  1. Nov 24, 2019 at 8:42 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Man, that ranks as the dirtiest TB I’ve seen.
    TX-TRD1stGEN[QUOTED] likes this.
  2. Nov 24, 2019 at 8:45 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Picked up my "new to me" winch for the Tundra. I will give it a good cleaning but still need to order my bumper so it will sit for a while.
    MS22, NUDRAT, bmf4069 and 4 others like this.
  3. Nov 24, 2019 at 8:49 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Ah bird food insulation.
  4. Nov 24, 2019 at 9:48 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Yeah 20 years of pcv oil.
    Still ran fine.
    Anyone do a pcv delete on a first gen??
  5. Nov 24, 2019 at 9:52 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Any plans for synthetic rope?
  6. Nov 24, 2019 at 9:55 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    No but I see em done on Honda's and stuff. I know you can put that little breather filter on the crank case. I don't know if you just.plug the inlet to the intake tube or what.
    however another alternative popular on Tacomaworld is the in line oil catch can on the PCV vacuum line
  7. Nov 24, 2019 at 10:22 AM
    What is PCV oil?
  8. Nov 24, 2019 at 10:49 AM
    imDementeD
    Not sure honestly. I know about | | much about winches but was browsing FB Marketplace and saw what I believe was a great deal for the Zeon 12 so i scooped it up.
    What are the benefits using synthetic? Is it worth the cost and hassle to re-spool it?
  9. Nov 24, 2019 at 11:17 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Synthetic rope is a must in my opinion, although very expensive. It has very little stretch, less than 3% I believe compared to cable which stretches a mile (possibly 28%). It is safe, if it breaks it isn't going to cut you in half like a loaded cable might if you are in the wrong place when it snaps under tremendous force. It is also far nicer to handle than cable, easy on the hands.
    Three years ago, when I was far more capable than today, my son and I pulled down two maple trees on some property that I own that needed a clearing, one about 30" in diameter and another around 36", using 7/16" synthetic rope and two come-a-long winches rated at 6-ton each, and several (6?) large snatch blocks. Note I said pulled down and not cut down - we wanted no stump being left, so I decided we would use leverage to unearth the rootball (pre-stump) and digging around the trunk, cutting all the roots exposed before setting the 12ton towing strap around each at approximately 15' and running two separate lines to two separate winches attached to two maples of same size. As the come-a-longs had a fairly short working length of 16' or so (vague on the distance now) it was necessary to constantly adjust the winches with one pulling or holding while the other was being reset for its turn, working back and forth until the trees came down, unearthed and with no stump left in the ground. And such is the workings of one who saw the orcs pulling down trees in The Lord of the Rings.
    I learned then that cable costing 60% as much wasn't such a good deal, mainly because of the stretch and secondly on the danger of the line snapping and leaving the world with two of me.:rofl:
    allibubba, MS22, Darkness and 2 others like this.
  10. Nov 24, 2019 at 11:36 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Oil that goes into your throttle body from the pcv valve.
    speedtre likes this.
  11. Nov 24, 2019 at 12:08 PM
    Got it. So you just meant it hasn't been cleaned before.
  12. Nov 24, 2019 at 12:20 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yeah I don't believe it had ever been cleaned.
    Seems like a pcv delete or bypass would prevent this dirty/oil from happening at all.
    I know they are popular with Honda car s and Duramax trucks.
    Just wondering if anyone has tried it with a 4.7.
  13. Nov 24, 2019 at 12:33 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Did a headlight restore job today....took exactly an hour beginning to end including waiting 15 min between the 2 clearcoat applications.
    This is the product...3M with UV protective clearcoat...$30 at Pep Boys:
    Before:
    After the two dry sands...500 then 800 grit:
    After the 3000 grit wet sand:
    All wiped off and ready for the 1st clearcoat application:
    After the first clearcoat application:
    And the final product after the 2nd clearcoat application dried:
    I'm pretty happy with it.... we'll see how it holds up.
  14. Nov 24, 2019 at 1:00 PM
    joseph_sal
    joseph_sal New Member
    Joseph
    Memphis TN
    2000 Toyota Tundra 4WD SR5
    Loving the setup and wouldn’t ask for more!
    Just finished installing OME 2885 coils with Bilstein 5100 (1st notch) and 1.5” Supreme Suspensions wheel spacer.
    Also, installed new tires; Discover Cooper A/T M+S - 285/75/R16 on Tacoma TRD rims.
    Previous measurements (floor to fender):
    - Front: 34”
    - Rear: 37”
    New measurements (floor to finder):
    - Front: 37.5”
    - Rear: 38”
    P.S. No rub anywhere! Of course I had to remove the front mud guards.
    Volt92, speedtre, Filthyphil and 6 others like this.
