TRD Beadlocks
Discussion in '1st Gen Tundras (2000-2006)' started by notlikejohnny, Dec 6, 2019.
  1. Dec 6, 2019 at 2:32 PM
    notlikejohnny
    notlikejohnny [OP] New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Greetings all,
    New member, just posted in the new members section. Just bought a 2005 Double cab Limited. Will get pics posted soon.
    So what I have been trying to find out for several days, and can't seem to get an answer for is about the TRD Beadlock/FJ Baja wheels. Currently no lift and 265/65r17 stock tires and split spoke OEM 17" rims. I like the look of the rims and would keep them...but do not want to run spacers, and would like to minimize work to be done to fit 275 or 285s later on. So I am searching for rims that have the correct backspacing to work, and will sell the OEMs to offset the cost a bit.
    I found a great deal on a set of 5 TRD "Beadlocks" with BFG KO2 265/75/16 with under 2000 miles on them. However, from what I have (not) been able to find, is if they will clear the brake calipers. I believe without looking that I have the 13WL calipers since mine is a 2005 DC. I've seen an old post where the OP put them on his 2004 DC, but there is no information about backspacing or rub for larger tires.
    The seller measured and said it looks like they have 4.5" of backspacing which would be perfect from what I am reading here. Can anyone confirm this? If this is true will I be able to upgrade to 275 or 285 without rub? UCA or frame? Anyone have pics of the setup?
    Next plan is to put OME 2.5 coilovers in the front, and an ICON 3 leaf AAL and OME nitrochargers in the rear.
    Sorry for the long post. Thanks in advance and really happy to be here. I legitimately searched for this truck for over a year and finally got it. So stoked.
    EDIT: The wheels in reference: https://parts.toyota.com/p/Toyota__...oy-Wheels---Bronze/69529041/PTR1835090BR.html
    TundraDude18 and InTheRough like this.
  2. Dec 6, 2019 at 3:20 PM
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    I just bought a set of the 17" TRD Rock Warrior wheels (I believe this is what you are referring to) that have 285/70R17 tires on them. I plan to put them on a stock 2020 crewmax so it isn't directly relative to your inquiry but, if I can answer any questions about the dimensions, I will try.
    GODZILLA likes this.
  3. Dec 6, 2019 at 3:26 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    Which wheels do you mean?
  4. Dec 6, 2019 at 3:48 PM
    notlikejohnny
  5. Dec 6, 2019 at 3:51 PM
    notlikejohnny
    Thanks but no these aren't the ones. I attached which ones I am talking about. They would be a nice option if they fit the lug pattern the first gens have (6x5.5)
  6. Dec 6, 2019 at 3:52 PM
    InTheRough
    Kolt
    2020 Platinum
    Darkness likes this.
  7. Dec 6, 2019 at 3:52 PM
    speedtre
    speedtre New Member
    Inland Northwest
    They will fit...only Toyota 16 inch rims that won't are these 3rd from a 3rd Gen 4runner...but Ithink you can even make these fit with minor grinding to the caliper.
  8. Dec 6, 2019 at 3:56 PM
    notlikejohnny
    Are you able to confirm the backspacing of these? They're the exact ones I am talking about.
  9. Dec 6, 2019 at 4:09 PM
    InTheRough
    Kolt
    2020 Platinum
    It's a bit primitive but I got the measurement.
    Backspacing was a hair under 120mm (maybe 119mm?)
  10. Dec 6, 2019 at 4:16 PM
    notlikejohnny
    Thanks, looks like you are pretty much spot on per the online calculator I used with width and Toyota listed offset. Seems like I'll most likely have rub with anything over a 265. Hmm.
  11. Dec 6, 2019 at 7:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those are my favorite TRD wheel. They're around 4.75 backspace, 285 can fit with Camburg or TC UCA but not with stock arms. You will rub frame on 285.
    If you really want them just run 265/75 the difference is hardly noticeable in AT or MT. I've pulled up beside Tundras running 265/75 BFG and they look the same as my 285/75.
