Push rod adjustment advice, Brakes Locking Up!
Discussion in '1st Gen Tundras (2000-2006)' started by justinx987, Dec 13, 2019.
  1. Dec 13, 2019 at 12:32 PM
    justinx987
    justinx987 [OP] New Member
    Justin
    2001 v8 tundra 2wd access
    I have an '01 4.7 2WD that has been giving me fits with the brakes locking up! It will be fine at start up or after a long rest, but then it seems to build pressure to the point of almost stopping the truck. I have had to pull over and release pressure from the bleed screw. This is what I've done so far; changed calipers, pads, shoes, and flushed system fluid. thoughts, advise anyone please?
  2. Dec 13, 2019 at 12:43 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Try replacing the rubber brake lines. They can de-laminate on the interior, acting like a valve that won't allow pressure to release.
  3. Dec 13, 2019 at 3:46 PM
    Professional Hand Model
    Fred
    Hand Protectors
