Another Tundra or Jump Ship
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sierra_Nevada, Nov 15, 2019.
  1. Dec 8, 2019 at 9:34 AM
    #211
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Good luck with your new Tundra. When the time comes, I will be jumping ship. Not enough capacity in the Tundra platform, and more problems with my Tundra than I was expecting. I have decided that Toyota sort of sucks at making seals. I have had cam tower leaks on both sides of my truck, and when I recently took my truck in under warranty for the broken clock spring, they replaced my oil pan seal that was leaking. That combined with early shock, ball joint, and other minor failures - makes it a no-go in the future for me.
    Also, I'm not a huge fan of the way the new Tundras look - then again, nobody really makes a good looking truck any more.
    B737 likes this.
  2. Dec 8, 2019 at 12:04 PM
    #212
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The brand new, completely redesigned GM twins didn't do great on that crash test either, from what I've read.
  3. Dec 8, 2019 at 12:11 PM
    #213
    14txtss
    14txtss New Member
    Ron
    Houston
    2017 attitude black platinum 5.7 4x4
    My 2014 has 73k on it, never had a single issue. Im sticking with Tundras until i need heavy duty for towing a toy hauler with ATV's
    GODZILLA and Cpl_Punishment like this.
  4. Dec 8, 2019 at 12:28 PM
    #214
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    Thank you. Yes, I was comparing strictly tow capacity without restricting trim choice.
  5. Dec 8, 2019 at 12:29 PM
    #215
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Only truck I trade to is a V-8 Tacoma :headbang:
  6. Dec 8, 2019 at 2:06 PM
    #216
    WNY PAT
    WNY PAT New Member
    trie - I think they were rated marginal. The Tundra was rated poor, the worst possible rating. It’s just unacceptable. The Ram, Ford and Nissan all received the highest rating of good. Toyota needs to address this. With TSS and all Toyota’s talk of their commitment to occupant safety, this doesn’t jive. I knew about the ratings when I leased my 2019. But honestly, the safety ratings will be one of the things I consider carefully when the 4th gen comes out. I have to assume Toyota will step up, but I’ll be checking before I drop my $50K+. IMO anyway. :)
  7. Dec 8, 2019 at 2:17 PM
    #217
    B737
    Jersey Shore
    so i guess reading isnt your thing, i'll spoon feed a bit...
    This is tow capacity, not limited to "platinum trim".... Most of these figures, are greater than, the tundra. If you need additional help with maths I will be by later...
    Neither does Toyota, 8' bed can only go on double cab and regular cab... However, ford does offer 6.5 ft beds on all trim and configurations (besides Raptor and Limited).
  8. Dec 8, 2019 at 3:30 PM
    #218
    PermaFrostTRD
    Northern NY
    a chart of diesels, turbos, and other useless “oranges” shit. Congratulations, you’re a moron.
    5._liter v8 naturally aspirated engines. 4 full doors. 4wd. All the buttons and knobs and switches inside from each manufacturer to make it tingle where you dingle. That was the original comparison *you* were making.
    All I did was correct your mistake. It hurts, but it heals.
    szabo101 likes this.
  9. Dec 8, 2019 at 3:53 PM
    #219
    Technically a true 3rd gen needs to come out before the 4th gen. The DC didn't get the poor raring. The Crew Max did. DC's always have historically done well safety wise compared to the CM.:thumbsup:
    WNY PAT[QUOTED] likes this.
  10. Dec 8, 2019 at 3:59 PM
    #220
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Yeah never understood that. Maybe because of the weight difference between the DC and CM which leads to the different ratings in safety?
  11. Dec 8, 2019 at 4:15 PM
    #221
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    Our 07' DC has 245,000 on the odometer and everything from the engine compartment to the rear axle is bone dry. Due to our age, this truck may be the last one we'll every own, but most certainly, if I had to get another truck, it would be a Tundra and I don't care if it's an "old" platform, it's one damn good truck!!!
  12. Dec 8, 2019 at 4:25 PM
    #222
    B737
    Jersey Shore
    lol right bud. You just keep the blinders on and drink the kool-aid, never mind those pesky facts.
    Atomic City Tundra likes this.
