Brand New 2019 Tundra Leaking Oil - Only 3000 on ODO!
Discussion in 'General Tundra Discussion' started by EMToyo, Nov 21, 2019.
  1. Nov 21, 2019 at 4:08 PM
    EMToyo
    EMToyo [OP] New Member
    Very disappointed. Had Toyota's all my life, and they were all amazing. My previous Toyota, FJ Cruiser served for 11 years without any issues EVER. This one, two months of the dealer lot, and $40K later, already leaking oil.
    If I wanted such experience, I would go with a ford! I cannot believe my Tundra is having those issues. Brand new car. Wow.
    Will bring it to a dealer tomorrow for exam. Already called corporate and opened a case with them. Will see what happens, but this should not be happening to a brand new truck.
    OR18TRD likes this.
  2. Nov 21, 2019 at 4:11 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I would be pissed also but the world isn’t perfect. Let them take a look and see what’s wrong and go from there.
  3. Nov 21, 2019 at 4:16 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Considering about 100,000 Tundras are sold every year, the odds of each being 100% perfect is pretty up there.
    I'm sure the dealer will take care of you!
    Txexplorer23 and tinman10101 like this.
  4. Nov 21, 2019 at 4:30 PM
    Hopefully they correct that and do something for you.
    EMToyo[QUOTED][OP] likes this.
  5. Nov 21, 2019 at 4:56 PM
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    :popcorn:
  6. Nov 21, 2019 at 7:26 PM
    EMToyo
    Not sure what part of the engine is that. Here is another pic that may show a better perspective.
  7. Nov 21, 2019 at 8:02 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Huh...finally figured it out. Looks like the oil filter bracket to me. Attaches to the front of the engine with two o-ring seals. One or both of those probably leaking, or the oil filter housing leaking...should be an easy fix. That black housing on the bottom is the OEM plastic oil filter housing we all replace at first opportunity.
    Ready for a free oil change?
    Badger Co-Op likes this.
  8. Nov 21, 2019 at 8:09 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Yeah you are right .. you should have purchased a Ford. You will have much better experiences with them. :anonymous:
    JK. Like everyone says, the number of vehicles produced against the number that are lemons are slim but unfortunately, it happens. It probably is a very logical explanation and simple fix.
    Kung likes this.
  9. Nov 21, 2019 at 9:53 PM
    JohnLakeman
    Front of the engine, looking from underneath, in front of the tire on the passenger side.
    OR18TRD[QUOTED] likes this.
  10. Nov 21, 2019 at 9:54 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    @JohnLakeman says it looks like the oil filter bracket on the front of the engine.
  11. Nov 21, 2019 at 10:18 PM
    JohnLakeman
    https://www.sparksparts.com/auto-pa...7l-v8-gas-engine/engine-cat/engine-parts-scat
    See Item 15. Item 16 is the filter housing and the filter assembly. Item 15, oil filter bracket, attaches to the engine up above that little vacuum actuator, behind that gray conduit with two bolts, two nuts, and two o-rings that seal the engine oil passages into that oil filter bracket. If that oil filter bracket (called "housing" in the parts list) is loose, those o-rings will leak down the lower front of the engine and oil will show up where the green arrow is pointing. They'll find the leak wherever it is...minor disassembly required.
  12. Nov 22, 2019 at 5:51 AM
    JohnLakeman
    Yes, well, the green arrow is pointed to the bottom of the front timing cover split line where timing cover bolts to the engine...the leak could be from that joint. However, I believe the oil leak is actually higher up, and the oil is leaking down the front of the timing cover and has blown back and collected at the bottom. There is also oil running down the oil filter bracket from above the filter housing and off the plastic filter housing, indicating a leak source directly above.
    Hopefully, they will find the true leak, and not jump to the premature conclusion that the filter housing o-ring is the sole source. The filter o-ring could be leaking, but I think that oil film is from the leak running down. The OP should insist that they look at the oil filter bracket attachment joint...oil will blow back, but they'll be dumb to think it will blow up from the filter and then back to the timing cover.
    EMToyo[OP] likes this.
  13. Nov 22, 2019 at 6:00 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Could it be leaking from the oil cooler? Mine was leaking from that,
  14. Nov 22, 2019 at 6:29 AM
    JohnLakeman
    YES! Good thought!
  15. Nov 22, 2019 at 7:14 AM
    EMToyo
    Hi Guys,
    Thanks for the info. I will make sure I tell them. I will post an update once I complete my appointment today.
    Thanks!
  16. Nov 22, 2019 at 4:49 PM
    EMToyo
    Just got my Tundra back from the dealership. Apparently, leak on oil pressure sending unit. They replaced oil pressure switch and oil pressure sending unit. We'll see how it goes. I am relieved it's not something big. Thank you guys for all of your input.
  17. Nov 22, 2019 at 5:00 PM
    TheBeast
    TheBeast The Beach
    shit happens, it's how the dealer and Toyota handle it imo
    rockmup likes this.
  18. Nov 27, 2019 at 8:31 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Glad they found it. Leaks are one thing with rattle... hate them both.
  19. Aug 29, 2020 at 12:03 PM
    LANC
    LANC New Member
    Any update if problem was solved. I have a 2020 with less than 2,000 miles and have a small leak at the exact same place.
  20. Aug 29, 2020 at 12:57 PM
    mundra
    mundra New Member
    2019 platinum 4x4
    Must have been a Monday morning build. I’m glad they found it.
  21. Aug 29, 2020 at 5:50 PM
    Stig
    Stig New Member
    Labor work is tough when wearing a face mask all day
  22. Sep 2, 2020 at 7:03 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    When I purchased my truck in 2015 I drove from the dealership home, the next morning I had a spot the size of a quarter on my driveway. The rear main seal was leaking. I took my brand new truck back to the dealer and they pulled the transmission and found that one of the dowels that positions the rear main seal cover was not seated in the block. They had to tap it in and then replaced the rear main seal with a new one. It has not leaked since. It happens, take it in, if you have a good dealer with a good tech, they will fix it.
    Cpl_Punishment likes this.
  23. Sep 2, 2020 at 7:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wouldn’t worry. It will get fixed. When i bought my old 4.6 truck, it had a defective camshaft and toyota corporate flew out to help take it apart and figure out what went wrong. They got it all put back together good as new.
  24. Sep 3, 2020 at 6:11 AM
    blanchard7684
    blanchard7684 New Member
    Seen a few of these oil pressure sensors leak on other toyotas...
  25. Apr 17, 2021 at 7:30 AM
    LANC
    LANC New Member
    Hey. Everyone needs to remove cover under your engine and look for this leak. I had a mechanic tell me they are seeing on all they inspect. Mine is leaking. I am told not sure where the leak is coming from.
  26. Apr 17, 2021 at 5:48 PM
    Kung
    KG, VA
    Remove what cover, specifically?
