Tow mirrors
Discussion in 'Towing & Hauling' started by Prison rooster, Oct 24, 2019.
  1. Oct 24, 2019 at 6:53 AM
    Prison rooster
    Prison rooster [OP] New Member
    Bobby
    Tn
    2018 Tundra TRD SR5
    Just a question for yall. I bought a bigger camper and I need tow mirrors. I stopped at the dealership and they said they dont know if the wiring and everything are the same or not. So much for being professionals on these trucks. Has anyone done a mirror swap and know which are the best to go with. Thanks for the help.
  2. Oct 24, 2019 at 6:59 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    OEM tow mirrors are plug and play. Also the aftermarket ones are too. I've had both, ebay is a good place to find what your looking for. I have these on currently, but these needed additional wiring for features our trucks do not come with...
    https://www.ebay.com/ulk/itm/292899549301
    coTony likes this.
  3. Oct 24, 2019 at 7:41 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I actually like the OEM tow mirrors because they are plug & play. Actually purchased them the other day. Spark parts is a good site and I think we get a discount from this forum. Also for a cheap option there are clip on mirrors. 1AAuto is also a good site to look at. Good luck!
  4. Oct 25, 2019 at 1:57 AM
    Prison rooster
    Bobby
    Tn
    2018 Tundra TRD SR5
    That's what I figured then they had me second guessing my self. Thanks for the help.
    Lake.Life24 likes this.
  5. Nov 27, 2019 at 12:28 PM
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    I actually just installed brand new smoked tow mirrors and am thinking of selling them now as the look isn't what I'm going for if your interested
  6. Nov 27, 2019 at 12:43 PM
    Jrharvey02
    Jrharvey02 New Member
    The ones in your profile pic? Correct me if I’m wrong, but those aren’t OEM, right?
  7. Nov 27, 2019 at 1:03 PM
    zachzap361
    Zach
    San Antonio
    Correct they are aftermarket from spec d
  8. Nov 28, 2019 at 4:45 AM
    awq735
    awq735 New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    I bought the trail ridge tow mirrors from 1AAuto.com. the keep all factory options (bsm, heat, and power adjust) as well as give you led running lights and turn signals. The fit and finish look factory, but the glass mirrors do vibrate more than I would prefer. Its not enough that the mirrors arent usable, just slightly annoying.
    Badderup, Y0TA PR0, Cthulhu and 2 others like this.
  9. Nov 28, 2019 at 4:50 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I went with Toyota tow mirrors precisely because of vibration issues with aftermarket mirrors. Some are happy with them, but some, as awq735, do have vibration issues.
    For your truck, OP, you should gain turn signal and running light with tow mirrors.
  10. Nov 29, 2019 at 1:13 PM
    Cereza
    Cereza New Member
    2014 White Tundra Crewmax 4x4
    Hmm, I'm interested but my truck doesn't have the BSM. Would this be an issue for install you think? I don't want to purchase, install and get some weird error or lights on for BSM on the mirror all the time. They don't seem to carry them without the BSM feature.
  11. Jan 21, 2020 at 8:39 PM
    Ditbwc
    Ditbwc New Member
    2014 Tundra SR5
    Do oem mirrors extend and collapse?
  12. Feb 19, 2020 at 2:33 PM
    18TMSTundra
    18TMSTundra New Member
    Spring,TEXAS
    2018 Red Tundra TSS CrewMax 2WD
    TRD rear anti sway bar. Rear SumoSprings - Black. Toyota Factory Tow mirrors. Advantage - Hard Hat Premier Tonneau Cover.
    The OEM tow mirrors manually extend and collapse.
  13. Feb 22, 2020 at 6:37 PM
    rycherd
    rycherd New Member
    Richard
    Castle Rock, CO
    2015 SR5 Crewmax Tundra
    4" lift, 35" Nitto G2, 20" Fuel Trophy rims, Nerf bars, grille
    I recently purchased similar ones to the above post.... there are 2 spot like LED lights that I assume would be attached to the reverse lights.. any luck on locating that wire?46C9E378-DB7C-4865-9FED-F9380E04CD7A.jpg
  14. Feb 22, 2020 at 6:38 PM
    rycherd
    rycherd New Member
    Richard
    Castle Rock, CO
    Here’s better pic
    Creatures 1982 likes this.
  15. Apr 2, 2020 at 6:30 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    I just installed these, and haven't finished the wiring yet, but I'll be wiring them to the cargo light switch. There is a 1AAuto video on YouTube that shows their version being installed. The white wire goes to a brown power wire for the switch. That way you can control when it comes on for additional light, and just manually switch them on reverse when needed. I believe the grey wire is the ground, which is slightly different than the 1AAuto mirror.
  16. Apr 2, 2020 at 7:26 AM
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Is there anything that you can do to stop the vibration?
