Top setting 5100...biggest tire without trimming?
Discussion in 'Suspension' started by Torian13, Nov 20, 2019.
  1. Nov 20, 2019 at 4:10 AM
    Torian13
    Torian13 [OP] New Member
    2019 Tundra XSP
    I’m about to pull the trigger on 5100s on top setting, 1.5 inch shackles, and some spacers for my ‘19 Tundra XSP. I’m thinking of keeping the stock wheels because I like the look so that’s the reason for the offset spacer.
    My question is, how much meat can I fit in the wheel well when it comes time for new tires. I’m running the stock trail grapplers currently. And will go bigger when it is time to change. What have you guys using the top setting of the 5100 ran in to as far as sizing/rubbing issues. Thanks!
  2. Nov 21, 2019 at 5:18 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I am running 285/60 20 With 5100 on top setting
    Had to remove factory mud flaps but that’s it
  3. Nov 21, 2019 at 5:54 PM
    rznhales
    rznhales New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    Running 5100’s and 1 coachbuilder shim on factory rims with 295/70R18’s. Just pulled the front mudflats but no rubbing anywhere else.
  4. Nov 24, 2019 at 2:45 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Top setting on my 5100's with 275/65/20. Removed flaps and bent the skid plate a little.
  5. Nov 24, 2019 at 2:47 PM
    plumber802
    Andy
    Vermont
    CC00DC88-3D9B-4FBB-B5CF-1468607AFEB8.jpg Here...
  6. Nov 24, 2019 at 3:06 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Flaps removed, ran a 285/75/17 on top setting 5100s with zero issues. Nothing out back. 17x8 50mm offset wheel.
