Camburg UCA alignment????
Discussion in 'Suspension' started by Wiredshut112, Nov 18, 2018.
  1. Nov 18, 2018 at 1:06 PM
    Wiredshut112
    Wiredshut112 [OP] New Member
    Israel
    2014 ...1794 tundra
    So I have had fox coilovers on the truck they are the extended length coils , I just out the camburg uniball arms on.. my alignment was good before... After I put them on my camber was wayyy -.. I have been messing with it.. got it pretty good but now they are toed out a lot... Is this common? I can't even drive it to get akignea it's so bad
  2. Nov 18, 2018 at 1:11 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Camburg have a lot of caster built into them, this is well known and documented everywhere.
    That said, I run Camburg arms and have no issues getting my alignment where i want it.
    You cant adjust one aspect of the alignment without thinking it wont affect the other values. I would suggest taking the truck to someone who knows how to do alignment, not all shops are the same.
    TheBeast, Rica25 and dcsleeper408 like this.
  3. Nov 18, 2018 at 1:22 PM
    Wiredshut112
    Israel
    2014 ...1794 tundra
    But even to drive it boe it's toed out a lot... I have to get it drivable
    Rica25 likes this.
  4. Nov 18, 2018 at 1:25 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Ok,
    so break the nut, get a tape measure and adjust the toe.
  5. Nov 18, 2018 at 3:16 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Do that. You can get it decent enough to drive to the shop.
    The camburg uca will get you at a decent spec. Just need a good tech. There is usually some compromise.
    joonbug and Rica25 like this.
  6. Nov 18, 2018 at 4:22 PM
    Wiredshut112
    Israel
    2014 ...1794 tundra
    Thank, pulled rods in.. got it decent... Little positive camber.. but I will take it tomorrow to toys 4 trucks and see what they can do..
    Rica25 likes this.
  7. Oct 13, 2019 at 8:57 PM
    Rica25
    Ricardo
    Tulare
    I have Camburg arms now and wanted to see some alignment numbers I'm taking mine tomorrow
    saybng likes this.
  8. Nov 22, 2019 at 7:52 PM
    GDOLBOI
    GDOLBOI Under Qualified
    Jared
    Concord Ca
    2021 Platinum
    3” lift 33” BFG KO2
    Do you have Any numbers. I’m taking mine in tomorrow?
    Rica25[QUOTED] likes this.
  9. Nov 22, 2019 at 8:37 PM
    Rica25
    Ricardo
    Tulare
    no i do not i threw them away but some one here can hopefully chime in
    GDOLBOI[QUOTED] likes this.
