  1. Dec 6, 2019 at 11:40 AM
    #5791
    Dylan7194x4
    Dylan7194x4 New Member
    Dylan
    2013 red cm rw
    This is almost exactly the set up I'm going with to stuff 35s. Except I'm doing boss fronts with the 700lb red coilovers and boss reservoir rears. My question is did you have to do a carrier bearing drop or front diff drop? What lift do you have up front and what did you end up with in the rear?
    Scary[QUOTED] likes this.
  2. Dec 6, 2019 at 11:54 AM
    #5792
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    I have the same head unit and love it. I installed my camera in the factory location and happy with my field of view. DA9102D1-D691-44A6-9604-21B4F54EF9F2.jpg
  3. Dec 6, 2019 at 12:32 PM
    #5793
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Cluster is back.
    Ordered the AUTO HVAC control panel today, while I had the cluster out to reinstall the new one I went to install the light sensor I bought and it was already there and wired in! woot!
  4. Dec 6, 2019 at 2:01 PM
    #5794
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    My wrapped door handle didn't handle cold weather well so I decided to spray paint them. Only did the driver side so far 20191206_152918.jpg 20191206_152246.jpg
    D4x4TRD, Scary, Rica25 and 5 others like this.
  5. Dec 6, 2019 at 4:40 PM
    #5795
    Silverghost
    Silverghost New Member
    13 tundra 4x4
    Very budget minded build , I'm very thankful you shared what you picked and spent , any pics of this bad boy?
  6. Dec 6, 2019 at 4:50 PM
    #5796
    Jrharvey02
    Jrharvey02 New Member
    Is that 202 Black?
  7. Dec 6, 2019 at 6:23 PM
    #5797
    Cobeez
    Cobeez New Member
    2012 White Tundra CrewMax TRD
    20" Black Toyota Rims 275/65/20 Sierra Radial A/T Tires 2" Leveling Kit Tow Mirrors w/ Side Markers
    Is that the stock stereo surround or did you have to get a new one? I like that Alpine!
  8. Dec 6, 2019 at 6:41 PM
    #5798
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Did you overpay? I saw their pricing and went the ebay route. Same fortin unit with less wires to tap.
  9. Dec 6, 2019 at 6:48 PM
    #5799
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    @Civiceg94 did those instructions help ya out?
  10. Dec 6, 2019 at 9:36 PM
    #5800
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    Yes it did. Its a really simple thing to add. Worst part was arranging the wires and zip tie them in place.
  11. Dec 7, 2019 at 2:16 AM
    #5801
    Sober_Survival
    Sober_Survival New Member
    08 Tundra 4x4
    When I pulled my "blank" switch covers, the wiring plug is completely different then the one on the back of the USB plug. I'm not sure what to do...
    TRD-tv and Rica25 like this.
  12. Dec 7, 2019 at 2:23 AM
    #5802
    Sober_Survival
    08 Tundra 4x4
    NVM. I ordered the wrong one originally. I ordered this: Cllena Car 12V 24V to 5V 3.1A Dual USB Ports Dashboard Mount Charger Blue Light for Toyota (2.1/1.2A-2) https://www.amazon.com/dp/B01CTOKI06/ref=cm_sw_r_cp_api_i_BZ36DbC5NA77R
    and it didn't work.
    Rica25 likes this.
  13. Dec 7, 2019 at 4:20 AM
    #5803
    omgboost
    East Coast
    Yes
    Jrharvey02[QUOTED] likes this.
  14. Dec 7, 2019 at 6:32 AM
    #5804
    Jrharvey02
    That looks really good. Just spray paint or did you also wet sand and clear coat?
  15. Dec 7, 2019 at 7:22 AM
    #5805
    omgboost
    East Coast
    No wet sanding. I used some rubbing alcohol on the chrome, applied two coats of the adhesion promoter, 4 coats of the Toyota black, then 3 coats clear coat. All duplicolor products. I may wetsand 2000 grit next week to make it look a bit better or just leave it of I'm feeling lazy.
  16. Dec 7, 2019 at 9:21 AM
    #5806
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    No drop kits of any kind. I've learned to avoid drop kits if possible. 2 - 7/8" front and 1 - 1/8" rear.
    When I looked at the geometry (my rough calculations are somewhere) the delta in angle from front and rear lift applied to the CVs and driveshaft respectively were trivial. If you're worried, measure angle before and after, then find the tolerance of angles on the CV and u joints... You'll find the difference is negligible. If I find measurements laying around, I'll post... Might be on whiteboard.
    Since I'm an engineer by trade, physicist by education, I prefer calculations using experimental data over recommendations by other forum users or vendors. I need to know what I'm doing is necessary for application.
    This morning. :)
  17. Dec 7, 2019 at 9:38 AM
    #5807
    Dylan7194x4
    Dylan
    2013 red cm rw
    Awesome info! Thanks one more question did you notice any loss in power with the lift and 35s and what is your average mpgs with what kind of driving? I have a 2013 rock warrior and yours has the exact stance and setup that I want. Thanks again for sharing.
