VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Nov 24, 2019 at 5:20 AM
    #2071
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ! have no information or experience upon which to base even a speculative answer.
  2. Nov 24, 2019 at 5:54 AM
    #2072
    Dakar650
    Dakar650 New Member
    Shawn
    2019 Cement Limited
    My 19 is ready for tuning! Can't wait
    rockmup likes this.
  3. Nov 24, 2019 at 7:14 AM
    #2073
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    @OVTune
    Mat, I'm having a dash button made that says 87 octane for the other map I requested.
    It can be made as an on/off switch or as a momentary switch. The OEM tow button is a momentary switch.
    I was thinking an on/off switch would be nice, so I wouldn't have to press it each time, if I had to run 87 octane. Would continuous signal from the on/off style switch cause a problem with the tune or ECU?
    Wynnded likes this.
  4. Nov 24, 2019 at 8:11 AM
    #2074
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    My justification for the SC was mostly extra towing power. Most of my Bikes, The GT500 and the Cobra all run premium fuel so its what I am used to anyway. The daily and my older Dodge plow truck are the only vehicles I run 87...Being limited to Premium is only an issue for me when traveling and I usually just map out stations using puregas.org, and have some Boostane along just in case...
    Duneflyer[QUOTED] likes this.
  5. Nov 24, 2019 at 11:22 AM
    #2075
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    I have one of those but the software isn't going to work with Android (at least not right now).
    Maybe one day they'll have us flashing with smart phones but as of now it needs windows.
    ZPMAN[QUOTED] likes this.
  6. Nov 24, 2019 at 11:49 AM
    #2076
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    I am curious then about maybe mirroring the laptop or maybe the orange virus ToyotaCal TuningTablet
    https://www.ovtuned.com/collections/toyota-cal/products/toyotacal-tuning-tablet
    With wifi or cable?
    Is the tablet wireless capable? Or able to mirror it? @OVTune
  7. Nov 24, 2019 at 2:02 PM
    #2077
    Ericsopa
    Ericsopa Old man and the sea
    Okay....now here's a question for all you who, like me, already had or have a DAP tune, done remotely using the MyGenius handheld device, and are swtiching to the OV Tune. This MyGenius critter has my OEM tune stored in it right now, in case I ever needed to change it back from the DAP tune for some reason. Maybe @OVTune has some insight on this, too.
    Can I pull the DAP tune prior to flashing the OVtune and store it in the MyGenius? If I don't switch back to the OEM tune prior to reflashing with the OVTune, is my DAP tune gone? Can I ever use the MyGenius device to restore the OEM or DAP tune and expect it (the MyGenius device) to retain the OVTune, in order to be able to reflash the ECU again at a later date with the OVTune? According to DAP, the MyGenius device also is not compatible with MAC, must use Windows.
    Is that clear as mud?!? :Do_O:confused:
    Honestly, I'm not too worried about trying to keep the DAP tune, just more curious than anything. And wondering if I'll ever have any use for the MyGenius again.
    EDIT: Then again, maybe the OEM tune is here in my laptop, and the MyGenius is the device used to do the reflash. I'm gettin' too old .... memory fails me....sometimes.....what were we talking about?
  8. Nov 24, 2019 at 6:36 PM
    #2078
    4firemandan
    SWFL
    So which software do we use from the OVT website? 2016+ Tacoma?
  9. Nov 24, 2019 at 7:06 PM
    #2079
    Midway
    Midway New Member
    Others can chime In. The fastest way is click on "Resources", then click on the photo I attached. Or, you can go to General-Instructions", scroll down until you see:
    OROLLA / LEXUS / TUNDRA FLASH KIT
    TOYOTA INSTRUCTION
    Click on "TOYOTA INSTRUCTION"
    The flash/driver download links are there.
    *Remember to disable your Antivirus protections.
    *Use a labtop that you will dedicate to this process*
    4firemandan[QUOTED] likes this.
  10. Nov 24, 2019 at 7:07 PM
    #2080
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    First one. Tundra is listed.
  11. Nov 24, 2019 at 7:14 PM
    #2081
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Your factory tune and the dap tune are both stored on the mygenius. You just go through the flash procedure and click the non "mod" file. You will always have the dap stored for a rainy day.
    You'll most likely want to flash back to stock before you flash the OVtune on it.
  12. Nov 24, 2019 at 7:15 PM
    #2082
    4firemandan
    SWFL
    Thanks guys. I followed the directions on the flyer and was getting only taco options.
    Is there a version of the flash manager and logger to confirm I have the right ones?
  13. Nov 24, 2019 at 7:24 PM
    #2083
    Midway
    Midway New Member
    I believe version 1.3.0
  14. Nov 24, 2019 at 7:29 PM
    #2084
    4Runner
    4Runner New Member
    Columbia, SC
    Don’t pick a truck. Launch P5 or Logger and you are good.
    4firemandan likes this.
  15. Nov 25, 2019 at 3:35 AM
    #2085
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    The gear issue I am referring to are the new gears I had installed, I am going through the break in period. Nothing to do with the tune
  16. Nov 25, 2019 at 7:27 AM
    #2086
    Seuqoia11
    Seuqoia11 New Member
    @OVTune I have been thinking for a while now on a new feature I have not heard anybody ask for. When we downshift with the factory tune, it has preset townshift limits based on speed from what I can tell. It works great as an engine break/aggressive down shifting for all gears ACCEPT 1st. If your rolling at 40MPH and put the s mode in 1, it will beep and NOT shift until somewhere around 20-25 mph which gives you only about 3 thousand ish rpm which doesn't engine brake anything.