  13. Dec 8, 2019 at 4:27 PM
    #223
    WNY PAT
    WNY PAT New Member
    That’s interesting. Learn something every day. Wonder what the difference is.
  14. Dec 8, 2019 at 4:45 PM
    #224
    Has something to do with the cab if I recall correctly. DC has always fared better than the CM in the annual safety tests. I don't recall the DC ever getting a marginal in any category. The Tundra is a safe truck. Problem is not much at all has changed safety wise with the Tundra, other than more sensors, since 07 and the Big 3 have updated their safety so naturally they get better results. Doesn't mean the Tundra isn't safe, just not up to date with what the Big 3 have done.
  15. Dec 8, 2019 at 4:55 PM
    #225
    GNX6
    GNX6 New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    As a former GM employee of 22 years I can tell you despite whatever little quirks the Tundra has it is nothing compared to the pain you feel after a few years of owning a Chevy. I was very proud to own my Tundra working for GM and I showed all my co-workers on a regular basis why it was a better truck. I can also tell you I hit a deer with my Tundra and it took that hit like a champ.
    Get another Tundra.
  16. Dec 8, 2019 at 5:17 PM
    #226
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Wait... So are you saying that because a stripped out RCLB XL trim can tow 13k lbs your Platinum CC is way more equipped to tow than a Tundra Platinum?
    That's like saying my wife is hotter because her sister is hot. Just because it's possible in the family doesn't make the entire family automatically better.
  17. Dec 8, 2019 at 5:45 PM
    #227
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, I didn't mean to imply anything about the Tundra. Just pointing out that there's no such thing as a crew cab long box halfton from Ford (or any other manufacturer). The label on that chart was just a bit confusing/ misleading.
  18. Dec 8, 2019 at 7:07 PM
    #228
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Dude, you own a Tundra. You should know this is blatantly inaccurate. I don't know why people assume the Tundra is more basic than it is. The Platinum and 1794 both come standard with Premium Leather seating that far exceeds the crap that they put in F150s. The 1794/Platinum also offer adaptive cruise control, navigation, parking sensors, class IV receiver, 7 pin/4pin wiring harness, 4.30 rear axle and a 38 gallon tank as standard features. The Lariat offers none of those features as standard. Add them and you significantly exceed the price point of a 1794/Platinum Tundra.
    The F150 Platinum doesn't offer premium leather seating, adaptive cruise, larger tank or pedestrian monitoring as standard. The adaptive cruise/ pedestrian detection is part of a $2300 upgrade package on the F150 Platinum. If you want to tow and upgrade to the towing package (Standard on my Tundra, it is another $2300 to add the tow package, 36 gallon tank, 7 pin wiring harness, and the Ford 3.55 (but still shitty for towing)rear axle. The standard rear axle on the Ford is 3.15.
    When I get done pricing out a F150 Platinum with all the features of 4x4 platinum Tundra, it comes out to $64k. The Lariat comes out to about $62k. So tell us again which features of the 1794/Platinum Tundra make it closer to a Lariat, when the standard features actually blow away the Ford Platinum.
  19. Dec 8, 2019 at 8:02 PM
    #229
    belanger9
    Edmonton, AB
    A bunch
    Just looking at pricing is why I wouldn't compare platinum to platinum. Toyota is at CAD $65k, F150 is at $75k. Lariat pricing is much closer even if it lacks a few options.
    This point is what annoys me about 'journalists' reviewing trucks. They put the Tundra Platinum against a Denali, Laramie Limited, F150 Platinum and say the interior is the worst. No shit it is, those models cost $10k more than the Tundra, they better have nicer interiors. It's like they're penalizing Toyota for not doing an ultra-luxury focused pickup.
  20. Dec 8, 2019 at 9:33 PM
    #230
    GNX6
    GNX6 New Member
    2014 Crewmax
    I looked at the new Chevy at the car show last weekend with that funky tailgate. The back seats were a joke.
  21. Dec 9, 2019 at 12:31 AM
    #231
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Exactly 100% of the dozens, if not hundreds of f150 platinums I searched for all came with the upgrade packages. I think the Tundra is the best truck for me, but I won't pretend like the big 3 don't have better feature sets and way more available options.
