TPMS Problem with Bigger Tires
Discussion in 'Wheels & Tires' started by AA_ronTX, Aug 25, 2019.
  1. Aug 25, 2019 at 6:53 PM
    AA_ronTX
    AA_ronTX [OP] New Member
    2016 Black TSS Tundra
    3 inch Lift and level. Ranch hand front and back, 35” MT/2, F+R VIOFO Dash Cam, light bar and bed cover.
    Hello All! 2nd Post here (just did new members). I’ve read lots of advice since I purchased my first Tundra in May, and thank y’all for the wise contributions. My question is about TPMS and upgraded tires.
    Background:
    Stock tires are 49PSi recommendation according to door and were a 17” rim. I purchased Firestone Destination MT/2 35”x12.5x20 with a max PSI of 65. According to some posts on here about calculating correct PSI and Firestone’s website, my tires were immensely over inflated. I thought there was something wrong with the suspension or struts as my truck was so bouncy. Tire shop put them at 51; I have since dropped them to 38 at the recommendations of here and Fstone. Just got back from a test drive.......night and day difference, so much better!!!!! Now though, truck TPMS is on. Any idea on how to fix this and the speedometer is definitely off too.
  2. Aug 25, 2019 at 6:56 PM
    AA_ronTX
    Typo, 49 PSI. Good catch, that’s what they were at when I checked.
    TRD15559 likes this.
  3. Aug 25, 2019 at 6:58 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Follow the baseline pressure reset procedure following the instructions in your owner’s manual and using the little round black button under the steering column.
  4. Aug 25, 2019 at 7:02 PM
    AA_ronTX
    Thanks landphil, I’ll give it a try tomorrow!
  5. Aug 25, 2019 at 7:12 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Here you go...
    OP, 35 should be good on those based on load range compared to the oe 285/55/20.
    https://static1.1.sqspcdn.com/static/f/589830/23447320/1378330097907/Discount+Tire+inflation.pdf
    There is the TPMS reset button on the bottom right of the dash (in front of where your right knee would be).
    Make sure the tire pressure is where you want it.
    Hold the button for a few seconds and the light on the dash should blink and then stay solid.
    Drive or leave the truck running for at least 15 mins.
    Your baseline pressure will now be reset to 35.
    Ely010606 and Watt maker like this.
  6. Aug 25, 2019 at 7:41 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Same size tire but Nitto Ridge Grapplers, psi at 35 and TPMS not going on.
    Watt maker likes this.
  7. Aug 25, 2019 at 7:45 PM
    AA_ronTX
    Great Description!!! This will save my OCD ass! I hate dash light-ups. I mean on long road trips where I know I’m gonna be using brights a lot. I put electrical tape over the brights on light.
  8. Aug 25, 2019 at 7:48 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Sweet, i dont need to read the manual to reset the TPMS. thanks for the post
    AA_ronTX[OP] likes this.
  9. Aug 25, 2019 at 8:06 PM
    AA_ronTX
    It worked like a charm!!!!!!
    Watt maker and Ely010606 like this.
  10. Aug 25, 2019 at 8:15 PM
    Ely010606
    SPARKS, NV
    So , you set your TPMS @ 35.
  11. Aug 25, 2019 at 8:56 PM
    AA_ronTX
    I set the rear to 35 and front to 38.
    Ely010606[QUOTED] likes this.
  12. Aug 26, 2019 at 12:45 AM
    TXTundra2722
    2015 Black Tundra
    Looking at your post I saw this sticker on your truck and just noticed that I have the same. Anyone know what option gave this truck the reduced payload?
  13. Aug 26, 2019 at 2:01 AM
    timsp8
    NY
    Could be bed liner or sunroof. Mine has the sticker saying it was reduced by 7 lbs or something small like that.
  14. Aug 26, 2019 at 4:42 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    No doubt------------lawyers compelled this level of crazy shite.
  15. Aug 26, 2019 at 9:01 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I’m thinking it’s my taneau cover.
  16. Aug 26, 2019 at 9:09 AM
    TXTundra2722
    2015 Black Tundra
    That's the only thing that I could come up with on mine too
  17. Nov 25, 2019 at 6:31 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    so do u guys reset the tps when u air down for off roading??