    Could you remove this 1st limit so we can shift into 1st to engine break at similar points to say 2nd or 3rd? I think 2nd will click in around 60 mph and it revs to around 5000. Be nice if it let 1st engage at whatever speed lies at around the same rpm limits as the higher gears.
    Also any chance you could add in auto engine breaking (auto downshift when braking) in drive tow haul mode, like GM does with there newer tow haul features?
    Not sure if anybody else is interested in this feature being added. I would say that this is a low priority to me as I would love to see the flex fuel tune next!!
    Thats after I get the base tune! Which should be very soon?
    shellshock likes this.
  17. Nov 25, 2019 at 7:55 AM
    #2087
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    That’s probably my biggest gripe I can’t get into first until you are like nearly stopped.
    my shifts decent in tow haul but I’d definitely be ok with it being fine tuned a bit.
  18. Nov 25, 2019 at 7:57 AM
    #2088
    suby2low
    suby2low New Member
    2016 TRD Tundra DC SC'd
    3" lift w/ 33x12.50s, Grampa cap, TRD supercharged, URD pulley, 340LPH FP, OV tuned
    1st gear down shift is limited to less than 22mph FWIW. it does feel like it is too slow but Toyota is really just trying to protect your engine and trans.
  19. Nov 25, 2019 at 8:11 AM
    #2089
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I'll look into it, but can't make promises (on the 1rst gear thing). Seems a bit dangerous. The LC500 allows this and the driveline shock is tremendous when going into first at 5000 + rpm
  20. Nov 25, 2019 at 8:51 AM
    #2090
    Seuqoia11
    Got it. I have never seen this low engagement on any other vehicle to date...??
  21. Nov 25, 2019 at 11:12 AM
    #2091
    maharaj1
    maharaj1 New Member
    Justin
    2014 Tundra 1794 2WD
    Sent my logs in last week. I was on my second tune revision and was seeing roughly 13.6-13.8 MPG with mixed driving, 2014 2WD no lift or bigger tires. Looking forward to the next round of updates.
  22. Nov 25, 2019 at 12:26 PM
    #2092
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    My $.02
    Agreed that this would be a dangerous feature. During some spirited driving I've been guilty of accidentally double taping the s mode selector, heard the beep and had been glad that the lock out was there.
    I'd keep it
  23. Nov 25, 2019 at 2:04 PM
    #2093
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Alrighty guys.
    Rafael and I are working right now on wrapping up the ECUs that need S mode lock completed.
    I might have some features coming for the shift selector (up/down) but that's at a later time. We have a lot to get wrapped up with first and get all ECUs on the same page.
    And sequoia guys I have some questions for you, please check your zendesk ticket later this evening
    Stroke250, theraven and TruckyTruck like this.
  24. Nov 25, 2019 at 2:38 PM
    #2094
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    For those of use Sequoia owners interested in this, would you share the questions so we can chime in? Or at least be aware of newer information so we can make a decision to proceed or not. Many thanks!
  25. Nov 25, 2019 at 2:44 PM
    #2095
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Sure,
    1. I need to confirm, but some sequoias have tow haul mode and a ECT button, we wanted to confirm a few things because this gives us room for a few additional things unique to the sequoia as they both act independently on the shift and throttle.
    The combination (s mode, ECT, and Tow haul) needs to be appropriately handled in the ECU so that it doesn't hang up in the code. Basically.
    Wynnded likes this.
  26. Nov 25, 2019 at 4:47 PM
    #2096
    e30cabrio
    West Valley, Phoenix, Az.
    2010 Crewmax, 2013 Sequoia Limited
    Sequoia LED Headlights! D.T. L.T. headers, dual exh., BDX, S&B intake, 2018 seat skins.
    Not rushing but can you give me an idea when I might get my base (& verify you got my ECU info)?
    Order 5325.
    Thank you!
  27. Nov 25, 2019 at 5:23 PM
    #2097
    TruckyTruck
    Gary
    :woot:
    theraven likes this.
  28. Nov 25, 2019 at 6:17 PM
    #2098
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Also, there will be a *slight* update with our S-mode control.
    S-mode control will have (optional) 3 things:
    1. Gear locking
    2. Full Throttle Direct Upshift shift control. (fully functional). -Allows direct and immediate shifting up or down at ANY RPM within the programmed allowable limits. (no you cannot downshift into first to get 1rst gear at 6000 rpm).
    there is no delay, you press it, it shifts immediately. You press it at "4877RPM it shifts at 4877RPM... you press it at 5155...etc..
    3. Full throttle Direct Downshift Control.
    tundra_20, Wynnded, Warreng and 7 others like this.
  29. Nov 25, 2019 at 6:23 PM
    #2099
    TruckyTruck
    Gary
    What's the third???
    Dont make mine optional. I'm in for it all!:)
  30. Nov 25, 2019 at 6:26 PM
    #2100
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Edited, got ahead of myself lol
    0CM51 will get "day1" access and DirectShift control will be added in as an option
Thread Status:
