Official Gas Mileage Thread
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Oct 3, 2019.
  1. Nov 25, 2019 at 6:00 PM
    #61
    I'm slacking. :oops:
    lsaami likes this.
  2. Nov 25, 2019 at 6:12 PM
    #62
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I think it's winter fuel time and extra warm-up idling that's bringing me down to a solid 14mpg. I expect it will be more like 13-13.5 as the winter gets wetter and I idle/clear snow off longer.
  3. Nov 26, 2019 at 4:19 AM
    #63
    Professional Hand Model
    Fred
    Hand Protectors
    You might want to look at the ‘state taxes’ involved on your gallon of gas. Please don’t move and bring those with you.
  4. Nov 26, 2019 at 4:21 AM
    #64
    Fred
    Hand Protectors
    Definitely winter blend is effecting things. Losing about 1mpg average in the last few fills.
    KarmaKannon[QUOTED] likes this.
  5. Nov 28, 2019 at 12:50 PM
    #65
    I drove like old people people fornicate and got less mpg. 331.8 miles on 24.29 gal for 13.65 mpg. That's 75 mph tops and only a few shifts above 3k. Random mpg continues...
    Filthyphil likes this.
  6. Nov 30, 2019 at 8:53 AM
    #66
    Mr. Pink
    Mr. Pink New Member
    Ontario, CA
    06 DC 4x4
    Tint, stereo system, lift , more to come
    Different transmission,
    What kind of gas are you running, try a good quality gas.
    Last tune up?
    Fuel filter?
    Last time you clean the carbon out of the throttle body?
    PSI?
  7. Dec 3, 2019 at 12:30 PM
    #67
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I wouldn’t feel to bad. I doubt there’s many 2000-2004 tundras that get much better than 15mpg on a tank to tank basis. Even on a completely stock truck I think the fuel economy.gov pegs it at 13city, 17hwy and 15 combined.
  8. Dec 15, 2019 at 9:36 AM
    #68
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    well, According to Fuelly, I was down to 8.6MPG my last tank. before that, 9.9, 10.6, 11.7.
    anyone know why my mileage would drop like a rock once temps got below freezing? I was averaging 14-15 this summer, and now it dropped again. Obviously MPG goes down in the winter due to winter blend fuel and idling time, but this is insane. I'm lucky to get 200 miles on a tank!
  9. Dec 15, 2019 at 9:56 AM
    #69
    Ouch.. That's brutal. Sorry to hear that. Something has to be wrong though. Winter fuel alone should drop you down into single digits.
    Filthyphil and lsaami[QUOTED] like this.
  10. Dec 15, 2019 at 10:17 AM
    #70
    lsaami
    lsaami Let ‘er buck
    Minnesota
    that's what I thought. It's something related to the cold though. It did the same thing last winter. As soon as it warms up, MPGs go up. I'm lost.
  11. Dec 15, 2019 at 10:32 AM
    #71
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I would throw some fuel additive in and just see if anything happens.
    revtune and lsaami[QUOTED] like this.
  12. Dec 15, 2019 at 6:20 PM
    #72
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    How long do you let it idle/warm up when it's cold? Long idle times could bring your mileage way down.
    Are you running the defrost mode? That runs the AC compressor which could also cause your mileage to suffer.
  13. Dec 15, 2019 at 6:33 PM
    #73
    Bring him down to 8mpg? Unless he's leaving it idle half the day I just don't see that happening. Something has to be wrong.
    lsaami and revtune like this.
  14. Dec 15, 2019 at 7:07 PM
    #74
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Filled up my tank when I first bought it in early November, I got 346 miles and put in 17.9 gallons. 130 miles of that was with my lift and 285’s so we’ll see what it drops to from here.
  15. Dec 15, 2019 at 8:16 PM
    #75
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Yes I run in defrost mode, but that isn’t going to kill more than a fraction of an MPG. Plus, I ran the AC all summer.
    exactly. I’m going to try some fuel system cleaner for the heck of it. It almost feels like there’s some increased rolling resistance when it’s below freezing, even after fully warm. Maybe I have some grease somewhere that doesn’t like the cold?
    either that, or I’m thinking fuel injectors or coil packs are worn.
  16. Dec 16, 2019 at 2:03 PM
    #76
    Fred
    Hand Protectors
    Hand calculated per usual prior posts here at 11mpg today.
