  1. Nov 22, 2019 at 9:41 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Weird I guess wheelers doesn't carry OME anymore. Toytec should and they also have a sale going on
    Another option is firstgenoffroad.com
    This guy uses dobinson springs and Billy 5100s on bottom notch
    https://youtu.be/F7UYLbNct4g
    speedtre[QUOTED] likes this.
  2. Nov 22, 2019 at 11:50 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  3. Nov 23, 2019 at 12:32 AM
    Good till the last drop!
  4. Nov 23, 2019 at 2:32 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    :eek:
    I filled up 21.6gal yesterday at $2.09/gal iirc. Gotta love Houston and lack of state sales tax. At least you got shell. They make good gas. I buy the cheap crap lol
    bmf4069 and Volt92 like this.
  5. Nov 23, 2019 at 4:41 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Holy crap, $3.70 gal, I'll stay in the deep south :eek2:
  6. Nov 23, 2019 at 5:35 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I've been considering a full Dobinson's setup too. Assembled coilovers (2 inches of lift) and rear shocks shipped to my door for $850 from Dobinsonsdirect.com...I would need to use an AAL as well....decisions decisions.
  7. Nov 23, 2019 at 7:16 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    If you get an AAL the only way to go is progressive 3 leaf style, don't waste money on a single AAL. The ride quality between the two is vast and the singles can snap in half under too much stress. Of the 3 makers of progressive AALs for our trucks I'd avoid icon, due to bad reviews and either go with wheelers off-road or toytec
  8. Nov 23, 2019 at 8:37 AM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    Went to the junk yard. Found an old low profile roof rack and I am now restoring it to put on my first gen camper shell. ABE2F51D-3D64-4067-A641-BF310ACF4FDE.jpg
    ethan1911, NUDRAT, bmf4069 and 9 others like this.
  9. Nov 23, 2019 at 9:41 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Yea, I was probably going to go with Wheelers...but the Toytec one is interesting...it says to leave the overload leaf in while Wheelers says take it out...
    Wheelers...
    Toytec
    Does anyone know anybody who's used the Toytec 3AAL?
    TX-TRD1stGEN and Volt92 like this.
  10. Nov 23, 2019 at 9:50 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its actually down about 80 cents, I was happy.
  11. Nov 23, 2019 at 10:08 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Experimenting with the red. Probs will change the red ashtray and drink holder back to black, but will live with it for a while. Easy work. Still have a few details to work out.
  12. Nov 23, 2019 at 10:20 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    The overload is optional on any AAL. I kept it in on both my Tacomas with wheelers AAL because they were pavement princesses. But my tundra I removed it for more flex offroad. The only reason to keep em in is to get the most lift possible. You remove em for a better ride but less lift. The likely reason they say to remove em is for off-road prowess and possibly the included ubolts aren't long enough to keep the overload in place. But they should be. The wheelers ones always were. It's up to you. If you have a shell on your bed or an rtt I'd keep the overload.
  13. Nov 23, 2019 at 10:33 AM
    One member here had a build thread with the Toytech AAL.
  14. Nov 23, 2019 at 11:53 AM
    Fred
    Hand Protectors
    Anyone familiar with these spring leaf clips/keepers? I’ve being looking around for some stouter versions, which come already assembled on some of these heavier duty springs sets, but this design looks like the only type available sold as a pair. Seeing the stouter version already installed on AAL options with them has reminded me to ask.
    Need some feedback, as these will be installed on new OE replacement leaf springs purchased separately.
  15. Nov 23, 2019 at 12:55 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  16. Nov 23, 2019 at 1:31 PM
    Fred
    Hand Protectors
    Thats the style, but like you can’t find the inside dimension of 2 3/8
    Might end up with doing a fold over design and adding some Fuse before doing install. The Fuse will act as a rubbery cushion preventing rub and rattles. Fuse will be added to clamps and dry prior to install.
    Right now, I’ve added squared u-bolts on the OEM originals which splayed and are clunking on slow turns. I’ll add these in addition to the poorly designed C clamps (like OEM).
    Possibly, I maybe able to re-use the ones added last year.
  17. Nov 23, 2019 at 2:17 PM
    Where are you going to source the OEM leaf packs? I thought someone said they don't make them anymore.
  18. Nov 23, 2019 at 2:36 PM
    Fred
    Hand Protectors
  19. Nov 23, 2019 at 2:39 PM
    Fred
    Hand Protectors
    Probs will do those General Springs for $129 each. Another $80 each for OEM shackles and about $40 for errata.
    $480 totes
  20. Nov 23, 2019 at 2:43 PM
    Fred
    Hand Protectors
    My OEM springs still have good spring (no sag), but they splayed from the badly designed keepers. If it was easy to just redo these I would, but better in this case to go all new and install a good set of keepers along side the ones that come with.
  21. Nov 23, 2019 at 3:04 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It should be easy enough to make your own keepers. A piece of 1/8" flat stock and a 3/8 shoulder bolt would be the only supplies you'd need. Maybe add a can of the bed liner you're so fond of paint them.
    Make a cardboard mock up to figure out the length, cut with a hack saw, clamp it in a vise, hammer it into shape, drill a couple holes. Shouldn't take much more than an hour to do all 4.
  22. Nov 23, 2019 at 3:43 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    One side welded with the exception of some more gussets and one side about half welded. Maybe tomorrow I will have them mounted. I am thinking of trying the steel-black for these guys. I suppose I should be ordering that tomorrow also.
  23. Nov 23, 2019 at 5:50 PM
    Mr. Pink
    Mr. Pink New Member
    Ontario, CA
    06 DC 4x4
    Tint, stereo system, lift , more to come
    CVJ Axle. I'll be putting it on tomorrow
  24. Nov 23, 2019 at 5:59 PM
    Looking nice. Are you going to weld or drill these to the frame?
  25. Nov 23, 2019 at 6:39 PM
    KarmaKannon
    Utah
    Some junk
    Drill and bolt.
  26. Nov 24, 2019 at 6:52 AM
    Fred
    Hand Protectors
    Developing some final plans with the interior colors scheme now that I can see yesterdays work with the naked eye. Not sure when it will happen but it should look pretty good once its all done. Plan is to remove front seats and door panels for properly performed job. I’ll add some Purple Carrot insulation throughout interior under the existing carpet. On the fence about ordering some new speakers since the door panels will be off and I don’t want to remove them ever again after this. Might call this Crutchfield place to speak with a human.
  27. Nov 24, 2019 at 7:19 AM
    KarmaKannon
    Utah
    Some junk
    Purple carrot insulation?
  28. Nov 24, 2019 at 7:53 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'm quoting my own post for @Professional Hand Model you'd also need a length of 3/8 black pipe to cut spacers for the bolts.
  29. Nov 24, 2019 at 8:29 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  30. Nov 24, 2019 at 8:41 AM
    Fred
    Hand Protectors
    Yeah. Its a Vegan Food Delivery Service. Keeps my skin healthy. They deliver in boxes with this nice thick recyclable insulation. An example pic is in my build thread. Save the whirled with whirled peas!
