New member, new problem, not an expert
Discussion in '2nd Gen Tundras (2007-2013)' started by dmr, Dec 1, 2019.
  1. Dec 1, 2019 at 8:18 AM
    dmr
    dmr [OP] New Member
    Dave
    2007 Toyota Tundra DoubleCab Limited
    Hi there,
    I have an 07 Tundra DoubleCab Limited w/ 127k miles and an electrical problem(s) that maybe are related?
    My cigarette lighter USP adapter cannot charge my phone as the voltage constantly fluctuates. Purely coincidentally, I recently searched for a relay that doesn’t exist under my dash and can hear something shorting in an assembly above the parking break. Does anyone know if the lighter wire passes through this area? If not, any thoughts about troubleshooting these two issues?
    Many thanks.
    Dave
    YardBird, Prostar 190 and OR18TRD like this.
  2. Dec 1, 2019 at 8:24 AM
    Welcome from NY.
    Hopefully someone will chime in with the answer.
  3. Dec 1, 2019 at 8:34 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Based on my experience in toyota cigarette lighter. They have a built in fuseable link. My speculation id that the link is broken but still making contact due to expansion and contraction of the material.
    Pull the socket out and check the current. As for the sound above the pedals, I do not know.
  4. Dec 1, 2019 at 9:14 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Calif
  5. Dec 1, 2019 at 9:26 AM
    dmr
    dmr [OP] New Member
    Dave
    Thanks y’all!
  6. Dec 1, 2019 at 10:32 AM
    Welcome from Ohio.
  7. Dec 1, 2019 at 10:34 AM
    Welcome from CO.
  8. Dec 1, 2019 at 10:37 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  9. Dec 1, 2019 at 10:38 AM
    Sundown5oh
    Sundown5oh New Member
    2008 SR5
    First have you tried using another charger?
  10. Dec 1, 2019 at 10:42 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  11. Dec 1, 2019 at 10:45 AM
    dmr
    dmr [OP] New Member
    Dave
    Yes, multiple. My latest USB connector has a power indicator light and it basically flickers indicating inconsistent power supply. I’m just not sure what’s between the fuse and the cig.
  12. Dec 1, 2019 at 10:49 AM
    dmr
    dmr [OP] New Member
    Dave
    Thanks for sharing your truck photos. I’m embarrassed to post mine because everything is stock right now. Just began the journey of modifying my headlights to LED. I don’t have projector beams so I’m like a neutron star coming at other drivers. New projector headlight housings arrives this Friday, hopefully won’t blind others once installed. . Broke two attachment posts for the trim under the headlights trying to install the LED bulbs. Learning the hard way.
  13. Dec 1, 2019 at 10:52 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    You're going to need to pull the receptacle out and check. I think this is a common issue from that era. Wife's 2006 RX has the same problem but there is another she uses instead. Probably on the same circuit so guessing it's the receptacle.
    dmr[OP] likes this.
