Did my first oil change on my 06 double cab
Discussion in '1st Gen Tundras (2000-2006)' started by markshoreline, Nov 20, 2019.
  1. Nov 20, 2019 at 3:17 PM
    markshoreline
    markshoreline [OP] New Member
    Mark
    Whidbey Island, WA
    2006 Tundra TRD 75k miles
    Front trailer hitch, tonneau cover
    Have had it changed twice by shops after purchasing used two years ago with 75k miles.
    Since it has a front hitch, it seemed that removing the front plate would be complicated so I drained the oil and removed the oil filter from the top. That was easy, but replacing the filter was very difficult since I couldn't see the filter mount (it is under the alternator pulley) and is at an angle. It took almost half an hour of holding the filter with one hand and guessing at the angle to screw the filter in place.
    Any have a suggestion for a better way to change the oil/filter???
  2. Nov 20, 2019 at 3:23 PM
    Practice makes perfect! I will probably cut a notch in my skid to easily see, remove the filter. For the oil itself, look at a Fumoto valve; it’s a secure 1/4 turn ball valve that stays in the oil pan and you just open it when it oil change time
    bmf4069 likes this.
  3. Nov 20, 2019 at 3:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I’m assuming you are vertically challenged, so try using a small step stool or little step ladder to give you height so you can lean in. If your arms still aren’t long enough, then drop the skid plate and do it from under.
    Secret for you is to find the oil filter by feeling the threads first before install with your fingers. This gives you your range. I back (reverse) spin the filter also before then forward spinning to tighten. This also allows you to feel the angle and prevent cross threading.
    Make sure your hands are clean and you wipe the oil cooler before putting on the new filter. Prevent dirt contamination as much as possible.
    Darkness, bmf4069 and TundraDude18 like this.
  4. Nov 20, 2019 at 3:37 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    This Dude: like a BOSS!:D
    [Meaning 'masterfully done']
  5. Nov 20, 2019 at 3:48 PM
    Fred
    Hand Protectors
    @Darkness posted up some contraption for @FirstGenVol last year to help him with doing engine work. Think Tom Cruzé used it too?
  6. Nov 20, 2019 at 3:49 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Yeah, it will get easier with practice/experience. The main mistake new learners make is trying to see the oil filter mounting location. When you try to see it you make it more difficult for yourself. You want to learn to put an oil filter on by feel. Put the threaded hole of the filter against the threaded oil filter mounting nipple and gently wiggle it while turning it. It will catch and then just spin it on. With practice you will be installing filters in seconds on most any engine. Anyway, that's how I taught my sons and other new mechanics that I trained.
  7. Nov 20, 2019 at 4:05 PM
    markshoreline
    Mark
    Whidbey Island, WA
    Thanks, that's what I did in the end to be successful, though finding the threads with the filter was certainly a challenge, as you can't see the threads and you are screwing the filter up and at an angle. Yes, I did use a step to reach over the front end and down to below the alternator! Also, I dropped the filter once and it was a bit difficult to extricate from on top of the skid plate!!!
    The other odd thing is when I drained the oil I got 6 quarts out. I have added oil when it appears low on the dipstick, but since the manual says it takes 4.5 quarts I think it was overfilled. After driving and waiting 5 minutes (as mentioned on our forum) the oil is still not touching the dipstick, let alone not being in the zone. I don't like not seeing the oil on the dipstick. Should I add more oil? If so, how much?
  8. Nov 20, 2019 at 4:07 PM
    6.5cuties I believe
  9. Nov 20, 2019 at 4:07 PM
    Fred
    Hand Protectors
    Say what? You have a V8 4.7? Spec should be 6.5 quarts for ENGINE OIL. At least this is true for the 2002.
  10. Nov 20, 2019 at 4:08 PM
    Removing the skid plate next time will solve this problem. I'm way too short to do what you attempted.
  11. Nov 20, 2019 at 4:08 PM
    Fred
    Hand Protectors
    But you have nice hands.
    bmf4069 likes this.
  12. Nov 20, 2019 at 4:09 PM
    Thank you. :hattip:
  13. Nov 20, 2019 at 4:16 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    bmf4069 and speedtre like this.
  14. Nov 20, 2019 at 4:19 PM
    Fred
    Hand Protectors
  15. Nov 20, 2019 at 5:38 PM
    Yes, 6.5 quartz. Also don't overfill your filter, as it will spill when you tilt it to screw it on. Also, if anyone knows how to get 1/2 a quartz w/o cutting the full bottle in half let me know. It's a mess...
    speedtre and Darkness like this.
  16. Nov 20, 2019 at 5:50 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    A milk jug or any normal half gallon/Gallons jug screws right into the filler cap opening
    I use this for filling to keep from making a mess
    I cut the bottom out
  17. Nov 20, 2019 at 5:52 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    You'll get used to it.
  18. Nov 20, 2019 at 7:46 PM
    markshoreline
    Mark
    Whidbey Island, WA
    Well, one mystery is solved....
    When I looked again at the manual the spec for the V6 is 4 quarts and 6.5 for the V8.
    Duh
    Thanks everyone!
    bmf4069 likes this.
  19. Nov 20, 2019 at 9:15 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Do you take the seeds out of the cuties or leave them in??
  20. Nov 20, 2019 at 9:18 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Are you sure you cant drop the skid with the front hitch on? I had a Curt front hitch on my old Tundra and I am pretty sure I could drop the skid plate no problem with that on.
