  1. Dec 8, 2019 at 4:45 PM
    Zachp
    Zachp New Member
    Zach
    2016 tundra SR5 TSS 5.7
  2. Dec 8, 2019 at 4:45 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Is there not a plug and play replacement that will have decent improvement where can just replace the lights?
  3. Dec 8, 2019 at 4:47 PM
    18" TRD Off Road Wheels
    Yep, that would be replacing the bulbs with a higher quality halogen.
    If you are going to replace the whole housing you would be best served going LED, and that requires a harness to regulate the voltage for the LEDs.
    equin likes this.
  4. Dec 8, 2019 at 4:51 PM
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    I did not do an alignment only because I lifted the front a few inches shortly after getting the wheels and needed an alignment after that. I lost about 1 mpg with just the wheels and tires installed before the lift.
    Albinator[QUOTED] and GODZILLA like this.
  5. Dec 8, 2019 at 5:05 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    ahhh....ok. So any LED requires wiring to account for the voltage
    So I have found these but they just say “projectors” and don’t say whether they are LED or not but also are supposed to be plug and play so I guess they aren’t LED? I like the look of them but not sure if they would be brighter. Have some tail lights form them and they are working great.
  6. Dec 8, 2019 at 5:31 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I can see that lol you've got plenty amber there. For me, I only have the squadrons fogs in amber. I have them on my stalk and pretty much use as a high beam turning on and off as vehicles approach so I can see wildlife off the sides of dark windy roads. The s8 with dash push button in clear I use when it's really dark off road and when I'm sure there is no one around on the road during crazy hours.
    The plan I have is to mount 2 BD LP9s or at least 6's in amber on top the SSO push bar. My Warn Platinum Zeon 10s has 2 auxiliary ports to run accessories. Since my wireless handheld is always charged in the center console I plan to hold that in my hand with just my headlights on for those times I'm driving into work in the middle of snow storms, offroad, and in crazy fog when no one else is on road. I'll know ahead of time when I'll need them and a simple push button on and off from the remote will greatly increase my visibility from those ambers in heavy snow since I'malways driving in it.
    As you can see I've already thought this one out and have convinced myself it's a necessity. Now it's just a waiting game to find someone selling them so I can save some money off them.
  7. Dec 8, 2019 at 5:59 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    thanks for the info....appreciate it!
  8. Dec 8, 2019 at 6:27 PM
    Some LEDs could have resistors built in and be plug and play, but your halogen housings would scatter the light.
    The projector refers to the piece inside that looks like a fish eye. Not an indicator of the bulb type, and I think they are good for any bulb type. I might be wrong about compatible bulbs. ***The ones you linked are for a sequoia and will not fit your 2019 Tundra.***
    I really recommend you talk to IHacker and Roman. They will have better info than I will for the OEM swap.
  9. Dec 8, 2019 at 6:31 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Mounted a block plug in my n-fab bumper after I fought with Toyota last week about their crappy install of the factory plug that burnt off on the manifold. 9A1D21E2-F3FA-4D8B-826A-5D0152F4B1B5.jpgThey refuse to warranty it because I’m heavily modified with an after market bumper they said.
    5CB6F0DE-1DD1-4542-B624-44D29FF2ECD6.jpg 008F9039-B9DB-486E-88D1-A9C92970B204.jpg
  10. Dec 8, 2019 at 6:38 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    yeah I selected the wrong one on the site, this is the one I meant to select. Thank you for the info and will certainly check them out once i figure out which way I want to go.
  11. Dec 8, 2019 at 6:39 PM
    I was going to say they can't deny warranty unless they can prove your modification caused it, but then I saw Canada. Idk what protections you guys have.
    equin likes this.
  12. Dec 8, 2019 at 6:49 PM
    bomber
    bomber New Member
    2017 tundra cm 4x4
    Ajt climate control knobs, footwell lights and added led in center console.
  13. Dec 8, 2019 at 6:59 PM
    daays
    daays New Member
    Ordered a set of Alpharex headlights. Can't wait for them to get here so I can replace my stockers in my '16 SR5. And on the fence about the ecoological bumper caps or an ESP storage box as the next upgrade, most likely next month.