  22. Dec 9, 2019 at 10:52 AM
    #232
    B737
    Jersey Shore
    ^ this is woefully inaccurate. Off the top of my head, I can think of at least 15 or 20 items Toyota doesnt even offer, that are available either stock or as an option by Ford. The platinum tundra is still in the stone age, no matter how much they try to polish that turd. Want a 6.5' bed? Limited is the highest trim you can get from toyota and it is pretty much a base truck by today's standards. A platinum F150 with the $1800 701A Tech Package (comes with a $500 credit), + extended range tank, will run rings around platinum tundra, and can be had for under 60k w V8. The F150 doesnt come with mud flaps or wheel well liners standard though ;)
    Toyota has to keep the tundra budget friendly because they cant compete anywhere else, besides reliability and price.
    Want a reliable truck on a budget? Or be more comfortable, spend a little more (while wisely adding an extended warranty)...
  23. Dec 9, 2019 at 11:35 AM
    #233
    RPKEAN
    RPKEAN New Member
    Perhaps I’m pouring gasoline on the fire but I paid $46k for my Platinum back in August.
    So the question is if all the benefits on the F150 Platinum are worth that much more than the Tundra Platinum.
    Maybe I’m a simpleton consumer since I came from a Tacoma with not much options or technology; I thought the Tundra was a real nice step up. I’d rather have the extra $10-15k of cash in my pocket than a 10 speed trans or a truck that can reverse a trailer with a dial. All personal preference of course.
  24. Dec 9, 2019 at 12:50 PM
    #234
    18" TRD Off Road Wheels
    This is the important part. Anybody can justify accepting any numbers, stats, pros or cons if it is what they want. The "my truck is better" debate is always going to be subjective because there is NO truck that is the absolute best in EVERY category.
    Truck A can tow more so it's better! Truck B has the best ride so it's better! Truck C has more options so it's better! Truck D is the most reliable so it's better! :facepalm: Who cares? Do your research, compare the points that matter to you and get the best truck for YOU. If you have to flaunt it or run another person's choice down it says far more about you than it does about the truck.:smack:
    MS22, CMB, 71_340 and 4 others like this.
  25. Dec 9, 2019 at 1:22 PM
    #235
    RPKEAN
    RPKEAN New Member
    When shopping I knew I’d have some remorse when looking how “old” the Tundra is compared to other half tons, especially driving this and a 19 Ram side by side.
    However in 2011, I bought an F150 Ecoboost new since it was such a new technology and it was great at first. Then at 5k miles on the ODO they had to drop the transmission out of the truck and keep it for two weeks. Then the next year the rear end shudder started. Then at 60k miles the truck started acting up, throwing codes, going to limp mode, etc. sold it for the Tacoma shortly after. That whole experience reminded me of the chance I’m taking (valuing my time over an extended warranty which I had on the F150) with domestic trucks and a newer model. All three domestics had new tech between redesign and power trains. This was something that when I drove the Tundra, I knew these things were built like tanks I could trust. That above along with the Options and “luxury” trim you get per dollar vs domestics is what sold me on the 12 year old new Tundra. I’m a Director of Finance for a living so my mind works in dollar value per unit to make decisions on a daily basis. Fords and Rams are really nice trucks but the value per dollar was maxed out with the Tundra IMO. And an earlier post of mine shows the door sticker payload not that far off from a super crew F150 (although it was a picture of a specific model).
  26. Dec 9, 2019 at 3:34 PM
    #236
    superslif
    superslif New Member
    NE. Ohio
    2014 Tundra Double Cab 5.7 Limited
    Firestone bags, Toyota tow mirrors, TRD sway bar
    I 100% agree...the Chevy 1/2 tons have "kiddie" rear seats at best. That is another reason to check out the new (2020) 2500 Chevy's when they start to produce the double cabs. The 2500's are supposed to be much larger in the back seat area on the 2500 double cab configuration.
    As far as "pricing" between the upper three trim levels on the Tundra (Limited, Platinum and 1794) and the "Big 3", I'll see some value in a Tundra. Couple that with it's reliability pedigree, resale value and the fact it's more of a "simple" truck, you can have some peace of mind owning one. I think my 14' Limited DC sticker-ed for $42k back in Dec of 2013 (when ordered). At the time the 2014 1794's were $49,999....where the top of the line F-150's were hitting near $60k.
