Will you buy a dog training shock collar?
Discussion in 'Pets' started by tinnytinny, Dec 4, 2019.
  1. Dec 4, 2019 at 1:08 AM
    tinnytinny
    tinnytinny [OP] New Member
    sienna
    My dog likes barking at any time, we are so agonizing. I plan to buy a shock collar for my dog. Will it work for a barking dog? Will the collar hurt my dog? I hope it is a good training way. Seller send me the instruction, it seems it is easy to operate. But I want to ensure it is ok for a dog. Do you have any experience?78612850_132325571534787_679037565755457_90537bc4ebb356844b72f0e6e46eb42bab1d870c.jpg 78435456_132325521534792_410971470500462_e16693bfecf33f8ca6d565b58d86ff241ed4530c.jpg
  2. Dec 4, 2019 at 1:37 AM
    grannynancy
    grannynancy New Member
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    A bark collar is a better option than a hand controlled *shock* collar. It is very hard to manually control the timing for the bark. Make sure you don't leave it on too long and set the level as low as possible to start and see what is effective. The collars must be snug to be effective. Petsafe makes some good inexpensive models.
    Kerch71 and tinnytinny[OP] like this.
  3. Dec 4, 2019 at 2:10 AM
    usmchawk
    usmchawk New Member
    Jack
    Maryland
    2018 Tundra Double Cab Limited TRD Off Road - Super White
    TRD Rear Sway Bar Red Interior LEDs Console Safe Victory Rock Sliders Pop n Lock BakFlip4 Bed Mat Led reverse lights Fumoto valve
    We used a bark collar BUT we were outside with the dogs whenever they had it on. It only took a couple of times for them to understand that bark equaled tingle. Problem was fixed within a day. Now our English Cream Retreiver is looking for ways to get under our fence, although she doesn't run, it's like a game to her. We bought a remote control "shock" collar. The "shock" can be controlled from 0-100. I set it to 25 and put it on my hand - a slight tingle. Then set it to 35 and the tingle was a bit more. Both my wife and youngest daughter (12) were concerned, so I had them hold the pins in their palm and "shocked" them. They both agreed it was startling, but it was only a tingle. Whenever I need to tingle the dog, it has a two beep option. I do that first and if she doesn't move away from the fence she gets the tingle. She doesn't' cry, just jumps and gets away from the fence. This took longer to train than the bark collar, but only 3-days and now she doesn't go near the fence.
    SomeGuy4 and GODZILLA like this.
  4. Dec 4, 2019 at 2:28 AM
    We bought one that's controlled by phone, my wife's youngest has a dog that barks at the back neighbor's dogs when they come out, and she's tearing up the yard, few tingles and she doesn't go by the fence anyone
  5. Dec 4, 2019 at 2:41 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Trained my lab with one.
    Only had to shock her twice. Now I put the collar on her and she is a good girl knowing it could happen if she disobeys.
    Her problem was running and not coming when called.
    She barks but she has a strong prey drive and is over protective.
    I am ok with that
    The one I got works from 3000 feet or more, has a setting for bark mode as well as tone, constant shock, momentary shock and 16 different levels.
    SomeGuy4 and tinnytinny[OP] like this.
  6. Dec 4, 2019 at 5:10 AM
    TS18
    TS18 Northern CO
    2018 sport
    We use a citronella spray collar on our great pyre mix. Put it on her before work and she no longer barks at the neighbors outside during the day. Take it off in the afternoon and we correct her barking verbally. She’s a barker for life but not w the collar on.
  7. Dec 4, 2019 at 5:23 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I had a great experience using a e-collar, and private lessons with a dog trainer. I think the new e-collars are so much better than the old shock collars. My dog got annoyed at such a low setting that I could not feel it with my bare hand. Good luck!
  8. Dec 4, 2019 at 5:32 AM
    War Machine
    War Machine SSEM # 5 3MW
    The little ones are always the worst. Oddball thinks he’s a total badass.
  9. Dec 4, 2019 at 5:52 AM
    Max n Gemma not bad with dogs n back, but they know when mail man comes by
  10. Dec 4, 2019 at 6:44 AM
    coTony
    Tony
    Montrose, CO
    I paid to have my dog trained and the bulk of the training is the "shock" collar. The term "shock" is taken out of context because automatically everyone thinks the dog gets shocked by massive electricity and that is NOT the case.
    When you press the button the collar will have a very low voltage arc between the terminals of the collar which interrupts the dogs thought process and snaps them out of the thought pattern they were in when you initiated the shock. You can put your fingers on the 2 terminals and press the button. Mine goes from a setting of 0 (no shock) to 100 all in increments of 1 so a vast range for various dogs. If you have a Mastiff dog you may need much more than for a Dachshund.
    My collars also have a vibrate and ring modes on them which all are great for varying situations.
  11. Dec 4, 2019 at 6:46 AM
    War Machine
    Oddball wants to murder anything he notices outside. Whenever someone’s headlights hit our window he starts growling. Took a while to get him to stop going after all the deer when I had him outside.
  12. Dec 4, 2019 at 7:00 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Used a shock collar on my Vizsla. Worked great.
