This keeps popping out
Discussion in '2.5 Gen Tundras (2014-2021)' started by VA_tundra_gal, Dec 14, 2019.
  1. Dec 14, 2019 at 12:42 PM
    VA_tundra_gal
    VA_tundra_gal [OP] New Member
    Kimberly
    Botetourt, VA
    2014 Toyota Tundra Crewmax Limited
    6 inch Rough Country lift 20x10 -19 inch Hardrock Affliction wheels 35x12.50x20 Kenda Klever R/T wheels Custom design wrapped Opt 7 rock lighting BAMuffler Standard Dump System
    I'm at last whits trying to figure out is causing this???
    It keeps popping out!!
  2. Dec 14, 2019 at 12:47 PM
    First time I've seen anyone mention this before here. Are the plastic mounting clips damaged?
  3. Dec 14, 2019 at 12:48 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Worn retainer clip or warped bulge. Loosen all the 10mm bolts, snap it back in and tighten, but not too tight.
    DM 2018 Tundra likes this.
  4. Dec 14, 2019 at 12:48 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Possibly a broken clip. Duct tape and bubble gum and you’re back in business!!
    Cpl_Punishment and Pinay like this.
  5. Dec 14, 2019 at 12:51 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Find a large tree. From three feet out hit the gas. The impact should pop it right back in. Or try the other advice given.
    mttjdy and Cpl_Punishment like this.
  6. Dec 14, 2019 at 12:56 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Black Wolf likes this.
  7. Dec 14, 2019 at 12:58 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Had an sequoia do that and the clip was broke. It’s was on a 08.
    Got a grill off Amazon
  8. Dec 14, 2019 at 12:58 PM
    Grumpy Uncle
    Pat
    CO
    Mine were wore out to the point I had to replace the hood bulge.
  9. Dec 14, 2019 at 1:46 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Now is the time to get rid of that chrome