    Scary[QUOTED] and Rica25 like this.
  18. Dec 7, 2019 at 12:05 PM
    #5808
    kgb4187
    kgb4187 New Member
    I didn't install my new color matched door handles because Sparks didn't think I would need both sides.
    TRD-tv, Prostar 190 and Mountun Goat like this.
  19. Dec 7, 2019 at 4:39 PM
    #5809
    Lifeislarge
    Lifeislarge New Member
    2007 Tundra 4X4 TRD 5.7L
    The usb wire on the back of the new port goes into the usb on your aftermarket stereo head unit and the black and red wires need to be tapped in to the 12v socket underneath the AC controller. Use a testlight to tell you which wire is 12V (that's where you attach the red wire) and the other one is ground (black wire). Use scotchlok connectors to attach the wires and you should be GTG.
    Mountun Goat likes this.
  20. Dec 7, 2019 at 7:15 PM
    #5810
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Did you go with coil set up at 2 inch or 3 inch coil lift? By the pictures I would guess 3.
  21. Dec 8, 2019 at 3:31 PM
    #5811
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Got my 1794 20s and Falken Wildpeaks AT3W installed. Unfortunately 1 tpms sensor wouldn't come out of the old wheels. Nothing some black tape on the dash couldn't fix.
  22. Dec 8, 2019 at 4:23 PM
    #5812
    mbn225
    mbn225 New Member
    Louisiana
    2008 Tundra Crewmax TRD
    Rock Warrior Bits Flowmaster exhaust 3/1 Lift
    Got my 23Zero roof top tent on and will be doing a trial run next weekend. Great quality!E071BB66-8411-4065-9AE0-BD8EFD788FB8.jpg
    Scary, kparrow, D4x4TRD and 4 others like this.
  23. Dec 8, 2019 at 7:03 PM
    #5813
    TheBeast
    TheBeast The Beach
    swapped clear lens for amber lens for my Baja ditch lights. should be good for the snow.
    Mountun Goat, Rica25 and Prostar 190 like this.
  24. Dec 9, 2019 at 8:27 AM
    #5814
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    Yes, but to be honest with ~33s before, the truck felt super jumpy, especially off-road. Hitting bumps in the road would cause my foot to bounce and hit the throttle, jerking forward. Now there's not that instant torque applied to the ground, feels less twitchy. It still gets it though. It will spin without effort on concrete. I drive like an asshole, so I don't know MPGs before or after. Seems like I'm topping off about the same, but I also never let it go below 1/2 tank. Sorry that I don't have better insight there. Calculating the MPGs would just make me sad, so I avoid it.
    With the coilovers I chose, they are preset at 3 inches. Unlike the Billstein coils, there isn't a setting to choose. I went with convenience of not messing around with spring compressors over the ability to have adjustability in ride height. But after some off-roading this weekend, the springs have settled into a total front end lift from hub center to fender of +2-7/8".
  25. Dec 9, 2019 at 4:46 PM
    #5815
    e30cabrio
    Dealer parts needed for the auto AC swap & auto headlight switch came.
    Any tips on the install from anyone that has done it?
  26. Dec 9, 2019 at 5:06 PM
    #5816
    Randy Morton
    Randy
    Deepinahearta, Texas
    Document the installation and create a separate thread. I'm sure there's a lot of interest.
    TheBeast likes this.
  27. Dec 9, 2019 at 5:22 PM
    #5817
    e30cabrio
    I'm going to create a thread asking about the headlight switch (there are several threads for the AC) I have found one for the switch that uses a parts seller's write up that is a dead link, if no one helps with a thread that exists I'll change t to a DIY.
    Rica25 likes this.
  28. Dec 9, 2019 at 7:51 PM
    #5818
    Coldjustin
    Coldjustin New Member
    Justin
    2008 Limited Crewmax
    Kenwood ddx9904s, leveled with 305/55/20 nitto terra grapplers g2's. Dual flow masters
    Replaced 3 door lock actuators and a left rear wheel bearing. The right rear will have to wait because I simply ran out of weekend before getting it done. Bought my own press and done the entire job in my garage. Man does that feel good to say. Didn't pay a dealer or a machine shop to press anything off or on. And I have only had my garage for about a month. Before that I done my work at home on a gravel driveway. I'm spoiled now.
    Prostar 190, Viking, Scary and 3 others like this.
  29. Dec 9, 2019 at 9:55 PM
    #5819
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Ditch lights anyone?
    WVI, chugs, airosey and 12 others like this.
  30. Dec 9, 2019 at 10:00 PM
    #5820
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :thumbsup::thumbsup:
    Good for you sir :hattip: Officially livin the dream now! :thumbsup:
    vq35721 and Coldjustin[QUOTED] like this.