  13. Dec 4, 2019 at 10:16 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I use one I got off of Amazon for my Aussie. I can either beep, vibrate or shock him. There's levels of 1-100 for both vibrate and shock. I've had it for two years and I can count on two hands how many times I've actually had to use the shock. For barking, I use the beep mostly and it's enough to correct him. Dogs are smart and if they get buzzed or shocked after each bark, they'll learn that barking causes something they don't like.
    If your dog is just randomly barking for no reason, then it could be anxiety or acting out if he/she isn't getting enough exercise. If that's the case, a bark collar will be better. If your dog is barking at specific things, even if at everything, then a shock collar will work with a remote. As long as you get one that you can adjust the levels, it wont hurt your dog. Just start low on settings and work your way up as needed until you can effectively correct the behavior that you don't like.
    coTony likes this.
  14. Dec 4, 2019 at 7:06 PM
    tinnytinny
    sienna
    Thank you!
    Jaypown[QUOTED] likes this.
  15. Dec 4, 2019 at 7:07 PM
    tinnytinny
    sienna
    Thank you!
  16. Dec 4, 2019 at 7:15 PM
    dv8TRDPRO
    dv8TRDPRO NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    We have used these for training and have had good success. Our two pups now look forward to the collars because they know they are about to either take a trip or we are going to train. We also put them on when we have visitors to help keep them calm. My wife and I both wore the devices on our arms to feel the sensation to make sure we were okay with it first.
    https://www.educatorcollars.com/?gc...CaXd74a9ivoG-4GC5NsFxxD7cAlrH0NQaAvS-EALw_wcB
  17. Dec 4, 2019 at 7:17 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    We had one, our husky would constantly bite our cat and finally drew blood. Only had to shock once, then the beep preceding the shock did the trick. After a few days of beeping, the cat was left alone. Our dog must have thought the cat was magical.
    Then my wife would put it on me... oops, wrong forum.
  18. Dec 4, 2019 at 7:18 PM
    dv8TRDPRO
    Chattanooga
    @JoshuaA
    "Then my wife would put it on me... oops, wrong forum.[/QUOTE]
    LMAO!!
  19. Dec 4, 2019 at 7:47 PM
    tinnytinny
    sienna
    I bought a training collar for my boy just know. Thanks for your useful sharing and information, thank you all guys.
    I so expect for the product, and can't wait to get it now. I hope it helps:)
    https://www.imeshbean.com/product/2...erproof-electric-shock-lcd-anti-bark-856.html
  20. Dec 4, 2019 at 7:50 PM
    tinnytinny
    sienna
    :laugh::laugh::laugh:
  21. Dec 4, 2019 at 10:22 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    A training collar is a great tool, but success with it depends on timing and consistency on part of the trainer. You can get great results, especially working with a dog in the field, but it takes a lot of work just like any training. It’s not a quick fix.
    Bark collars are a little easier, being automatic/voice activated.
    I hope you get the results you’re going for.
    tinnytinny[OP] and grannynancy like this.
  22. Dec 5, 2019 at 4:45 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    that’s the exact collar that we have for our German Shepard. It was recommended by the trainer we had. She’s a great dog but gets stupid happy excited like a five year old with ADD after eating a bucket of sugar. She still has a lot of puppy in her. We call if her “gotta be good collar”.
    She’s to the the point now that saying “do you want your gotta be good collar?” Will typically calm her down. And if we do put it on her (like when new people are coming over), just hitting the vibrate button is enough to get her back into her well trained mode.
  23. Dec 5, 2019 at 5:47 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Now she thinks you're magical :anonymous:
    JoshuaA[QUOTED] likes this.
  24. Dec 5, 2019 at 10:46 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Spoiler alert, it’s metaphorical we don’t own any pets
  25. Dec 5, 2019 at 11:01 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Seriously speaking, I tried it on my hand first at the lower levels, it’s one hell of a shock. Funny on the package it’s a husky, buddies after employing the collar:
    She’s passed on, lived a full life with our loving family.
  26. Dec 5, 2019 at 11:14 AM
    Skinnywater
    Skinnywater New Member
    2016’ Tundra TRD 4x4
    Use one. Love it. Like stated earlier they know when their wearing collar. Voice, beep, shock! Rarely get past beeping. Broken coat Jack Russell
  27. Dec 5, 2019 at 11:43 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Had one for my mastiff with the perimeter fence, she would go lay on the fence so she could feel it. Very hard headed dog.
    831Tun likes this.
  28. Dec 5, 2019 at 11:51 AM
    I use a training collar for my German Shepherd. He is a GD angel when wearing and only needed to use the shocker a few times.
    When in public, the trainer and choker is a necessity due to how aggressive he can be towards other dogs.
  29. Dec 5, 2019 at 11:54 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    We have shock collars on 2 dogs. The property is too big/ expensive to fence completely. But a single wire around the property and shock collars works really well. I've tried to get my neighbors to use a bark collar on their effin obnoxious dog but they/she thinks it's cruel. Much better to annoy and disturb humans than to control her POS dog.
    tinnytinny[OP] and 15whtrd like this.
  30. Dec 5, 2019 at 11:57 AM
    Mr_Lahey
    Mr_Lahey New Member
    SE Idaho
    2016 TRD Double Cab (Black of course)
    Once you go black you never go back.
