Tundra moon roof
Discussion in '2.5 Gen Tundras (2014-2021)' started by pdavelar, Sep 17, 2017.
  1. Sep 17, 2017 at 6:19 PM
    pdavelar
    pdavelar [OP] New Member
    The moon roof on my 2014 Tundra Platinum suddenly stopped operating. Right now it's stuck in the " just slightly opened " mode & is leaking air. Annoying to say the least. Could it be a fuse ? Where is the fuse located ? Any other ideas ?
    Thanks,
    Pete
  2. Sep 17, 2017 at 6:28 PM
    How many miles are on it? Can anything be stuck in the track?
  3. Sep 17, 2017 at 8:18 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Somewhere in my owners manual I recall reading about cycling the moonroof after removing or replacing the battery. It was basically pushing and holding the buttons in a particular sequence to ensure that the tilt and full open/close work properly. Don't know if that'll help but might be worth a look.
    Patriot and Eclipsed & Floating like this.
  4. Sep 17, 2017 at 8:19 PM
    duece292
    Greg
    Green Bay, WI
    Oh yeah, welcome from WI
  5. Sep 18, 2017 at 12:44 AM
    pdavelar
    37,900 miles. I haven't recently changed battery or disconnected battery cables. Can something get in the track if it's been closed for at least 3 months ?
  6. Sep 18, 2017 at 3:07 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    One possibility check your sunroof switch, it may need replacing. Or what @duece292 said. This is the first time I have heard of this issue.
  7. Sep 18, 2017 at 5:45 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    You appear to be pretty close to the 3/36 warranty. I'd see if the dealer will fix it as an accommodation.
    dasunsrule32 and big_jarv like this.
  8. Sep 18, 2017 at 5:48 AM
    Patriot
    Patriot Member
    Or at a minimum meet you half way...that would be fair if your that close to factory warranty.
    Let us know how it goes...
  9. Sep 18, 2017 at 5:55 AM
    New member... Welcome from Texas! Post pics of your ride
  10. Sep 19, 2017 at 8:34 AM
    pdavelar
    Thanks for the welcome guys.
    duece292 likes this.
  11. Sep 19, 2017 at 9:17 AM
    Patriot
    Patriot Member
    Welcome from Western NC!
    pdavelar[QUOTED][OP] likes this.
  12. Sep 19, 2017 at 9:20 AM
    duece292
    Greg
    Green Bay, WI
    Did you find a solution to your dilema?
  13. Sep 19, 2017 at 9:37 AM
    pdavelar
    Not yet Deuce. I've been working 7 days a week & haven't had a chance to evaluate the situation some more. I'll keep y'all posted.
  14. Sep 19, 2017 at 11:55 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you haven't checked the fuses yet, there's the obvious fuse box under the hood. If it's not there, there's another fuse box in the cab. You have to lay on your back in the driver's footwell and look up near the parking brake area. Sorry, I don't have a sunroof so I can't tell you which box it's in.
    pdavelar[OP] likes this.
  15. Sep 19, 2017 at 12:04 PM
    pdavelar
    Thanks Joon
    joonbug likes this.
  16. Sep 20, 2017 at 5:58 PM
    pdavelar
    Well guys, I found the fuse ( under the dash ). It seems to be fine. I guess I'll have to explore other options.
  17. Oct 4, 2019 at 4:57 PM
    mmartin86
    mmartin86 New Member
    2012 Tundra Platinum 4x4
    I know this is an old thread, but did you figure out the problem? I bought a 2012 last week, and it did this same thing to me today.
  18. Oct 4, 2019 at 5:08 PM
    I prefer broken sun roofs..
  19. Oct 19, 2019 at 10:49 PM
    SilverPen15
    SilverPen15 New Member
    Silver Limited
    Chrome delete. Icon suspension. 35’s on bronze fuels.
    I bought a 2014 last week, changed battery yesterday. Had sunroof open today. Tonight tried to open it again, nothing. 25A Fuse under dash is good too. Any fixes?
  20. Oct 20, 2019 at 7:33 AM
    trinituner
    trinituner New Member
    Andron
    Orlando, Florida
    2017 Silver 1794
    Following...
  21. Oct 20, 2019 at 7:36 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Dude that sucks, I’ve gotta swap battery soon, not looking forward to this.
  22. Dec 11, 2019 at 5:11 AM
    HDZ1794
    HDZ1794 New Member
    Ernesto
    Following too. Everywhere I look no one has a legit answer. I have a 2015 1794 with approximately 97000
  23. Dec 11, 2019 at 6:03 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    I've already swapped mine out and didn't have to do anything at all with my sunroof.
    MAGDADDY[QUOTED] likes this.
  24. Dec 11, 2019 at 6:14 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Same here, got the new battery in and everything works fine!
  25. Dec 11, 2019 at 9:24 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    I have a 2017 Platinum with moon roof. Here is the interior fuse panel. Top left fuse 25amp. Hope this helps bro
  26. Dec 11, 2019 at 9:28 AM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I don't open mine. EVER.
  27. Dec 12, 2019 at 5:13 AM
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    Try this in post #2. Should be the same for Tundras. I know this is for the auto-open/close but perhaps it'll work too.