    Having my 14' Tundra now for close to 6 years, it's treated me well. The only issue was when I went to do brakes, the new factory pads were "squealing" the first application in the morning. My Toyota dealer said there was a "issue" with the new pad material not being designed to the rotors. The front pads as of Aug. 2019 were re-formulated. So my dealer swapped them out, and threw on new rotors (free of charge). He said the new re-formulated rear pads were to be available either Dec or Jan. So those will get swapped out my next oil change.
    szabo101 and GODZILLA like this.
  27. Dec 9, 2019 at 4:01 PM
    #237
    belanger9
    Edmonton, AB
    A bunch
    Please list them - I go through all the trucks from time to time in my downtime and can't think of that many. I'll get it started for Platinum to Platinum off the top of my head:
    Pano roof - although this is a negative to me, I don't like holes in the roof, bigger hole means possible bigger problems.
    Crash test - F150 is lighter, meaning it takes less impact force, let's see a Tundra v. F150 head on before any conclusions can come from this.
    Don't think a Tundra has a 120v plug
    That's all I got without digging into the websites. I'd like to see what you come up with.
    Cpl_Punishment and szabo101 like this.
  28. Dec 9, 2019 at 4:07 PM
    #238
    szabo101
    szabo101 New Member
    ED
    I can't tell if you're serious, your statements are all contradictions. Nope, no 6.5' bed. You better go buy a Ford. Good luck!
  29. Dec 9, 2019 at 4:23 PM
    #239
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I get so frustrated with Ford......
    I just spent 25 minutes trying to build a comparable Lariat to my Toyota Platinum. Ford absolutely nickels and dimes you and puts popular options as part of a package.
    I went to select 20" aluminum rims and it is a $4,260 upgrade package.
    I went to select the ford version of adaptive cruise control and it is part of some 502a upgrade package or something like that for almost $6k upgrade.
    I tried adding tube step bars and you had to select an appearance package for $$$$.
    You try to get close to options on the Tundra and if you want to add one little thing, you have to select a package with a bunch of other stuff.
    I built a Lariat with comparable features, actually a little less and it was $61k. I choose the few missing options and it jumps to $65k plus. I doubt ford dealers are going to come down $14k to get to $51k which is the price of a Platinum.
    looking in auto trader and cars.com and you can pick up some really nice looking loaded Lariats that are 2 years old and under 40k miles for $32k to $36k, and that is advertised price.....
    the $51k Platinum less than 2 years old with under 40k mikes are advertised for $39 to $44k used.
    there are 47 used Lariats just in Knoxville alone. Those people took a beating!!!
    I would hate to spend $60k in a truck just to trade it in for $31k max to years later. Ouch!!!!!! That one hurts as a ford owner!!
  30. Dec 9, 2019 at 4:31 PM
    #240
    71_340
    71_340 The German
    Hans
    FLW, MO
    Pano roof - I like it on my Platinum as well as on my wife's MB SUV. It is a luxury feature not a requirement.
    Crash test - F-150 has 5 stars in every category except rollover which is 4 stars. Definitely a safer vehicle. I believe they use solid concrete walls for crash tests, I doubt a Tundra is tougher then that wall.
    Seats - unlike what somebody stated above, the KR, Platinum and Limited do have premium leather and massage seats standard on Platinum and Limited
    Different people look for different qualities in a truck. Most Tundra buyers (here anyways) like the "truck" feel and simplicity. I like the luxury features and refinement on my current truck and it can still out tow an optioned Tundra (not that I really care because I don't tow). I like the Tundra but they need to step up their game with the next generation and I will be more then happy to shell out an extra 10K or 15K to get a nice truck with quality high end materials and features. For you real truck guys there always will be the SR or SR5 Tundra (and they have a higher towing capacity to boot). IMO the SR and SR5 are excellent trucks in their segment, Platinum and 1794 are heavily outclassed and mediocre at best in their respective segment (as in luxury truck).
    B737 likes this.
