Gas tank size
Discussion in 'General Tundra Discussion' started by Georgearama, Nov 29, 2019.
  1. Nov 29, 2019 at 9:28 AM
    Georgearama
    Georgearama [OP] New Member
    Georgearama
    2019 Toyota Tundra
    None
    When my 2019 Tundra displays that I have 5 miles before I run out of gas and I fill it up, I can barely get 31 gallons of gas in it. My sticker says that I have a 38 gallon tank. I called the dealer I bought my Tundra (Toyota of Oak Brook in Westmont) and talked to the service department and the guy told me there is not a reserve on the tank. I can’t imagine what size gas tank Toyota actually put in the Tundra that I bought in June of 2019.
    OR18TRD likes this.
  2. Nov 29, 2019 at 9:30 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    It's all there. 6 gallons is used to keep the fuel pump submerged. It will register empty at 32. But you do have 6 gallons left.
    Buildn, Trooper2 and OR18TRD like this.
  3. Nov 29, 2019 at 9:53 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  4. Nov 29, 2019 at 9:56 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
    jewsNbrews and OR18TRD like this.
  5. Nov 29, 2019 at 10:26 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It’s because the bad fuel tank design, that fuel tank is so long it takes 6 gallons for the fuel pump to work safely.
    jewsNbrews likes this.
  6. Nov 29, 2019 at 11:04 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I don’t believe this topic has come up before
  7. Nov 29, 2019 at 11:04 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    TXMiamiFan[QUOTED] likes this.
