How do you carry your kayaks?
Discussion in 'Towing & Hauling' started by Conflicted, Jul 20, 2019.
  1. Oct 15, 2019 at 4:46 PM
    Conflicted
    Conflicted [OP] New Member
    Buffalo-ish, New York
    2019 Crewmax SR5 TRD Off Road
    I keep it really clean!
    Bed extender won't work for me because I can already throw 3 or 4 kayaks in the back of my truck without it, and I'm trying to keep them out of the bed so I can still have it free to pack all my camping and adventure gear
  2. Nov 25, 2019 at 2:50 AM
    grannynancy
    grannynancy New Member
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    I did a ton of research and we even loaded our 85# 14 foot kayaks on the roof before ditching our old mid rise leer 180 camper shell (about the same height as a rack). I am very excited about having an open bed.
    Decided to buy Yakima Overhaul HD for the bed. When we looked into roof carry the snags we hit were load capacity of about 165# on a DC and the challenges of loading onto the roof rack located on the roof rather than loading from behind (which is very easy even with two old folks) . The various load assists are for kayaks under 75-80#, add weight, and are very pricey. The yakima has a load rating of 500# while driving, 800# static, and 300# for offroad. You can get standard contractor ladder racks for about the same price as the yakima but I like being able to remove the rack, the rack looks great, it can take accessories, and the standard ladder racks are too narrow to carry 31" wide kayaks flat. We can also climb into the bed to manage straps.
    The other issue I had with the roof was the span would max out at 32" on those bars. Once again...and down the road we hope to get 16' surf skis. (lighter but longer). I know you can carry long kayaks with that kind of span but I don't like the idea.
    Decided on the yakima over the thule (I really preferred that sliding thule mounting system) for TWO reasons. (1) The height of the yakima can be infinitely adjusted so if we decide we want to center the kayak over the truck (it seems the center point is actually right between the bed and the cab for my truck), the roof can carry some of the weight as we can line up all the bars, using the back bar for loading and as a tail anchor. (2) the Thule HD system can accept a very limited number of cradles. I have made peace with the kayaks hanging over the back of the truck because they already hang off the ends of the trailer we have been using. So we will see. The Thule does offer an overhang for the cab but I thought that was very ugly. Granny does like aesthetics. :). It was a tough call. FWIW Thule says you need to remove the bed rail tracks for mounting as it uses the stake pockets and Yakima has adapters for the rail. We are relocating the rail anyway to our wooden deck drawers but that could make a difference for someone. My experience with the topper was that the clamps for the topper shell limited the utility of the rail system and knew mouting the yakima to them would do the same thing. EDIT. I am actually looking into mounting D rings into the holes left behind after uninstalling the bed rail system. Anyone ever done that?
    Plan to make some PVC bunks like we use on the trailer. I am working on ways to attach via the t-slots so we can remove them when not in use. It is easier to load upright than upside down for some reason and those bunks really support the hull of a plastic SOT kayak nicely (they run in the channel where the scupper holes are) and are great at preventing lateral movement - and we have the option of standard carriers with other kayaks. Also looking into either the Rhino t-loader or some other roller system. The yakima rollers are 75# limit and only 24" wide each.
    Trailers ARE great when you have access to a parking lot with adequate parking but a lot of great places to launch kayaks have no ramp and no trailer parking. They can also be a bit scary when you are driving down a narrow dirt road with deep ditches and that road is carrying two way traffic or are on twisty mountain roads.
    The rack should be here in about a week. We will first see about loading on gunnels as that means all we need are load stops and I will try to figure out how to do pictures on this forum.
    splitfuse and Mater like this.
  3. Nov 25, 2019 at 3:28 AM
    grannynancy
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    Skew12 likes this.
  4. Nov 25, 2019 at 4:23 AM
    18" TRD Off Road Wheels
    I started looking into some of these bed racks for kayaks, as it is something I want to get into next summer. Holy CRAP!:eek: These things are effing expensive. Definitely need to be shopping for deals on these.
    BravoDeltaRomeo likes this.
  5. Nov 25, 2019 at 5:30 AM
    Snoman181
    Snoman181 New Member
    Reg
    Ottawa, Ontario
    2017 Toyota Tundra
    I have a pair of 16' sea kayaks that go on top regularly. I didn't like the idea of a semi-permanent bed rack because of what it does to fuel mileage. So my solution is a single Yakima roof rack near the back half of my CM cab and a Yakima rack that attaches to the trailer hitch and rises up the the same height as the roof rack. Takes seconds to remove the rack when I'm not carrying the kayaks.
    The only problem is that I can't open the tailgate with the rear part of the rack in the trailer hitch, but that turns out to be just a minor inconvenience.
    Kayaks are packed up for winter already, but I can snap some pics of the rack if you like.
    BravoDeltaRomeo and GODZILLA like this.
  6. Nov 25, 2019 at 5:56 PM
    I appreciate it, but I'm trying to avoid anything on the roof of the truck. I'll just pinch pennies and go with a bed rack eventually. They pop out easy enough from everything I've seen.
  7. Nov 26, 2019 at 7:08 AM
    Conflicted
    The problem I'm having is finding an affordable solution with the combination of a bed rack and a tonneau cover. When I'm hauling my kayaks it's usually because of a camping trip lasting at least a weekend which means that all my camping gear is in the bed of the truck. That requires a tonneau to keep all my gear dry and out of sight. This is the reason I'm leaning more towards a roof rack system because finding a compatible tonneau and bed rack system is way out of my price range.
  8. Dec 1, 2019 at 4:15 PM
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    I have not looked into these very much. I Looked into roof racks for a truck cap but the weight rating on those is not very large and by the time I add the racking and boats, I am too heavy. I wonder how much weight they can hold on top of our trucks? I have two 12’ foot kayaks And need a way to haul them when towing our camper.
