2000 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Skullman3/, Dec 11, 2019.
  1. Dec 11, 2019 at 4:48 PM
    Skullman3/
    Skullman3/ [OP] New Member
    2wd extra cab short bed 2000 tundra
    Stock
    I have a 2wd 2000 tundra I’m looking to raise the front up about 2-3” what is the best route for street driving only
  2. Dec 11, 2019 at 4:53 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Not raising it up 2-3”.
    Keep it stock or maybe +1” upfront lift with Bilstein 5100 adjustable shocks. Affordable and safe and looks good!
    Aerindel likes this.
  3. Dec 11, 2019 at 6:38 PM
    Aerindel
    Aerindel New Member
    Montana
    Amen. I just removed a 3" ( I think) leveling kit from mine because when I parked it next to a un-leveled truck I thought the other one looked so much better.
    In anycase....thats what you do if for that is what you are going for. Strut spacers. Cheap and easy to install, although I wouldn't recommend it.
  4. Dec 11, 2019 at 6:56 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    I would say you could just throw a spacer(usually it’s a leveling kit that lifts the front a couple inches) on your stock setup and it’s cheap and isn’t going to damage to much but does put a little more stress on that upper ball joint I believe. Still rides great to me. I bought mine with that. Or if you want to do it right go new coil overs and upper control arm for the lift. I’d do king/fox shocks on camburg upper control.