    Lots of idle time, no towing/hauling, and all city driving. Normal mpg considering.
    lsaami, revtune and Filthyphil like this.
  17. Dec 18, 2019 at 8:16 AM
    #77
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Seems a fitting place
    revtune and bmf4069 like this.
  18. Dec 18, 2019 at 5:08 PM
    #78
    revtune
    revtune New Member
    Dane
    Houston Texas
    4 years ago when I went to the used car dealer to buy my 02, I asked about the mpg. This was the result.
  19. Dec 18, 2019 at 6:27 PM
    #79
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    2015 4x4 Crewmax w 5.7 Terrible MPG
    2003 2x4 Extracab w V6 also bad MPG
    That's why I have a 2014 Yaris for commuting and great MPG
    Bulldog_tundra likes this.
  20. Dec 19, 2019 at 4:49 PM
    #80
    Bulldog_tundra
    USA
    2006 Double Cab
    I traded my built 2003 4Runner on 35’s for a 2 door 2011 Yaris hatch, absolutely one of my favorite vehicles I’ve ever had bc of how simple it was and the gas mileage (routinely hit 38-42 MPG). Traded it in bc I couldn’t afford the gas to drive across town to date the now Mrs. in college haha
    FrenchToasty and Darkness[OP] like this.
  21. Dec 23, 2019 at 8:28 AM
    #81
    cammiller
    cammiller IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    I have a 2004 Double Cab 4x2 and 90% of the time I’m pulling my near 5,000 lbs lawn trailer or my 6,700 lbs tractor. When I fill up I average about 11-14 mpg. I wish I could get better but with my usage I don’t see how.
    georgiey22 likes this.
  22. Dec 23, 2019 at 10:25 AM
    #82
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Yeah, that’s pretty dang good. Most of us Average the same as you unloaded.
    revtune likes this.
  23. Dec 23, 2019 at 12:32 PM
    #83
    swampshark
    swampshark New Member
    south la
    2020 MGM SR5
    Just made a trip from Baton Rouge to Houston (I-10)....set the trip odometer to "0" when I left my home and set the cruise control on 73mph and let er eat....when I filled up in Houston, I divided the miles traveled by the number of gallons to refill the tank and got 16.9mpg! 2020 SR5 TSS Offroad edition (all-terrain tires on 20" wheels)....this truck has the 30+ gallon tank....the "miles to empty" display said I still had 121 miles I could go!
  24. Dec 23, 2019 at 1:44 PM
    #84
    revtune
    revtune New Member
    Dane
    Houston Texas
    Do we need to put up the guy smashing into the door again:D
  25. Dec 23, 2019 at 4:10 PM
    #85
  26. Jan 2, 2020 at 3:52 PM
    #86
    Fred
    Hand Protectors
    12 MPG
    All city driving. A little idle, but not much.
  27. Jan 2, 2020 at 5:03 PM
    #87
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 tundra 4.7 2wd
    3 inch lift
    stock 3.91 gears
    P285/70/17 terra grapplers (45lbs)
    Sams club 87 octane
    Access soft roll up cover (always covered)
    tank was mixed driving, sorry I can’t quantify exactly how much city vs highway.
    I calculated 14.77 mpg but I like 5’s and 0’s;)
    So I’ll go with 14.5 mpg:thumbsup:
  28. Jan 4, 2020 at 1:13 PM
    #88
    rickybobby6969
    rickybobby6969 New Member
    2003 tundra extended cab 5 speed
    2003 extended cab with 3.4 manual 4wd around 17-18 mostly backroad driving with 5 minutes twice a day on highway I give her the juice often but not crazy 5-10 above speed limit
  29. Jan 7, 2020 at 9:02 AM
    #89
    Tbau
    Tbau New Member
    2006 Tundra XSP
    This makes me feel better that I'm about where everyone else is. I get about 14.5 mostly highway
    2006 DC
    300+lbs was weight between the ladder rack and all my towing and recovery tools in the bed
    Bed cover
  30. Jan 13, 2020 at 5:57 AM
    #90
    Filled up today with ethanol free gas. I want to see if it makes a difference. I got 341 miles to the tank at 15.13 MPG. Not bad for 40% city driving.
    lsaami and speedtre like this.
