Truck only shifting into 2 gears
Discussion in '1st Gen Tundras (2000-2006)' started by garyo, Nov 12, 2019.
  1. Nov 12, 2019 at 1:19 AM
    garyo
    garyo [OP] New Member
    Hi,
    Got a problem with my truck and my mechanics can't find what is it.
    When i start the car, it display i'm always on reverse position (and backlight always on).
    My truck shift normally in all position but, when i'm on "D"drive the truck just shift in 1 and 2 gear (probably cause it said he is on reverse).
    If i take off the gauge fuse, the truck behave normally but i lost all dashboard display and after a moment running in drive the car battery drain.
    Please help me to find what it could be.
    it's not very nice to have a car who just can run in 2 gear !
    (sorry for my english , i'm a french canadian)
  2. Nov 12, 2019 at 4:24 AM
    bmf4069 Captain wtf
    Yeah, it sounds like you're 1 lower than what it shows. But the truck wont start if it's in gear which is weird. Sounds like your shifter is fubar somewhere.
    Darkness and speedtre like this.
  3. Nov 12, 2019 at 11:03 AM
    garyo
    OR18TRD :
    Around 128500 Miles
    2002
    V8 4.7L
    The vehicule Shift all the position right. Park is Ok, Neutral is Ok, Reverse is Ok but light stay on (in dashboard and back light too).
    So i can be in Drive position, drive my car but dont shift in 3 and 4
    Same thing when i put it in 1 and 2.
    Thanks for your fast reply.
    BMF4069 : How can i verify if its really a shifter problem ?
  4. Nov 12, 2019 at 11:11 AM
    Thesandaddict
    Thesandaddict The dude
    Harley
    2010 DC
    Bilsteins, methods
    Shift actuator?
    OR18TRD likes this.
  5. Nov 12, 2019 at 12:14 PM
    garyo
    Cant go at 60mph its too high . 35-40 is maximum without being over 5000 rpm.
  6. Dec 3, 2019 at 4:11 AM
    garyo
    I post this message in case there is someone else who has a similar disorder.
    My problem has been solved. Water had infiltrated behind my dashboard. There was a short circuit and the reverse wire burned with the electrical wire of the buttons to raise the window on the driver's side.
    This thread is located approximately above the left foot.
    Thanks for your help.
  7. Dec 3, 2019 at 4:23 AM
    bmf4069 Captain wtf
    Wow. How did you end up finding that?
  8. Dec 3, 2019 at 5:12 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Thank you for the follow up.
    Seems this drivers side leak issue pops its head up here every so often. Last member had to replace his entire interior fuse box from a long time leak which corroded the device.
    Have you addressed the leak issue? My theory is if its not coming from the glass its coming from the pillars. Here is a pic of the pass side clips where the rubber gasket deteriorated. You access by pulling the rubber trim back gently. I found this out when having my bad glass (due to sand blasting) installed by a pro.
    Check out my build page for more tips.
