04 Tundra 4WD issues - Please help
Discussion in '1st Gen Tundras (2000-2006)' started by NavyChief120, Dec 11, 2019.
  1. Dec 11, 2019 at 3:08 PM
    NavyChief120
    NavyChief120 [OP] New Member
    Glen
    2004 Tundra SR5 Crew
    So my 4HI light was blinking and would engage/disengage on it's own randomly but of course not for me when I wanted it to. I researched it and even spent $100 to get it professionally diagnosed to make sure. All of my research was confirmed (or so I thought) when I was told it was the transfer case actuator. I waited a few weeks for 1 from Japan on Ebay (Toyo part 1/3 cheaper than the Doorman at AutoZone and about 1/2 the dealer cost locally for a "genuine" Toyota part) and just replaced it this morning. Now the 4HI light doesn't blink unless I try sticking it into 4HI, and nothing else happens. I've spent over an hour searching threads with no luck and am frustrated beyond belief. Any help is greatly appreciated!
  2. Dec 11, 2019 at 3:45 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Chief, post up professionally paid diagnosis for us first please. Thank you. The bridge is yours.
  3. Dec 12, 2019 at 4:47 AM
    bmf4069 Captain wtf
    If it's doing it on it's own without you pushing the button it sounds like your wiring it funky. Replacing it may have jostled a chafed wire, making it worse.
    BubbaW and speedtre like this.
  4. Dec 13, 2019 at 2:08 PM
    NavyChief120
    Glen
    20191213_155427.jpg Here is the "professional" opinion I got from Dobbs
  5. Dec 13, 2019 at 2:13 PM
    NavyChief120
    Glen
    Oh yeah, if you're ever in St Louis or surrounding area Do Not go to them. I went back and told them I had replaced it and am still having issues, their reply was "it's not the right part." I did my research and am 99.99% sure I got the correct part. It looks identical, part numbers matched the dealer part number, and it mated up perfectly.
  6. Dec 13, 2019 at 3:53 PM
    NavyChief120
    Glen
    The reason I didn't say 100% is because very few items in this world are delegated to 100% status IMHO. Death, taxes, and the presence of both good and evil in the world being amoung them.
    Pinay and Sunnier like this.
  7. Dec 13, 2019 at 3:57 PM
    NavyChief120
    Glen
    To bmfr069:
    Do you have any info you can provide for me to troubleshoot the electrical connections? I am admittedly virtually ignorant of electrical systems, but more than willing to try with guidance. Thank you.
  8. Dec 13, 2019 at 4:00 PM
    Fred
    Hand Protectors
    Post up your new part number paperwork.
    Your truck is 2004 Access Cab SR5 4 WD?
  9. Dec 13, 2019 at 10:02 PM
    NavyChief120
    Glen
  10. Dec 13, 2019 at 11:08 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Your new part can be defective. There are a lot of counterfeite parts on eBay and Amazon. I have been bit by them also and avoid buying certain parts from those sites now. Sometimes you just need to pay the price and/or buy local.
  11. Dec 14, 2019 at 12:24 AM
    NavyChief120
    Glen
    Thanks for the tip, I'll try to remember it going forward v
  12. Dec 14, 2019 at 4:35 AM
    Fred
    Hand Protectors
    This was what I was going to say after seeing paper work. I think the counterfeiting is more on the ebay side. I would use an online stealership or OEM part online dot com site for that part Chief.
    Also, I believe your truck style is known as an Access Cab. The best of the body styles in the 1st Gen period.
    How about a link to the ebay site you shopped so we can look at it?
  13. Dec 14, 2019 at 4:47 AM
    Fred
    Hand Protectors
    It appears there are two different looking parts under the same part number when looking at diagrams.
    Did your old part look just like the new part when matched up?
  14. Dec 14, 2019 at 7:17 AM
    bmf4069 Captain wtf
    I don't, but I bet @BubbaW has something. What I said is merely the electrician in me speaking. I could be completely wrong.
  15. Dec 14, 2019 at 9:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Having followed since beginning and now that We or I could suspect the non OEM to be bad, I have to agree the initial issue could be elec but where would one start. Without knowing if Navy(go Army) wants to replace original actuator and start back from there, would I/We won’t to venture down the elec road.....the 2w/4h switch contacts could simply be flacky. There are few FSM steps that could be posted if that direction is chose
    :pccoffee:
    Solved - 4hi Light blinking, won't "disengage" 4hi and 4low work fine
    perhaps @jberry813 could drop by
  16. Dec 14, 2019 at 10:43 AM
    bmf4069 Captain wtf
    You might get under there and unplug the connector and check voltage while some pushes the button.