  15. Nov 24, 2019 at 1:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    well that looks good. No lift in the rear? that front setup is what i plan on runnin on my reg cab.
  16. Nov 24, 2019 at 1:17 PM
    imDementeD
    Removed lighter and installed USB ports. (I placed the lighter below since I was missing the cap but ended up just tossing it so on the hunt for a 12v cap!)
    bmf4069 likes this.
  17. Nov 24, 2019 at 2:11 PM
    empty_lord
    05 rollover special
    can anyone with the secondary sunvisor unscrewed it and pull it down (theres a christmas tree pin on it too) and shoot me a picture of the hole in the headliner? and measure it if possible... trying to get this head liner ready to be re aphoulstered
  18. Nov 24, 2019 at 2:22 PM
    What is involved here? Pop out the lighter amd use the existing wires for this? I need to do this. My lighter will never get used.
  19. Nov 24, 2019 at 2:23 PM
    joseph_sal
    Joseph
    Memphis TN
    Thanks man! No lift in rear. Just wanted to level and fit the 285s. By the look it’s pretty level - by measurements it’s 0.5” lower in front.
  20. Nov 24, 2019 at 2:25 PM
    joseph_sal
    Joseph
    Memphis TN
    I did the a similar one. Got it from Amazon - plug and play.
    Quick Charge 3.0 Dual USB Charger... https://www.amazon.com/dp/B07MMHZDXY?ref=ppx_pop_mob_ap_share
  21. Nov 24, 2019 at 2:27 PM
    joseph_sal
    Joseph
    Memphis TN
    Last project for the day was replacing the long ass antenna!
    Got it from Amazon: AntennaMastsRus - The Original 6 3/4 Inch is Compatible with Toyota Tundra (2000-2020) - Car Wash Proof Short Rubber Antenna - Internal Copper Coil - Premium Reception - German Engineered https://www.amazon.com/dp/B01NALK2FC/ref=cm_sw_r_cp_api_i_MnW2DbXQ23YM8
    most importantly, reception is the same! At least I haven’t noticed a difference.
    TX-TRD1stGEN likes this.
  22. Nov 24, 2019 at 2:33 PM
    imDementeD
    The Atoto A6 Pro head unit comes with (2) USB ports but they don't have a way to "mount" so I used this guy to connect to the head unit and secure in the cigarette lighter hole.
    Worked perfectly. (1) USB is a fast charge and the other is technically for the DVR camera that Atoto sells but also charges.
  23. Nov 24, 2019 at 2:37 PM
    imDementeD
    I might need to get that model for my other 12v outlets. Or at least one of them. Maybe leave one alone just in case I need to use a traditional 12v socket.
  24. Nov 24, 2019 at 2:49 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I drove my 2002 out to a service call at one of my long time customers that just traded her 2003 step side 1st gen for a brand new 2020 DC 4X4 Limited... awesome truck! Here is her old '03 next to my '07.
  25. Nov 24, 2019 at 3:24 PM
    KarmaKannon
    Utah
    Some junk
    One side mounted. I need my angle drill to finish it. Oh and thank Jesus for sharp cobalt drills.
  26. Nov 24, 2019 at 3:40 PM
    empty_lord
    05 rollover special
    Got the secondary visors in. Poked 3 holes with bolts ground to a point for 2 then use the clip on the visor to mark where the 3rd went.
    Headliners ready to go out for getting reupholstered
    Just gotta order new main visors and dynamat the roof then line with the foam I’ve got... should kill ALOT of wind noise.
    Said hole for visors [​IMG]
    Volt92, bmf4069, ethan1911 and 2 others like this.
  27. Nov 24, 2019 at 3:47 PM
    Outbound
    Aaron
    Northern Alberta
    Do your Costcos has gas bars? Costco use Top Tier gasoline, which is the same as Shell. It's good stuff
    https://www.toptiergas.com/licensed-brands/
  28. Nov 24, 2019 at 4:35 PM
    Looks damn good. Looks like a professional job. Wouldn't it have been easier to paint them before installing?
  29. Nov 24, 2019 at 4:42 PM
    KarmaKannon
    Utah
    Some junk
    Sure, but paint won't be in until next week and I had to drill the holes anyway. Not hard to remove them for paint in a few days and then I have all the holes in the frame already.
    Added a cool picture of the rear mount with gussets hot metal glue gunned. Oh and I can still curl each side, but I bet they are about 90lbs. Getting to the point where I have to be careful throwing them around so I don't twist something. Lots of leverage over the 96" length.
  30. Nov 24, 2019 at 4:46 PM
    Fred
    Hand Protectors
    I like to dry fit things before paint. Just in case a slight change is needed. Eliminates painting twice. Or, a scratch on fresh paint during hole drilling time. Nice work!
