Recommend using Flex Fuel?
Discussion in 'General Tundra Discussion' started by ragtopp63, Jan 11, 2016.
  1. Jan 11, 2016 at 2:12 PM
    ragtopp63
    ragtopp63 [OP] New Member
    Chicago,Il.
    2016 Tundra SR5 4X4
    2016 Tundra SR5 Flex Fuel Engine.
    seen some posts ware people want to stay away from flex fuel engine Why is that?
    I don't use flex fuel and don't plan to. I have always used reg. fuel and premo every 3rd or 4th tank full on all my vehicals . what do you recommend?
  2. Jan 11, 2016 at 2:24 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    My Sierra had it, I could really feel a HP boost with flex fuel. It does take away gas mileage but not as bad as people say. My injectors did gum up and I dont know the cause of it because E85 is supposed to burn cleaner. When gas was $4.00 E85 was like $2.75 and I saved a fortune in gas at the time. Thats all I got for you.
  3. Jan 11, 2016 at 3:28 PM
    Ubc2361
    Ubc2361 New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    Had it on my chevy wasn't too fond of it. Besides cheaper the only thing I saw diff was the gas milage really sucked
  4. Jan 11, 2016 at 4:28 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It isn't really the engine itself but the electronic side of things. From what I've been reading, the computer/sensor on some trucks software are reading the fuel in their tanks as containing a higher percentage of ethanol than what is actually in the tank. This makes the computer run a different fuel map, a richer one. This makes the engine run very poorly. Some truck owners are finding resolution via a software update from Toyota dealers.
  5. Jan 12, 2016 at 8:51 AM
    Fitz19d
    Fitz19d New Member
    2015 5.7 SR5 Tundra
    Black wheel dip. Prodigy P2 Brake Controller
    Wow, like the first person I've seen in my life that has a vehicle they care about and like running E85.....
    Flex fuel doesn't play nice with supercharging without a lot of headache.
    Over the years many repeated flashes and updates to avoid issues with the system reading alchohol when you are on normal gas resulting in rough starts and general feel of wimpiness.
  6. Dec 11, 2019 at 7:56 AM
    Target612
    Target612 New Member
    I have a 2016 FFV 5.7L V8 4x4 crewmax. I feel the need to notify the public that my car was having really really bad rough starts in the morning - didn’t matter if weather was cold or warm - first start of the day always sounded like the engine was choking. I googled online and found this site and many other message boards about the Alcohol Density Calculation problems and the need to “reflash” the ECM (see Toyota Service Bulletin T-SB-0058-13).
    I took the truck in to the dealer yesterday, they did a cold start this morning after it sat in the lot overnight, and concluded it had this problem that is specific to FFV Tundra engines.
    The service advisor said that Toyota just came out with a new TSB a few days ago updating the old TSB so that it now covers the fuel pump and the “reflashing” of the ECM, it now also covers all FFV Tundras from 2009 - 2019. The new TSB is T-SB-0166-19.
    So I hope this info helps, hit up your dealer if you are having enginestart-up problems with your FFVengine Tundras, and pass the word around!
    If I had known about these engine issues, I would have NEVER bought a FFV engine!!!
    This TSB engine fix is only good if you’re under 96 months or 80,000 miles!!!
  7. Dec 11, 2019 at 9:14 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Dont worry about anything related to Flex fuel engines. If you are not running E85 and just running 87 to 93 octane gas you should not have any issues. FFV engines have a different tune in them when the sensor in the gas tank senses E85. The fuel injectors are larger to push 25% more fuel in due to the E85. Also the fuel pump is larger in the tank and is a 2 speed pump to deal with the additional fuel requirements with E85. Other than that the engines are pretty much the same.
    And yes there is a issue with fuel density reading in the ECU over time you may need to have it reset
    Skew12 likes this.
  8. Dec 11, 2019 at 8:09 PM
    MAN N BLK
    MAN N BLK New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    Is the tsb only if you’re having issues or should it just be done regardless?
    Ronin73 likes this.
  9. Dec 12, 2019 at 4:04 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I'd like to know this as well.