  9. Dec 1, 2019 at 4:26 PM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    1CA1C098-8C9B-4763-A9E4-BFE5F346BC99.jpg Picked up a Wilderness Systems Radar 115 this weekend. I wouldn’t be comfortable carrying it far the way I did in my CM. It wasn’t well supported by the tailgate because I have a bed mat. The bed mat is thick enough that the kayak wanted to rock up and down. Only about half of the kayak was supported
    I think the bed extender is a must for a 12 foot kayak in a CM
    Wallygator likes this.
  10. Dec 1, 2019 at 4:30 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
  11. Dec 1, 2019 at 4:46 PM
    spyshot
    Ohio
    Anybody know what the weight limit is on a 2019 crewmax Roof?
  12. Dec 2, 2019 at 5:00 AM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Pretty sure my setup is rated for 150# which would be more than enough for your two 12' kayak's.
  13. Dec 2, 2019 at 6:15 AM
    spyshot
    Ohio
    84lbs each. Plus I need to add the weight of the racking and holders.
  14. Dec 2, 2019 at 7:28 AM
    MrMax
    Rob
    Eastern Iowa, USA
    Damn...those are heavy. Not sure I would want to be trying to toss those up on the roof by myself anyway, and my assistant...5'2" 112# isnt much help either :) My 12.5' Tsunami is 51# and bulky enough by myself.
  15. Dec 2, 2019 at 8:28 AM
    spyshot
    Ohio
    I have a truck cap. I’m thinking maybe put one crossbar on the truck cap and one on the cab to distribute the weight.
  16. Jan 8, 2020 at 6:18 PM
    cosgrc
    cosgrc New Member
    Alabama
    2020 Super White Platinum CrewMax 4x4
    I added yakima rails and mounts on an old jet-ski trailer I converted. Works out really well!
    AC233DB1-2BEB-496C-8D4F-732B9615A7F4.jpg 3A79C755-918C-451E-9B7B-D2F17A75B8D4.jpg 8984B720-2107-4783-A83E-B55F7CA6564E.jpg
  17. Mar 30, 2020 at 10:44 AM
    Soooooo, does anyone know of anywhere that is running discounts or sales on bed racks and the like? I'm using google, but if somebody has a known source, that would be great.
  18. Mar 30, 2020 at 12:35 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    So my fishing buddy's and I have been ditching our kayaks for 10ft Jon Boats. It packs better in my truck then a kayak. It can go in just as shallow water as my kayak could. But I can also have my 55lb thrust electric motor and carry more gear. One of my friends even got a suzuki 6hp motor for he's. He is pushing 25 mph on that little Jon boat. Not to mention two people can stand and fish from it. The boat is only 87 lb so loading it is a breeze. I made a side lift, low profile and lightweight rack out of Unistrut. With the boat on the rack it sets just below he roof of the cab. So mpg is not affected. I used two 150 lb gas struts to assist in lifting. This allows me full access to my truck bed. Plus if I flip the boat upright I can also packet gear in it. There is also enough room under the boat that I can get a second 10 foot Jon Boat in the bed underneath it.20191028_172952.jpg 20200211_163322.jpg 2020-02-17 15.47.07.jpg 20191129_145642.jpg 20191129_092212.jpg 20191215_093727.jpg20191215_080823.jpg
    DZ_, mayan, jhardy1979 and 15 others like this.
  19. Mar 30, 2020 at 12:39 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    That's a pretty sweet setup!!!!!!!!! Makes me wanna do something similar
    Brown Bear[QUOTED] and GODZILLA like this.
  20. Apr 21, 2020 at 1:40 PM
    #50
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    This is what I pull behind my Tundra for kayaking and camping trips. Unfortunately I don't have any better pictures of it all loaded up with our kayaks or canoe. I have a large family and own six kayaks, all Wilderness System Pungo's, 3 - 12' and 3 - 14 footers. Also, a 15' old town canoe so I need lots of carrying capability. Works great and we love it. Keeps my bed free for carrying all the camping gear and stuff.
  21. May 19, 2020 at 10:41 PM
    #51
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
  22. May 20, 2020 at 5:11 AM
    #52
    YES! This is the kind of set up I am looking for. Would you mind sharing details on it? The big thing I'm trying to avoid is drilling holes in my truck, so I've been looking for rack systems like this that can mount to existing holes or to the bed rail system.
    BravoDeltaRomeo and rons23 like this.
  23. May 20, 2020 at 6:35 AM
    #53
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Sub’d
    GODZILLA likes this.
  24. May 20, 2020 at 10:00 PM
    #54
    SpooledReel
    RickyP
    Spanish Fort, AL
  25. May 20, 2020 at 10:02 PM
    #55
    SpooledReel
    RickyP
    Spanish Fort, AL
    That is one seriously clean garage
    Wallygator, Outbound and GODZILLA like this.
  26. May 21, 2020 at 3:54 AM
    #56
    gdiep
    Syracuse, New York
    jewild likes this.
  27. May 21, 2020 at 6:37 AM
    #57
  28. May 21, 2020 at 6:46 AM
    #58
    hmm. For whatever reason it says it won't fit a 2019 Tundra. Pretty sure if it fits your 2015 it'll fit everything after it, because nothing has changed on the Tundra since 2014, right?
  29. May 21, 2020 at 6:50 AM
    #59
    It doesn't look like it. It is attached to the rail system in the bed of the truck, and that would block any cover.
  30. May 21, 2020 at 8:19 AM
    #60
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    This would be a good use of the Retraxpro XR that I am looking at.
