Oil change by Valvoline
Discussion in 'General Tundra Discussion' started by Pariverpirate, Dec 11, 2019.
  1. Dec 11, 2019 at 5:19 PM
    Pariverpirate
    Pariverpirate [OP] New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    So got a groupon for a Valvoline oil change. Cost me $39.99 for semi synthetic 5 quarts. I knew I would pay the difference for the extra oil. Ive done this in the past with my Tacoma. Got there today and they say their computer says only full synthetic oil should be used. I told them I already paid for semi. They told me no problem they would still honor it for full synthetic. So got the oil changed using the full synthetic. The additional oil was $24, kind of pricey but saves me from having to do it in 30 degree weather. They finish up and my total was the $39.99 I paid for groupon and $24 for the extra. This included a new crush washer for the filter. The guy proceeds to tell me it will take a couple more minutes because they have to put the skid plate back on........... Ummm ok is this normal to have to take the skid plate off for a oil change on a 2015 tundra??? If so glad I had them do it , lol.
  2. Dec 11, 2019 at 5:24 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    The stock skid plate needs to be removed to get to the oil filter. The TRD skid plate, and most aftermarket skid plates have an access panel which allow filter replacement without removing skid plate.
    Aerindel and Pariverpirate[OP] like this.
  3. Dec 11, 2019 at 6:41 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Yes, 5-6 bolts. 5 minutes for the challenged.
  4. Dec 11, 2019 at 6:49 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    $65 is pretty standard for an oil and filter change at the dealership...
  5. Dec 11, 2019 at 7:23 PM
    Pariverpirate
    Rich
    Non yet
    The thing I like about them is no appointment. You just drive up , never get out of your truck and your out in 15 minutes.
