Help - Bleeding brake system with "3rd Chamber"
Discussion in '1st Gen Tundras (2000-2006)' started by westtx28, Nov 20, 2019.
  1. Nov 20, 2019 at 7:00 PM
    westtx28
    westtx28 [OP] New Member
    I have a 2005 Double Cab LTD without VSC. I noticed brake fluid loss and traced it to the master cylinder leaking into the booster. My truck has the odd 2-piece master cylinder with the 2nd piece being referred to as the “unicorn” piece in other threads here. I order the part number that was the complete master and booster assembly. So now I have a very expensive but correct brand-new OE master and booster.
    I have a question on understanding the FSM instructions on bleeding the system. I’ve attached the FSM instructions for reverence.
    1. The notice says to bleed air from the chassis, 3rd chamber, and chassis again, in that order. Does this mean that I would first bleed all four wheels, then bleed the master, and then bleed all four wheels again?
    2. Section C-2 says to connect the vinyl tube to the master cylinder and the brake caliper or wheel cylinder bleed plug.
      I assume based on the images this means two separate bleeder bottles. One on the master and one on any of the four wheels?
    3. Section C-3 says to open the brake caliper or wheel cylinder bleed plug.
      It seems odd that you would perform the master bleeding steps that follow with one of the wheel bleeders open. I just want to verify this is the case.
    Has anyone done one of these or knows well enough to confirm or correct my assumptions?
    bmf4069 likes this.
  2. Nov 26, 2019 at 7:21 PM
    westtx28
    I did the master & booster replacement. For those with a double cab that has the oddball 2-piece master cylinder part # 47200-0C073 is the correct part. It gets you the complete cylinder assembly with booster. I'm pretty sure this is the only way to get it.
    So ultimately everything went smoothly and the brakes feel great. I guess the moral is to just follow the FSM step by step and not second guess it.
    bmf4069 and KarmaKannon like this.
  3. Oct 25, 2024 at 5:08 PM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    So no bench bleed?
  4. Nov 9, 2024 at 5:55 AM
    05Dub
    05Dub New Member
    Doug
    2005 Double Cab
    Stock
    As far as bench bleed, my 2005 sr5 DC without the vsc add-on CANNOT be bench bled. This is the first thread I’m visiting, but the new master cylinder, which will mount into the smaller, separate master cylinder’s piece that affixes to the booster (has bleed screw in top), has five weep holes next to the three O rings that slide into the mount. All the fluid will ooze out of those holes. My guess (?) is that it’s a way to collect any seepage past piston to recycle/ suck it back into reservoir somehow since leakage into booster seems to be a complaint for some. I called the online tech at Autozone to confirm this fir part # NM55666.
    Notice the diagrams above show two different types of master cylinder, with the fatter one being mine. Doesn’t inspire confidence.