  14. Dec 8, 2019 at 7:11 PM
    AZBoatHauler
    So.Arizona
    First drain and fill for the transmission at 40k. Fluid came out darker than I anticipated so I’ll do another 4 quarts with my next oil change.
  15. Dec 9, 2019 at 6:00 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Never seen a bumper with a plug in it what do you use it for
  16. Dec 9, 2019 at 6:45 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    He’s in Canada so I’m going with block heater?
    Rica25 likes this.
  17. Dec 9, 2019 at 7:09 AM
    canadianguy
    Kevin
    Yup, just put a better block heater plug in.
  18. Dec 9, 2019 at 9:42 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Hit 50k miles on my 2017(bought 8/2017). Changed oil, rotated tires, and changed air filter for first time. I live in country, but no dirt roads and no trees around my house (plus I park in the garage). Got to utilize the fumoto valve I had installed last oil change. So far no issues at all with my truck aside from having to change battery out about 3-6 months ago.
  19. Dec 9, 2019 at 9:48 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I know the thread has moved on from this, but y'all have some great info on fog lights and headlights in general. I'm in Texas, so rarely do we see snow. But we do get lots of rain day and night and occasional fog in the winter. Would yellow fogs still be better for those conditions or stick with the white fogs? And regardless of yellow or white, any recommendations on a good replacement? I've been looking at the Caliraised fog light and housing replacement, but I know very little about lighting other than having used the old-style Hella 500 off-road lights many years ago in past trucks I once owned.
  20. Dec 9, 2019 at 2:00 PM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
    TRD Shift knob and steering wheel matched accents. Have tufskins install on rest tonight. Woohoo.
  21. Dec 9, 2019 at 2:02 PM
    MJB_Tundra
    MJB_Tundra New Member
    Upgraded Sound System, bed cover, LED lighting, BA Muffler, Blisteins front/rear
    Check the skid plates. I had some minor rubbing on the front of the skid plate. Just used some pliers and bent the corner a half inch.
  22. Dec 9, 2019 at 3:53 PM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    Got my new bumper 511CD511-D5FA-4295-A916-13C4D30EF97F.jpg 5FAD3E88-10DD-4ADE-B83E-489EF60E1E2A.jpg
    cjmay13, GAknight, Pat and 16 others like this.
  23. Dec 9, 2019 at 3:56 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Hell to the yeah!!! That’s sexy!! :fistbump:
  24. Dec 9, 2019 at 3:57 PM
    Wheel tire setup?
  25. Dec 9, 2019 at 4:02 PM
    HazMatt
    HazMatt Go go gadget thingamajigger
    2019 MGM Tundra TRD Sport
    Toytec Boss Coilover suspension, JBAOffroad UCAs, Black Rhino Fury Gunmetal 18x9.5, Nitto Ridge Grappler 295/70R18, Access Vanish bed cover, spray-in liner, running boards, wind deflectors, Borla exhaust, Bedrug liner, rear floor storage, LED front turn signal bulbs, LED interior lights, TOGUARD dash cam, Yaesu FTM-400XDR HAM radio, Victory 4x4 18” modular bed rack, Tepui Autana 3 RTT
    Sweet!
  26. Dec 9, 2019 at 4:07 PM
    HazMatt
    Started work on my truck bed 12-volt access. I haven’t mounted the plugs yet because the wiring will need to be attached before hand. Still figuring out what all I will run from the back.
  27. Dec 9, 2019 at 4:09 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Opened a box with this in it. Nothing really "done" lol. Just had to get a peak at it.
    FancyPants, GAknight, Rica25 and 5 others like this.
  28. Dec 9, 2019 at 4:16 PM
    gears_call
    Orange County, CA
    2014 SR5
    :cheers:
    Rica25 and Pinay[QUOTED] like this.
  29. Dec 9, 2019 at 4:18 PM
    gears_call
    Orange County, CA
    2014 SR5
    18” Method double standards
    35x12.5 Toyo Open country m/t’s
    cjmay13, Rica25 and equin like this.
  30. Dec 9, 2019 at 4:19 PM
    It looks good, what's your offset?
