Tow Package Rear End Question
Discussion in '2nd Gen Tundras (2007-2013)' started by focal, Nov 25, 2019.
  1. Nov 25, 2019 at 3:17 PM
    focal
    focal [OP] and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    So, I keep reading this reference of the 4.10 being standard and the 4.30 for those with the tow package.
    I’ve pulled the VIN through the Toyota Vehicle Specifications page and it indicates the vehicle has the tow package AND 4.10 rear end.
    What say you? Is there a chance some have the 4.10 or could that field just list the standard without consideration of the package?
    “TO Tow Package-Factory”
    “Mechanical & Performance
    5.7L DOHC 32V i-FORCE V8 with Dual Independent VVT-i 381HP/401 lb-ft 6-Spd Automatic Trans w/Sequential Shift 4WDemand: Part-time 4x4 Sys w/ 2-speed Electronically Controlled Transfer Case TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed 4.10 Rear Differential w/10.5" Ring Gear Automatic Limited-Slip Differential Front Ind Coil-Spring High-Mounted Double Wishbone Susp w/Stabilizer Bar Trapezoidal Multi-Leaf Rear Suspension & Staggered Outboard Mounted Shocks Power-Assisted 4 Wheel Disc Brakes 18" Steel Wheels w/ P255/70R18 Tires”
    For what it is worth, the above also states it has 18” wheels but it has the Rock Warrior package with 17’s. May have answered my own question there.
    Thanks in advance.
    08crewmax likes this.
  2. Dec 2, 2019 at 5:17 AM
    focal
    Nikolai
    VA / NC
    Thanks for the reply. I do have the tow/haul button and trans temp gauge.
  3. Dec 2, 2019 at 7:15 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Isn't it a max tow pkg gets you the 4:30's ? That's how it is in my 1794 (2019)
    focal[OP] likes this.
  4. Dec 2, 2019 at 9:16 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    Interesting. My 2013 Rock Warrior comes up with the same build info as your's does. BTW the Rock Warrior and Tow Packages are listed as Factory Installations and not Port or Dealer.
    focal[QUOTED][OP] likes this.
  5. Dec 4, 2019 at 6:45 AM
    focal
    Nikolai
    VA / NC
    I’m starting to think the same thing. Thanks for the reply.
  6. Dec 4, 2019 at 7:23 AM
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    I thought I saw the TRD pro has 4.10 gears too?
  7. Dec 4, 2019 at 8:29 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    That would be strange, as they came with a slightly larger tire out of the gate - no? 32" vs a 33"
  8. Dec 4, 2019 at 9:05 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    So as I stated above, I thought a RW came with 33s not 32s.
    2013 Tundra stock tire size options.
    Using a generic tire size calculator...
    285/70/17 - RW - 32.71x11.22
    255/70/18 - 32.06x10.04
    275/65/18 - 32.07x10.83
    275/55/20 - 31.91x10.83
    So, as my previous comment stated with regards to tire size and not wheel size...
    I find it strange, that with a larger tire they would put 4.10s w/tow package and not keep it geared at the 4.30s.
  9. Dec 4, 2019 at 9:30 AM
    15whtrd
    15whtrd Mr. Blonde
    I thought only the 4.6 L non tow package got the 4.10 gears.And I also thought the 4.6 L had a different rear end all together. Although I didn’t pay too close of attention.
  10. Dec 4, 2019 at 9:31 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Really not sure where this conversation is going lol
    Larger diameter, gearing altered
    I believe they came with BFG LT KOs, heavier tire, more rotating mass
    Marketed as an "offroad" style upgrade, wouldn't 4.30 be a better gearing for this, more low end grunt and better pickup
    4.30 would be geared more favorable to this.
  11. Dec 4, 2019 at 9:34 AM
    Azblue
    The Dirty T ( ^_^)_且
    Since 2014 all 5.7s came standard with the tow package and 4.3. I believe only 4.6s get 4.1.
    Options were different from 07-13 and I believe that the tow package was optional at the time.
    15whtrd likes this.
  12. Dec 4, 2019 at 9:41 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    We agree there, ain't much but between a P and LT load range D there is probably about 20+lbs of additional unsprung/rotational weight added!
    I regeared my 08 4-banger Taco and it did great...until a made another jump in tire size lol
    I'm sniffing around going gear again to this pig. Just saving up that $.
  13. Dec 4, 2019 at 9:57 AM
    radon222
    Ed
    NW Arkansas
    Stock for now
    The RW BFG's are actually E rated. But still just a little more weight. For me personally and my everyday use 4.10's are fine. But I do find it humorous that ROCK Warrior got 4.10's. :facepalm:
