the bomb!
Discussion in 'Detailing' started by swampshark, Nov 24, 2019.
  1. Nov 24, 2019 at 9:57 AM
    swampshark
    swampshark [OP] New Member
    south la
    2020 MGM SR5
    Just got a chance to use my Griot's Garage PFM 25x30 towel.....DAYYYYYUUUUMMMM! Nuf said!
  2. Nov 24, 2019 at 10:13 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    For drying? I ended up going overboard on drying and bought a master blaster by metrovac. Go ahead and laugh at the name, I did. Works really well tho.
    1UPPER, YardBird and War Machine like this.
  3. Nov 24, 2019 at 10:17 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    They are magic......Pure Freaking Magic!
    Voyagermike and War Machine like this.
  4. Nov 24, 2019 at 10:22 AM
    swampshark
    south la
    2020 MGM SR5
    Yes...for drying....dried my 2020 SR5 Crew Max and still could have kept going!!!
  5. Nov 24, 2019 at 10:45 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Yep, love mine. Can do the entire truck without needing to wring it out.
  6. Nov 24, 2019 at 10:57 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Good grief!!!...You DID only buy one towel! :D
    War Machine likes this.
  7. Nov 24, 2019 at 4:11 PM
    War Machine
    War Machine SSEM # 5 3MW
    Far and away the best towel on the market.
    Hammerdog and Voyagermike like this.
  8. Nov 24, 2019 at 4:30 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Which one do you recommend? They've got several choices, but I think I remember the extra large edgeless one being hyped a while back.
    Voyagermike likes this.
  9. Nov 24, 2019 at 6:52 PM
    War Machine
    I haven’t tried the Edgeless. Don’t see how they can really improve on this one though.
    Griot's Garage 55590 1 Pack PFM Terry Weave Drying Towel https://www.amazon.com/dp/B01BD5F19A/ref=cm_sw_r_cp_tai_-f02Db704CYJW
  10. Nov 24, 2019 at 6:59 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  11. Nov 24, 2019 at 7:26 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    40 dollars for a towel? That's a lot of money I use my micro towel and spray my truck while it's wet with aero spray wax/cleaner so I'm waxing and drying at the same time.i can't see spending that much money 40 dollars ,not for me I'm sure it's good but my way is good too , been drying cars with a towel for 55 years ,
    War Machine and Hammy68 like this.
  12. Nov 24, 2019 at 7:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I spent $20 on some OK drying towels a few months ago and they were a huge improvement over the ones that I had been using. I've seen a lot of solid reviews on these, so $40 doesn't bother me for what it can do. AZ sucks for water spots so anything that can help dry the truck before those form is huge.
    Glockmeister and War Machine like this.
  13. Nov 25, 2019 at 4:13 AM
    War Machine
    I don’t disagree that it is very expensive, and certainly not the only effective way to get the job done. That said, it’s the only towel I know of that can dry an entire Tundra by itself. There are cheaper drying towels, but you always need more than one, so that closes the gap in price.
    Usually I dry the paint and glass first, then my Bakflip cover last. The Bakflip always has a ton of standing water on it. Even after drying the rest of the truck, it soaks up every drop of the pond on the tonneau cover with no effort.
    Certainly not for everyone, but there’s absolutely nothing better available. You don’t even have to use pressure. Just lay the towel across your hood, pick it up, and you’re done. For the sides of the truck, I just hold it along the top, and walk down the side. Just gravity and the weight of the towel does the job. This is very helpful to avoid marring.
    If you’re using spray wax as a drying aid, which is a great process, this isn’t going to be for you. You do need some pressure to make that work, and you’re not going to want to get wax absorbed into an expensive towel anyway.
    TRDFerguson and GODZILLA like this.
  14. Nov 25, 2019 at 6:12 AM
    swampshark
    south la
    2020 MGM SR5
    Pep Boy's was having an online sale when I bought mine....ordered online to get the discount and they sent the order to my local Pep Boy's who had it waiting at the register and I paid in the store....$31 with tax....
  15. Nov 25, 2019 at 7:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    I ended up getting the smaller version for $13. Well worth it!
  16. Nov 25, 2019 at 9:23 AM
    swampshark
    south la
    2020 MGM SR5
    $27.99 at Pep Boy's online...
  17. Nov 25, 2019 at 9:25 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I use my stihl blower.
    TundraDude18 likes this.
  18. Nov 30, 2019 at 5:32 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Thank you for the Pep boys info. I have one near me and will check it out today. Read the reviews on Amazon too. One towel will dry an entire truck?
  19. Nov 30, 2019 at 6:00 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Yup and very easily
  20. Nov 30, 2019 at 1:43 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    OK, you guys convinced me. Pep Boys had it and I went out and got one for myself. (another as a gift).
    Unfortunately, it is too cold to wash the car today and tomorrow there is supposed to be snow. So it may be a while before I get to try it.
    Pudge likes this.
  21. Nov 30, 2019 at 2:34 PM
    Pudge
    CT
    You will be very happy and amazed. Use it to dry off after your shower, I think you could dry a body with a 6"×6" PFM pretty easily.
    NewImprovedRon likes this.
  22. Dec 1, 2019 at 11:58 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  23. Dec 1, 2019 at 3:28 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  24. Dec 1, 2019 at 3:33 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Rarely do I find a product that lives up to the reviews... this towel does, it’s that damn good! I have a couple, I’m done buying them for now, but highly recommend.
  25. Dec 1, 2019 at 3:38 PM
    Pudge
    CT
    I have 4 of the medium gray w/ real trim, and 1 of the XL edgeless. :anonymous::anonymous:
  26. Dec 2, 2019 at 11:39 AM
    War Machine
    They’re 10.00 off now.....
  27. Dec 2, 2019 at 11:42 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Pep Boys still cheaper than Amazon, if you have one near you..
  28. Dec 2, 2019 at 11:44 AM
    War Machine
    The only one I have close is just a shop. They don’t sell products.
  29. Dec 2, 2019 at 5:11 PM
    War Machine
    Happens to me so much that when my friends want something, they ask me to buy one first.
    NewImprovedRon and Pudge like this.
  30. Dec 2, 2019 at 5:54 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Thanks gents!
    Just ordered one online, will pick up in store on Wed. $28 after taxes!
