  1. Nov 27, 2019 at 5:08 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Too bad about the night vision. That set up looked clean. You could always rig up some leds to turn on in reverse. It's super easy to do.
  2. Nov 27, 2019 at 5:14 AM
    Zjohn14
    Zjohn14 New Member
    Zachery
    2006 Tundra Limited Crew
    4" lift, 20" bead locks, 305/85 General Grabber A2, Bilstein shocks, 2" wheel spacers, nerf bars/step rails, bull bar w/ 11.5" led lightbar, replaced oem fog lights with LED cube lights, custom grill, tinted w/s, cold air intake, flow master Exhaust, rear brakes converted to disc, ARE hard shell bed cover, weather tech floor mats, pioneer touchscreen w/rear cam, bed has rhino liner & also under coated frame.
  3. Nov 27, 2019 at 7:22 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Getting ready to drive it in the rain :crapstorm:
  4. Nov 27, 2019 at 10:01 AM
    Professional Hand Model
    Fred
    Hand Protectors
    She got a brake fluid suck in fill and a pat on the butt.
    bmf4069, Darkness and FrenchToasty like this.
  5. Nov 27, 2019 at 11:55 AM
    Zjohn14
    Zjohn14 New Member
    Zachery
    Well got the ko2's in 305/65-17 put. Less rubbing than I was getting on the 285/70 grabber. They measure 32.5" tall 12.4" wide. Just need to clean her up an get bull bar an light bar installed this weekend!
  6. Nov 27, 2019 at 1:04 PM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    OCD continues to kick in while I “refresh” it. Living by a Toyota parts department helps, $10 high mount lens to replace the yellowing original.
    Bilstein’s should be in today, hopefully on next week sometime.
  7. Nov 27, 2019 at 2:47 PM
    This squeaky brake pedal has become very annoying. I just blasted some silicone spray on the parts that appear to move but I really have no idea what part is capable of making this noise. Will report back of this worked once I drive it again.
    bmf4069 and TX-TRD1stGEN like this.
  8. Nov 27, 2019 at 3:05 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    So I know this is an issue on old Tacoma clutch pedals. Iirc it's a spring that's worn out that squeeks.
  9. Nov 27, 2019 at 3:13 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Squeezed in one more item on the checklist, cleaned up the engine bay. Gunk Foamy and Shine did the trick, $10 at Autozone.
  10. Nov 27, 2019 at 3:13 PM
    I did see a big black spring attached to the pedal and sprayed it. Seems unlikely that it could make noise like this though. :notsure:
  11. Nov 27, 2019 at 3:16 PM
    I'm an anal SOB when it comes to this. Hate dirty engine bays. That looks so much better.
    Looks like that brake fluid is due next. :thumbsup:
    bmf4069, NUDRAT, BubbaW and 1 other person like this.
  12. Nov 27, 2019 at 3:51 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Along with a lot of other items :facepalm:Hoping to slowly get this thing to near new condition and keep it for as long as she’ll go.
  13. Nov 27, 2019 at 4:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    looks like youve got a good start
  14. Nov 27, 2019 at 5:20 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    i appreciate your attention to detail; glad i'm not alone here!!
  15. Nov 27, 2019 at 8:36 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    This is what I’m currently doing. The dynomat and foam is a great idea. Are you changing colors on the headliner at all? How long did they say for reupholstering? Seems like it should be cheap and easy. Thanks
  16. Nov 27, 2019 at 8:41 PM
    empty_lord
    05 rollover special
    It’s just a day thing for the reupholstering, same color,
    Volt92[QUOTED] likes this.
  17. Nov 27, 2019 at 9:31 PM
    empty_lord
    05 rollover special
    well finding a used fuse box/main body harness is turning into a nightmare... cant find any NON DRL 05-06 v8 trucks with tow packages... damn.
    lsaami likes this.
  18. Nov 28, 2019 at 5:37 AM
    Despite not having any cutting tools I'm going to find a way to cut this plastic tomorrow. Tired of my tires rubbing them in reverse. I'm assuming this plastic originally had some hardware that kept it tucked behind the bumper but not anymore.
    Darkness likes this.
  19. Nov 28, 2019 at 6:01 AM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    I spent some time last Saturday doing the exact same thing on my 03. I was able to trim the liner behind the fogs using some scissors. I trimmed up to the only remaining liner mount that sits above the fluid tank. I used my grinder to trim up the thicker bumper plastic at the bottom corners. No rubbing now with the 285/75/16. Not sure why I even took the time as I'm going to rip off that 03 front end and replace it with the 02 grille and steel bumper setup I just got delivered. Haha! Practice I guess.
    speedtre and FirstGenVol[QUOTED] like this.
  20. Nov 28, 2019 at 8:17 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Knife
  21. Nov 28, 2019 at 8:31 AM
    Fred
    Hand Protectors
    Happy Thanksgiving everyone. Thankful for my nice Tundra, the tools to work on it, and new parts, etc.
    hammeron, NUDRAT, bmf4069 and 7 others like this.
  22. Nov 28, 2019 at 8:41 AM
    KarmaKannon
    Utah
    Some junk
    I'll second that.I just got my poly steering rack bushings!
  23. Nov 28, 2019 at 8:53 AM
    ESTundra937
    Eddie
    San Diego
    Can't complain myself. The 03 will be getting mucho mucho love in the next coming weeks. So stoked can't wait, she's gonna be just like new! Happy Thanksgiving!
  24. Nov 28, 2019 at 9:00 AM
    Don’t forget your money makers!
  25. Nov 28, 2019 at 9:44 AM
    Indeed. Didn't realize how easy that plastic was to cut. Took me about 2 minutes per side. :sawzall:
    Darkness and KarmaKannon[QUOTED] like this.
  26. Nov 28, 2019 at 9:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Happy Thanksgiving all....gave the Tundra a workout this morning by going to the country and picking up smoked turkey from a bud of mine. Gave the Salsa rest of day off.
  27. Nov 28, 2019 at 9:59 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    SPC UCA's arrived today and ordered OME suspension from Wheeler's.
    speedtre, bmf4069, lsaami and 3 others like this.
  28. Nov 28, 2019 at 10:30 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    I would add that I am also thankful for this forum and the great group of members quick to encourage and help me with keeping my Tundra in the "cherry" shape she is in and improving on it still. My Tundra is a better truck because of all of you.:thumbsup::hattip:
  29. Nov 28, 2019 at 10:46 AM
    KarmaKannon
    Utah
    Some junk
    Good thing my old my 20 something year old toro 2 stroke snowblower started easily this year. I actually don't remember if I used it last year or not. A quick clean of the bowl, some starting fluid, and a fresh plug made it roar like it was no more than 15. It was so nice outside I decided to pull the tundy out for a quick look at the sliders. I can still smell the bedliner paint on my clothes from last night!
  30. Nov 28, 2019 at 11:02 AM
    imDementeD
    Darkness, NUDRAT and KarmaKannon like this.