  12. Dec 7, 2019 at 6:12 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Went to stealer yesterday to pick up a washer I dropped from the backside of my manifold yesterday during my quest for vacuum greatness. The banjo fitting is just like the fuel rails where its easy to loose a washer and this time I did. Ended up at parts dept for a $2 washer and parked next to this 2019 4Runner?
    Anyhow, I believe things happen for a reason. While at stealer I scored on 3 ‘free’ 2020 calendars!
    Pulling out of parking lot, a guy being trailed by a cop accidentally? had his 6’ fiberglass HD ladder drop off the back of his van in the middle of the street right in front of me. Cop said it yours. It will be used nicely at Dereks Center.
  13. Dec 7, 2019 at 6:22 AM
    Fred
    Hand Protectors
    Here is a temporary washer I fabbed up from some old sckool brass washers sitting around. The soft metal is perfect, but the aluminum and brass will cause corrosion together.
  14. Dec 7, 2019 at 6:34 AM
  15. Dec 7, 2019 at 6:41 AM
    Fred
    Hand Protectors
    Thanks. Still working on my second Italian Roast.
  16. Dec 7, 2019 at 6:56 AM
    Rubberdown
    I have one of those wheels in my garage if you’re anywhere close you can borrow to test fit your setup.
  17. Dec 7, 2019 at 12:13 PM
    notlikejohnny
    Yea, I think I might just stick with 265/70 for the time being. The seller said he's willing to let me put one on to test it out before I buy, so I'll keep everyone posted afterwards.
  18. Dec 8, 2019 at 7:14 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    If I could find a fairly thin wheel spacers to convert my proper 6 lug pattern to the abomination that is the newer tundra 5 lug I'd really be considering those wheels. I could probably work it all together with a rear axle upgrade. Too bad the only wheel adapters I've seen were 2" thick and that would make my truck about 88-90" side. A bit excessive in my opinion.
    Then again I guess going to 5 on 5.5 would probably be better and then I could build a ford 9" to match!
  19. Dec 8, 2019 at 7:40 AM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    They do exist in 6 lug, I have a brand new set of 5. They're a now discontinued VIN locked item from Toyota and only came on super rare 4Runners.
  20. Dec 12, 2019 at 6:52 AM
    Spotted in the wild today on a Lexus GX470. I thought they had 6 lugs like us? Guess I was wrong.
  21. Dec 12, 2019 at 7:22 AM
    speedtre
    speedtre New Member
    Inland Northwest
  22. Dec 12, 2019 at 7:26 AM
    Bubbles
    Bubbles Decent!
    you sure it was a gx470 and not an LX?
    speedtre likes this.
  23. Dec 12, 2019 at 7:29 AM
    speedtre
    speedtre New Member
    Inland Northwest
    That would make sense too..
    GX/LX470s and GX460s are 6 lug
    LX570s (Along with LC200s) went to 5 lug with the 2nd Gen Tundras...
    Bubbles[QUOTED] likes this.
  24. Dec 12, 2019 at 7:33 AM
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    stt pro 285/75 17
    Darkness and EDDO like this.
  25. Dec 12, 2019 at 7:34 AM
    Fred
    Hand Protectors
    Darkness and bmf4069 like this.
  26. Dec 12, 2019 at 7:34 AM
    Actually, you're right. It was the LX. I just googled one and realized the front end is different.
  27. Dec 12, 2019 at 1:56 PM
    notlikejohnny
    Well, just an update, the seller sold them before I had a chance to meet up and try them out. The search continues for used wheels that have proper backspacing! A guy at work runs the exact ones I was looking at on his Taco, I asked him about them and he didn't have any issues with rub despite having 4.64 backspacing. Although he does run TC UCAs and did the CMC for his Taco.
    InTheRough likes this.
  28. Dec 12, 2019 at 2:20 PM
    InTheRough
    Kolt
    2020 Platinum
    Bummer. I hope you can find some suitable wheels.
    I won't be able to answer any more questions on these as I sold the set that I measured the backspacing on.
  29. Dec 12, 2019 at 3:11 PM
    notlikejohnny
    Well I appreciate you being able to get me the specs and help out others looking for the same info in the future.
  30. Dec 12, 2019 at 6:25 PM
    Hey! No 3rd gens allowed!
    Trailscape and Darkness like this.
