Best and most affordable rear shocks for 2005 Tundra CrewCab?
Discussion in '1st Gen Tundras (2000-2006)' started by barrys2005tundra, Dec 10, 2019.
  1. Dec 10, 2019 at 9:23 AM
    barrys2005tundra
    barrys2005tundra [OP] New Member
    Barry
    2005 Tan Toyota Crew Cab
    Hi All, I bought a used 2005 tundra crew cab about a month ago. It wasn't taken care of the best (as I am now finding out). Anyways I'm looking to upgrade the rear shocks asap due to it bottoming out when I drove over a speedbump with a moderate load in the bed. Any suggestions will be appreciated. I'm looking at the Rancho RS55041 shocks but never owned a Rancho shock on a vehicle before. Are the Bilstein shocks any better? Thanks...
  2. Dec 10, 2019 at 9:30 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    The Bilstein 5100s are better than Rancho. Some other good brands to consider are Eibach and Old Man EMU by ARB.
    Hbjeff likes this.
  3. Dec 10, 2019 at 9:31 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    fyi 4 door tundras 2005 and 2006 are actually doublecabs even though that changed in 2007. Most people here go with Bilstein 5100s cause of the price and performance.
  4. Dec 10, 2019 at 9:32 AM
    barrys2005tundra
    Barry
    Appreciate it. Thanks..
  5. Dec 10, 2019 at 9:33 AM
    Mustanley
    Hendersonville, NC
    CodyP likes this.
  6. Dec 10, 2019 at 10:23 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    You can’t go wrong with Bilstein 4600’s or 5100’s.
  7. Dec 10, 2019 at 3:23 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Not sure Barry as I’ve never had The Rancheros before but can for sure recco the Billy Bobs 5100 as a great value for all around street performance tow/haul shock. They are stiff and sporty.
    If you are off roading mucho then plan on spending mucho on other types of shocks. Its a slippery slope.
  8. Dec 10, 2019 at 9:30 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Replacing the rear shocks won’t change anything if your rear leaf springs are worn out (which it sounds like they are).
  9. Dec 10, 2019 at 10:01 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Bilsteins are what you want. The Bilstein 4600’s are great for street/dirt road driving than the more stiff off road running 5100’s. Choose wisely by considering the terrain you frequently drive on. Avoid becoming irritated from feeling every imperfection in the road if mainly on street due to running HD off road shocks.
  10. Dec 11, 2019 at 4:52 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    +1
    Springs support the load, shocks dampen movement/rebound. New shocks won't keep you from bottoming out.
