  1. Dec 14, 2019 at 11:47 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    They do slightly, but the OEM wheels have room to accommodate that and isn't an issue. They are seated tight against the spacers.
  2. Dec 14, 2019 at 11:51 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Oem wheels have the knockouts on the hub.
    TRDFerguson likes this.
  3. Dec 14, 2019 at 12:32 PM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    They are smooth as butter out on the highway. Much more comfortable ride than the KO2s which I really liked.
    zia_tundra575[QUOTED] likes this.
  4. Dec 14, 2019 at 12:33 PM
    GarTX526
    GarTX526 New Member
    Many pending.....
    Thanks Z!
  5. Dec 14, 2019 at 1:38 PM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    OK I'm officially jelly right now, still waiting for mine to ship...
    Danman34[QUOTED] likes this.
  6. Dec 14, 2019 at 2:08 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    AJT Desings cup holder and shift rings.
  7. Dec 14, 2019 at 2:22 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    did mine too. I drilled it with a 7/32 bit for a little tighter fit. I think they should’ve gone with a smaller bolt.
  8. Dec 14, 2019 at 2:36 PM
    hudrock
    hudrock New Member
    So Cal
    18 Tundra before 20 Sequioa now
    Swapped the the drop in for a Bedrug and installed Rugged II Tonneau cover.....Thanks Black Friday
    rebmo, sseaman, mgm16trdpro and 14 others like this.
  9. Dec 14, 2019 at 2:44 PM
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    Nice! Hands down my best purchase for my truck so far.
    Yeah after some off-roading shortly after install, mine loosened up to the point that a couple of em dropped out. Since re-tightening they have been fine but I do check them now.
  10. Dec 14, 2019 at 2:53 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Remove the 2 torx t15 screws inside the sunglasses holder
    Slide the overhead console to the rear - will move an inch or so
    Pull down on the console - there are 2 metal clips holding it on
    Unplug console
    Then you can see the sunroof motor - disconnect the plug
    Mine had 8-10 wires plugged into it, but 2 were visibly larger gauge
    I tested the 2 larger wire with the volt meter to see if they were constant or ignition power
    The white with black stripe is ground on tundras
    Used t-tap connectors to attach the tiny dvr camera wire to
    Tested the DVR functions
    Reinstall everything back
    Tankstew and Scud like this.
  11. Dec 14, 2019 at 3:16 PM
    gman31
    gman31 New Member
    New Orleans
    RB20's. I like them more than I thought I would.
    georgiey22, ntg, sseaman and 9 others like this.
  12. Dec 14, 2019 at 4:16 PM
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Added a Tyger Tri-Fold Soft Tonneau Cover today
  13. Dec 14, 2019 at 4:26 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Lookin good! I just got my set today, install in a day or so. Excited!!
  14. Dec 14, 2019 at 10:22 PM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Picked up the new wheels. Method 313 with BFG K02 285/70/17 Load C. Couldn't be happier with the look.
    IMG-20191214-101345_9bb16b33f3359c2306e7e4da03946bd22bea54f1.jpg IMG-20191214-101521_44359c288440b4f97b3ccad6e506a516961493e9.jpg
  15. Dec 14, 2019 at 10:28 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  16. Dec 15, 2019 at 12:45 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    First oil change on the new Tundra, so I swapped out the cheap plastic filter housing for the aluminum version and added the Fumoto valve.
    Then put in the ESP long box I picked up with Earl’s killer group buy - love it!
    cjmay13, PeakIT, Tankstew and 12 others like this.
  17. Dec 15, 2019 at 12:55 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Installed my vent ring covers, that I received from my Tundra's secret Santa.
  18. Dec 15, 2019 at 1:07 PM
    jjstu123
    jjstu123 New Member
    James
    Las Vegas, NV
    2017 Super white Tundra Limited TRD
    Bilstein 6112/5160's ,35x12.5x18 Mickey Thompson Baja Boss's, K&N intake, Linex liner, Ceramic tint, Flow Master series 40 dual exhaust, TRD Pro grill, BAK Revolver X4
    Got some 31x12.5x18 Mickey Thompson Baja Boss's.
    ntg, sseaman, GAknight and 11 others like this.
  19. Dec 15, 2019 at 1:42 PM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    Finally got rid of my ugly wrap job on my cup holder trim and shift surround!
    cjmay13, ntg, tundratex19 and 11 others like this.
  20. Dec 15, 2019 at 2:05 PM
    Blue Thunder
    Washington
    Wow. That interior looks amazing with the various trim pieces. Nice job
    Ostrich[QUOTED] likes this.
  21. Dec 15, 2019 at 2:36 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Primer, pearl black basecoat, superwhite basecoat, and Max 2K clearcoat on my Limited grill. It is curing in garage right now. Now to get my hood bulge and color matching grill surround...
    ntg, sseaman, GAknight and 5 others like this.
  22. Dec 15, 2019 at 2:47 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Looking good!
    Those are on my list for sure. The Plastidip is not holding up well around the cupholders for me....
  23. Dec 15, 2019 at 2:52 PM
    FancyPants
    Amber
    Oregon
    Installed my 8” @dirtydeeds exhaust system today
    (with the help of my son)
    1015K9, georgiey22, GAknight and 30 others like this.
  24. Dec 15, 2019 at 2:54 PM
    Blue Thunder
    Washington
    I'm dead serious when I say I think it's awesome how many ladies we have on this forum...and how serious they are about their mods (and truck).
  25. Dec 15, 2019 at 3:07 PM
    Ostrich
    Nikki
    Marion, Texas
    Thank you! I've gone through quite a few ideas to get here.. next I'll be working on painting all the silver pieces.
    Thanks! Yeah, I had them plasti dipped black, then blue, then wrapped, now this. I think I'm done :rofl:. I do recommend these from ajt, I think they're nicely made.
  26. Dec 15, 2019 at 3:13 PM
    X2 :thumbsup:
  27. Dec 15, 2019 at 3:13 PM
    Nice. :thumbsup:
    FancyPants[QUOTED] likes this.
  28. Dec 15, 2019 at 3:23 PM
    FancyPants
    Amber
    Oregon
    Thanks! And I agree!
  29. Dec 15, 2019 at 3:37 PM
    Squatting Pigeon
    Holden
    North Texas
    Haha I know how that goes :rofl:
    I like the design of these way more than the tufskinz that came out a while back.
  30. Dec 15, 2019 at 3:38 PM
    daays
    daays New Member
    Installed my AJT surrounds yesterday. Pretty happy with how they turned out. Hardest and most time consuming part is drilling out the plastic welds. Also, I suggest securing the shifter surround with tape and drilling the holes using it as a guide, instead of simply marking drill spots and removing it.
    LyonKing likes this.
