2020 Toyota Tundra SPRINTER-XLK 4X4 Off-Road Build
Discussion in '2.5 Gen Builds (2014-2021)' started by SprinterAE86, Nov 16, 2019.
  1. Nov 16, 2019 at 4:21 PM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    2020 Toyota Tundra SR5 4x4
    So, I never had the chance to take any photo of the truck with any mods. I had my first mod within days of purchase.
    LEER topper
    Copper Discoverer AT3 XLT 295.70.18
    TRD Black shift knob
    Parking sensors for the front (Came with dealer installed rear)
    Firestone Air Rite air springs
    Daystar cradles
    Bed Rug
    All weather mats
    LED headlight Bulbs
    LED Fog Light Bulbs
    Bilstein 5100 bottom setting
    Tuff Country 2" leveling kit with axle drop
    TRD front sway bars
    TRD rear sway bars
    Toyota factory color key pocket fender flares
    Cover King neosupreme seat cover (waiting on rear)
    Side Mirror Covers super white 040
    Paint bulge and grill super white 040
    Black badge
    Bumper shellz
    Step/Side Armor
    Leather Steering wheel wrap
    Future:
    Katskinz
    TRD Pro LED head lights
    Patch harness
    TRD Pro skid plate
    Diesel Toys upgrade!
    Whatever mods I see in Tundras.com
    Before:
    20191113_152356[1].jpg 20191110_091008[1].jpg 20191112_124312[1].jpg 20191109_164859[1].jpg 20191016_170140[1].jpg 20191109_103940[1].jpg 20191109_164817[1].jpg 20191109_164931[1].jpg
  2. Nov 18, 2019 at 6:35 PM
    SprinterAE86
    Ian
    Side mirror caps in! Bumper Shellz after thanksgiving.
    jordan0317 likes this.
  3. Nov 24, 2019 at 12:59 PM
    SprinterAE86
    Ian
    Painted the grill surround, installed mirror caps, black emblems and seat covers.
    20191124_112327.jpg 20191124_150622.jpg 20191124_153750.jpg 20191120_134230.jpg 20191120_132457.jpg
  4. Dec 7, 2019 at 12:04 PM
    SprinterAE86
    Ian
    20191109_162404.jpg 20191118_165435.jpg 20191124_112327.jpg 20191207_140346.jpg
  5. Dec 7, 2019 at 1:55 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    What is the setup on your 5100s, do they have stock springs with a spacer ontop?
  6. Dec 7, 2019 at 2:52 PM
    SprinterAE86
    Ian
    Spacer sandwich between thje top perch and coil springs. Bottom settings. I kept the oem springs since I don't have any need for an upgrade.
    MacCTD[QUOTED] likes this.
  7. Dec 7, 2019 at 3:18 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Interesting, why would you do put the spacer in instead of just using a higher slot on the 5100 spring perch?
  8. Dec 7, 2019 at 4:39 PM
    SprinterAE86
    Ian
    I ordered the level kit before getting the 5100. Since I already have it, might as well install it.
  9. Jan 12, 2020 at 6:38 AM
    SprinterAE86
    Ian
    Pinay and Rica25 like this.
  10. Jan 12, 2020 at 7:03 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Nice truck. I gave the pathfinder at's a try for my current set, couldnt beat the price for the 295-70-18. A solid tire, great in snow, offroad and still somewhat quiet on the hiway, 20k so far and the wear is excellent
    SprinterAE86[OP] likes this.
  11. Jan 12, 2020 at 8:44 AM
    SprinterAE86
    Ian
    Filled up the tank, disconnected the battery, drove 90 miles, set cruise control to 75mph for 80 miles. Average speed 73/74mph on I95. 16mpg best, mostly 15.9.
    I have about 1200 pounds in the bed, 55/60psi. 2" level with 1" rake.
  12. Jan 12, 2020 at 12:36 PM
    SprinterAE86
    Ian
    Thanks! I had it in my 05 Tundra as well, I almost installed it in my 16, but I decided to trade it in instead. It's a great tire. I was looking into Wild Peaks, but 69# per tire vs my 55# 275.65.18. I am considering Cooper Tires discoverer AT3 XLT's 61# or go with Pathfinder 63# 295.70.18.
    Rica25 and Nm6300'asl[QUOTED] like this.
  13. Jan 12, 2020 at 12:50 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Nice ride... did you notice diminished bed bounce with the air bags on the rear?
  14. Jan 12, 2020 at 4:30 PM
    SprinterAE86
    Ian
    Thanks! I had two different experiences with two different brand airbags in a with 2 different 3rd gen with the same load. '16 DC and '20 DC. Both have same exact topper and bed load. '16 had an Air Lift, the '20 have Firestone.
    I selected the airlift because of the internal jounce bump stop. But it felt too bumpy, like I am riding directly on the axle. I changed the air pressure up and down just to find a happy medium. But was not successful. Air Lift did not work for my application.
    I installed Firestone for the '20. Empty bed with 5psi is just like running on stock shocks and spring unless it's a harsh dip. Then you feel the bag work. When loaded I just ad an inch lift to the rear over the front. It worked well for me.
    Now the answer to your question. It did not diminished the bed bounce, but minimized it in some way. Paring it with a good shocks over OEM made a huge difference. The OEM shocks valving is not sufficient enough with the added spring weight during rebound. That's where you get your bounce. Compression and rebound, and frequency or it makes it unstable.
    Below is the video of it driving the maximum posted speed limit of 65mph 300lbs in the bed, OEM shocks before the Air Lift. Passing lane was where I almost bounced off the road towards the guard rails the day before, the main reason I made the video.
    I'll video my drive tomorrow 65mph, Firestone Ride Rite Air Springs with 5100's and 1200lbs in the bed. It will still bounce, but the same or less due to the help of the upgraded shocks.
  15. Jan 13, 2020 at 7:40 AM
    SprinterAE86
    Ian
    Can you share me pictures of your truck with pathfider 295.70.19.
    Thanks!
    Rica25 likes this.
  16. Jan 13, 2020 at 12:28 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Here you go, even was able to keep the front wheel spats (look close and you can see where I added a screw).
    SprinterAE86[OP] and Rica25 like this.
  17. Jan 13, 2020 at 2:39 PM
    SprinterAE86
    Ian
    Thanks, that gave me a better perspective.
  18. Jan 20, 2020 at 4:02 PM
    SprinterAE86
    Ian
    Shimmed the bumper, deleted front mud guards, got some new shoes and wash!
    Cooper Tire Discoverer AT3 XTL 295.70.18 18x9 +12 Bilstein 5100 bottom setting Tuff Country 2" Level Kit.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    275.65.18/295.70.18
    TheBeast likes this.
  19. Jan 20, 2020 at 4:07 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Very nice progress so far!! :thumbsup:
  20. Jan 20, 2020 at 4:10 PM
    SprinterAE86
    Ian
    Thanks! I'm done spending money on this rig for now, need to divert the money back to the race car, or off road camper build. And finish typing up the Adobo Recipes. ;)
    Pinay[QUOTED] likes this.
  21. Jan 20, 2020 at 4:13 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Wooooohooo!! Sounds good!! Ima get fresh bottle of vinegar and soy sauce an lottts or bawang!! :drool:
  22. Jan 21, 2020 at 10:49 AM
    SprinterAE86
    Ian