  17. Apr 2, 2020 at 8:18 AM
    soarvet
    soarvet New Member
    2017 Silver Tundra Crewmax 4x4 XSP package
    I have the trail ridge mirrors and they don't vibrate any worse than the factory sport mirrors did. They've been great. I'm not staring in the mirrors, I'm just glancing in the mirror to check my trailer, and traffic, so the little vibration I do get is hardly noticed. I'd highly recommend the trail ridge mirrors over the super expensive factory mirrors from Toyota. I'm actually buying some for my old Ram 2500. Don't be scrrrddd.
  18. Apr 7, 2020 at 7:18 PM
    Pillguy
    Pillguy New Member
    Andrew
    2019 gris Tundra Limited
    I agree, just put mine my tundra. 10 min to pull door panel off, 5 min to swap out each one as long as you do not have to fool with rewiring. 30 min job tops.
  19. Apr 7, 2020 at 8:06 PM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    Just FYI the Gm style mirrors are way better for towing than the factory style. I started with the trail ridge ( factory clone ) hated them. The lower mirror is a joke, unless you like looking at your trucks rear tire.
    The GM style rocks pulling 30ft camper!! Much better in every way
    16 blue crewmax likes this.
  20. Apr 12, 2020 at 3:18 AM
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    I just found out the same thing. Toyota is the way to go with these style mirrors.
    mav7021234 and Wallygator like this.
  21. Apr 23, 2020 at 8:32 AM
    mostlyriceinside
    mostlyriceinside New Member
    NOVA
    ‘19 Tundra
    Anyone know if it's possible to replace the smaller bottom mirror on these tow sides?
  22. Apr 23, 2020 at 8:47 AM
    multimoon
    multimoon New Member
    Garret
    2015 Magnetic Gray Limited-Pro
    I've wanted to do tow mirrors but I'd probably go the 1aauto route since you keep BSM. As far as I know there are no oem tow mirrors with BSM.
  23. Apr 23, 2020 at 9:16 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    There aren't, but if you want the OEM and need the BSM, there is a hack I found on here.
    https://www.tundras.com/threads/bsm-and-oem-tow-mirror-mod.39092/
    dumbassdave likes this.
  24. Apr 23, 2020 at 10:18 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I have towed about 10,000 miles with the Trailridge tow mirrors and they perform great! The upper mirror doesn't vibrate any more than stock and the lower mirror allows me to see close up for trailer maneuvering and better blind spot view. I'd definitely buy them again.
  25. Apr 24, 2020 at 7:52 AM
    CO_Native
    CO_Native New Member
    Englewood, CO
    2024 Limited CM Silver/Nightshade
    Nice setup, twin ;-)
  26. Apr 25, 2020 at 7:14 AM
    Rustinjay
    Rustinjay New Member
    Justin
    2010 Red SR5
    KENWOOD radio, airbags and pump
    I went with a pair that look a lot like the trail ridge but are some other name on Amazon. Honestly I haven’t had any issues with them. Kept the defroster function and power adjustment. Have to slide the out by hand but they were plug and play. Took me longer to get the tools for the job than it did to put them in. I do like the ones posted below and probably would have bought them because of looks.
  27. May 11, 2020 at 5:00 PM
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    Very nice. Is that a toy hauler? how does it tow? I'm looking at one like that but not sure if it will be too much or not.
    thanks,
  28. Jul 8, 2020 at 6:43 PM
    Cthulhu
    I got mine and installed them today. Link below. I have a 2018 Limited, and it was nice to retain BSM, heated mirrors, and power mirror adjustments. Gained marker lights and turn signals which is awesome. Smoked out lights/signals look great. Be careful installing; the studs can strip easily (I need to get a replacement stud), and also, watch when removing the nuts, that they don’t fall into the door shell; about happened to me...almost mudded my drawers! The only other issue I have is the mirrors do indeed vibrate, like @awq735 stated. Not ridiculously, but noticeable. Seals are seated properly, and nice and tight, but still a little vibrating. I’ll probably get used to it though; it’s a trade-off, retaining factory features and gaining the marker lights, turn signals, and tow extensions, versus a little mirror vibration and not paying the crazy price for factory tow mirrors, which would cause me to lose BSM. I’m overall happy with the $300 spent.
    https://www.1aauto.com/2014-19-toyo...MIjLCpyv6-6gIVDQiICR1iMg_UEAQYASABEgIwcfD_BwE
    eddie98 and awq735[QUOTED] like this.
  29. Jul 16, 2020 at 7:17 AM
    cmrtopher
    cmrtopher New Member
    2012 SR5 5.7 DCLB 2WD
    For those with the official Toyota mirrors, does the passenger mirror have a "zoom" effect? I bought a pair of Amazon mirrors, and the passenger mirror is zoomed to the point you can't hardly use it. I returned them and ordered the Toyota ones, but I haven't received them yet.
  30. Jul 16, 2020 at 7:38 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    The Toyota OEM tow mirror do NOT have "objects in mirror are closer than they appear" glass. It's the same glass on both sides, which appears to be standard mirror. Which is why my tow mirrors are coming off as soon as the summer is over.
    twistedcricket likes this.
