Can the tundra handle this?
Discussion in 'Towing & Hauling' started by Hbjeff, Nov 19, 2019.
  1. Nov 19, 2019 at 10:20 AM
    Hbjeff
    Hbjeff [OP] New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Could our trucks handle this atv carrier? Atv weighs 400lbs wet.
  2. Nov 19, 2019 at 10:24 AM
    Look at the weight rating tags in your door. 400 lb ATV should be fine. Hitch weight and payload are both over that.
  3. Nov 19, 2019 at 10:30 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    What does the carrier weigh?
  4. Nov 19, 2019 at 10:42 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    I know the tongue weight rating is higher than this setup, but i can understand if the forces are a little different in that there are no wheels on the other side of that trailer tongue?
    Carrier weighs up to 116lbs
  5. Nov 19, 2019 at 10:50 AM
    True. The leverage would be something to account for, but that's above my pay grade. I don't see why you wouldn't just put the ATV in the bed. It's already eating a bunch of payload, so it's not like you can load the bed up with a bunch anyway. Just my thoughts.
    BravoDeltaRomeo likes this.
  6. Nov 19, 2019 at 11:25 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    This is for a truck with a camper shell...
  7. Nov 19, 2019 at 11:26 AM
    Aaaah. That would be why I didn't think of it. Lol
  8. Nov 20, 2019 at 4:48 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    What does the camper shell weigh, and what is in the bed
  9. Nov 20, 2019 at 4:53 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    On stock leafs??
  10. Nov 20, 2019 at 5:16 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Yes stock leafs. Assuming bed load is just a sleeping bag and ice chest. If the total load is under the payload for example
  11. Nov 20, 2019 at 5:22 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Jeff, is the atv too big to go in the bed with your cap?
    My 2015 leafs....before getting Deavers, but I know even Deavers can fail as said in Alex’s leaf update thread.
  12. Nov 20, 2019 at 5:23 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    You probably can load the atv on the trailer hitch but just watch how much you squat and keep the bed as light as possible.
    JohnLakeman likes this.
  13. Nov 20, 2019 at 6:05 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I put on a 350lb jet ski on a carrier, then my boat behind that. Besides needing airbags, seems fine. Boat is probably another 3 or 400 tounge weight. Only wierd thing is the hitch angles down slightly to account for stock rake is my only guess. When loaded/lifted it makes it exaggerated.
  14. Nov 20, 2019 at 6:08 AM
    Jrharvey02
    Jrharvey02 New Member
    The leverage from that being feet away from your truck is enormous. Think of a bowling ball on the end of a broom handle, you’d never be able to pick that up. If I’m understanding, you’re looking at this in combo with a camper in the bed? No way you’re under payload with that atv in that spot. Get a trailer....
    Bama, landphil and Pinay like this.
  15. Nov 20, 2019 at 6:11 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
  16. Nov 20, 2019 at 7:55 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    “Camper shell” sounds more like a fiberglass shell/ topper than a slide in/ cab over type camper. But I could be wrong.
    GODZILLA likes this.
  17. Nov 20, 2019 at 8:09 AM
    Jrharvey02
    Regardless of what’s going on the bed, his payload would be maxed out with that atv setup and anything else in/on the bed is just gonna exacerbate the problem.
    Pinay likes this.
  18. Nov 20, 2019 at 8:14 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Yes its just a leer camper shell on his truck. His atv wont fit under the shell thus the reason for looking at this
    For a friends truck. 08 i think, all stock.
  19. Nov 20, 2019 at 8:21 AM
    Jrharvey02
    If it were me, I’d get a used trailer, do an over-under axle lift to gain 6” of clearance and throw on the biggest tires you can cram. That trailer would follow the truck anywhere and be much better for suspension and mpg.
    Trooper2 and BakNBlk2014 like this.
  20. Nov 20, 2019 at 8:36 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    plumber802, Bama, GODZILLA and 5 others like this.
  21. Nov 20, 2019 at 8:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Max tongue weight is like 900lbs. Should be fine. Take it slow over bumps. I’ve had a double dirt bike carrier on mine with about 500lbs and no issues. I was more afraid of the rack breaking. And careful on inclines and dips, the back of the rack will be really easy to drag.
  22. Nov 20, 2019 at 8:39 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Yeah this is just transport needs. He isn’t wheeling the truck
  23. Nov 20, 2019 at 9:16 AM
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    I had a very similar set up behind my first gen, no issues even with a dirt bike and gear in the bed. You just need to be aware of dragging it when going in or out of driveways as Joonbug mentioned...gotta drive it like a lowered mini truck and hit everything at a 45 degree angle :thumbsup:
    Trooper2, joonbug and Hbjeff[OP] like this.
  24. Nov 20, 2019 at 10:58 AM
    HappyGilmore
    Trent
    Lakewood CA
    It seems like the obvious answer to most people here is to get a trailer, but there are a few advantages to a set up like this that makes it worth the research and effort. When towing a trailer in CA you have to drive in the right lane only except to pass, no car pool lane, and 55 MPH max no matter how small it is. Also storage of a trailer vs the hitch hauler when not in use.
  25. Nov 20, 2019 at 3:22 PM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    I wouldn’t use it in my tundra.
    The weight x the center of gravity distance to the hitch is the moment the hitch bracket to the frame has to resist.
    The 900# tongue weight limit x the distance from the hitch to the ball is WAY less than what you are looking at in the photo.
    that thing is going to bounce and put a lot of stress on things.
    landphil and GODZILLA like this.
  26. Nov 20, 2019 at 3:34 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    If you drive over bumps with a trailer isn’t that the same force
  27. Nov 20, 2019 at 3:39 PM
    salmonator
    Tigard, OR
    Same weight but different moment due to the way way way longer moment arm.
    think of turning a bolt - std wrench vs a breaker bar or cheater pipe over the wrench. Force multiplier.
    BeachyTundra and landphil like this.
  28. Nov 20, 2019 at 3:43 PM
    HappyGilmore
    Trent
    Lakewood CA
    There are some engineering variables since the draw bar is 3 feet long vs 9 inches or what ever a standard draw bar is. 300 pounds input on a 9" ratchet is less torque than a 3 foot one. But the quad carrier force is spread over the 3 feet, not at the end of it like a hitch, so there's some math to figure what it really is. In my opinion and experience it's fine. Others may not be comfortable. Do what makes you comfortable.
    KTM Hauler likes this.
  29. Nov 20, 2019 at 3:45 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Oooooh ok get it now. It’s as if you had the trailer attached to a 3 foot long hitch insert
    landphil and Jrharvey02 like this.
  30. Nov 20, 2019 at 3:50 PM
    Jrharvey02
    And to think, at its furthest point its like 5ft away from the truck (my best guess). Imagine what you could turn with a 5’ breaker bar to put it in perspective. My money would be on the atv hitch arm snapping before the tundras hitch fails. That bouncing takes a toll.
    edit: I towed many a golf car (up to 12 at a time) for a few years and know what these things can do to a trailer...
    BeachyTundra likes this.
