2020 Remote Start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jaypown, Dec 4, 2019.
  1. Dec 4, 2019 at 6:14 AM
    Jaypown
    Jaypown [OP] New Member
    Justin
    Rubber City
    Hey guys,
    2020 Tundra SR5 TRD Sport. I have the keyless entry and push button start. When using the remote start (either with keys or the app) the truck starts up, i walk to it and put my hand in the door handle as always to unlock and open the door and the truck shuts off. I then have to get in and restart it. I've asked a Toyota tech (family member) and he stated that's just how it works. Anyone figured out a work around yet?
    Thanks
  2. Dec 4, 2019 at 9:59 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Seems like majority of Toyota/Lexus vehicle with Push Start button will do this. There isn't a way around this, yet. I'm sure eventually someone will come up with a way. But for now that's how it is. Safety/Security thing with toyota/Lexus.
  3. Dec 4, 2019 at 10:01 AM
    Jaypown
    Justin
    Rubber City
    Ok thanks. It's definitely annoying though. It is what it is though.
  4. Dec 4, 2019 at 10:04 AM
    BrandonL812
    Brandon
    Yes it is. Although, my friend with a 2016 CM, key start, factory install remote start, also does this. Which I thought was very strange. His should not turn off when you open the door, like yours. I dont know what the dealer installed on his CM but I also feel the frustration. It is pretty annoying.
  5. Dec 4, 2019 at 10:06 AM
    Jaypown
    Justin
    Rubber City
    Yeah it's definitely something built in then. I had a 14 Tacoma before this and had an aftermarket remote start installed. I could get in the truck with it started that way, but if i put my foot on the brake and tried to put it into gear, it would shut off if the key wasnt in the ignition (pretty sure that's standard for remote starters though)
