  1. Nov 21, 2019 at 2:35 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Rustoleum Bed Liner Trim Restoration
    Got mucho done today. Sprayed all the trim black. Ran out of time at the end of day, but was able to get a sample of the red inside the exterior trim stripe area.
    The door cup turned out nicely. I’ll be painting the lock tab sticker the same red once I start focusing on the other inside trim. Nice to have some color contrast in the cabin to break up all the ‘Moon Mist’.
    Will pick back up on things tomorrow.
  2. Nov 21, 2019 at 2:46 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I actually don't know that I'd mind the plastic part of the armrest and the window switch surround being black also. I might have to play around with that. Good work!
  3. Nov 21, 2019 at 3:12 PM
    Fred
    Hand Protectors
    Thanks.
    Right now the plan is to paint black:
    1) Door lock/window switch trim
    2) Ash Tray and Sliding Cup Holder Faces
    3) Glove Box (Opening Tab Only).
    4) Door Thresholds (screws in red).
    Considering painting black (but door panel needs to be removed to do proper):
    1) Lower Speaker Grill.
    2) Door Grab Handle.
    Darkness and KarmaKannon[QUOTED] like this.
  4. Nov 21, 2019 at 3:15 PM
    I have bad painting skills, how do you paint the screw heads, install them, and not chip out the center where your tool was used to fasten?
  5. Nov 21, 2019 at 3:18 PM
    Fred
    Hand Protectors
    Himalayan Hand Yoga Technique along with proper prep and quality paint.
  6. Nov 21, 2019 at 3:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well finally got a fuse box that might work for pinning the trucks fuse box for the trailer shit. Hopefully the pins fit. Box is from a 2019 Camry I had an insurance job on. Fingers crossed
    Darkness likes this.
  7. Nov 21, 2019 at 4:02 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I just went the 1" lift. I need to clear parrking garages still. I see no reason it couldn't do 2.5" no problem. I had the orange TRD Bilsteins with 2" progressive springs from Performance Products (No longer made unfortunately) on my 2001 & they were great. I had 5100s on my 2004 set at 2" and they were nice riding too.
  8. Nov 21, 2019 at 4:13 PM
    You're gonna get a certain someone all hot and bothered with this painting things black thing you got going on.
  9. Nov 21, 2019 at 4:24 PM
    Fred
    Hand Protectors
    @Darkness
    I colluded with a Ukrainian employee at Autozoned today. After finishing her smoke break, she sold me on the Toyota Red. Asked her if it would help me score more chicks and she laughed nervously. I flashed her my hands to ease the tension.
  10. Nov 21, 2019 at 4:26 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I like the red accent. Can't wait to see the finished product. I've had red accents on all 3 of my Toyotas as well.
  11. Nov 21, 2019 at 4:26 PM
    859A40EA-BB16-41AA-A9A3-01AA602A8CB3.jpg Preparing for tomorrow, all bolts in suspect were juiced with kroil, wire brushed and juiced again. Oriley CVs, oem ball joints, oem axel seals, east coast gear supply clam shell bushing upgrade, amsoil severe gear oil. Oh and the impact:)
  12. Nov 21, 2019 at 4:27 PM
    Fred
    Hand Protectors
    You dog with your Impact.
  13. Nov 21, 2019 at 4:31 PM
    SoCalPaul
    Paul
    While I'm an old Kroil fan, I've seen some tests recently & Seafoam Deep Creep seems to be far superior followed by Liquid Wrench Rust Penetrating.
    MDobb79 likes this.
  14. Nov 21, 2019 at 4:48 PM
    I’ve been really impressed with it, the fuel; brushless version is insane on batteries. Last summer we used it at work to remove and drive back in 150 or more 15/16” hex bolts on heat exchangers.......with one battery!!!
  15. Nov 21, 2019 at 6:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  16. Nov 21, 2019 at 6:20 PM
    I quote this guy all the time and no one gets it. That movie was hilarious.
  17. Nov 21, 2019 at 6:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I used to work with a guy who looked exactly like him. I made him say "eeeh scusi" all the time. I was looking for his face before the last tunnel but couldn't find it.
  18. Nov 21, 2019 at 6:52 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    If I'm not mistaken I think that's Fred Armisen
  19. Nov 21, 2019 at 6:56 PM
    Didn’t realize that till now
  20. Nov 21, 2019 at 8:38 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    May I suggest on 1) that you get some headliner material or door panel fabric for this surround, I think it should fade in/away.
    I think the door pull surround in matching black as above would look good. YMMV.
  21. Nov 21, 2019 at 8:42 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    If the dusty ones are the Land Cruiser wheels - I'd say use those.
    You have soft curves on all the windows, wheel wells, all over the truck.
    The straight square lines on the TRDs are at odds with the truck.
    MDobb79 likes this.
  22. Nov 21, 2019 at 9:37 PM
    Outbound
    Aaron
    Northern Alberta
    I have the Himalayan Hand Yoga nailed but can't master paint prep. Guess I'm out.
  23. Nov 21, 2019 at 10:17 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn I never caught that. I saw that movie long before I saw him on anything else.
    Heres the scene if anybody needs a laugh.
    speedtre, Outbound, bmf4069 and 3 others like this.
  24. Nov 22, 2019 at 4:36 AM
    Fred
    Hand Protectors
    Sansei made this Grass Hopper study with the Yang camp.
    You, being Canadian, must have studied with Ying camp.
  25. Nov 22, 2019 at 6:49 AM
    Outbound
    Aaron
    Northern Alberta
    Correct. Sansei did indeed train this humble servant in the Ying camp
  26. Nov 22, 2019 at 6:49 AM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Cranking/lifting with icons does not preload the springs like other designs, such as 5100's. So cranking them up (more lift) does not effect the ride quality. I love my ICON's, they gave me exactly what I wanted on and offroad.
  27. Nov 22, 2019 at 6:54 AM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    I wasted hours with PB Blaster and other penetrating fluids, then I found Seafoam Deep Creep. Shit works so good and very fast.
    SoCalPaul[QUOTED] likes this.
  28. Nov 22, 2019 at 7:37 AM
    Fred
    Hand Protectors
    Taking the day off today as yesterday was heavy duty. Plotting out next weeks moves on the interior/exterior paint finale.
    On second thought, think I’ll paint the red exterior trim after lunch today as its still clean and fresh. The Monsoon moving in tomorrow might reek havoc on my fresh substrate.
    Real stoked on the color now that some daylight is on it and allows a final determination.
  29. Nov 22, 2019 at 7:59 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I find this hard to believe. Then what does it do?
  30. Nov 22, 2019 at 8:08 AM
    speedtre
    speedtre New Member
    Inland Northwest
