AIP bypass problem
Discussion in '2nd Gen Tundras (2007-2013)' started by eversole, Nov 23, 2019.
  1. Nov 23, 2019 at 12:51 PM
    eversole
    eversole [OP] New Member
    john
    2008 5.7 tundra blue
    Lift wheels tires
    I was installing a AIP bypass and the tube on the manifold broke away from the flange. Is there any way to fix it without replacing the whole manifold?
    OR18TRD likes this.
  2. Nov 23, 2019 at 2:33 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    How did it happen, any pictures?
    14CRWMX likes this.
  3. Nov 23, 2019 at 10:47 PM
    eversole
    john
    Lift wheels tires
    Tapping a little to hard on the bolts to try and push the tube back so I could get the block plate in. I ended up drilling a hole in the tube that separated from the flange. Then I put a bolt thru the hole with a fender washer and homemade gasket in between the tube and flange it separated from. Not ideal but it worked until I replace the manifold. Cleared all of the codes and now runs like a scalded dog again.
    focal likes this.
