Noise when turning at speed with leveling kit
Discussion in 'Suspension' started by AlexWV, Mar 15, 2018.
  1. Mar 15, 2018 at 4:28 PM
    AlexWV
    AlexWV [OP] Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Twice now I’ve been going around the same turn with a little speed and the truck made a grinding/rubbing noise of some kind and the traction light flashed. I’m on a 3/1 leveling kit running 35s. Could it just be the tires rubbing? They do at the right turn in reverse. Or is it possibly something else suspension-wise?
  2. Mar 15, 2018 at 4:31 PM
    Tires.
    Check your skid plate, mud flaps (if you have them) you may need a cab mount chop too.
    TheBeast likes this.
  3. Mar 15, 2018 at 5:21 PM
    AlexWV
    Alex
    WV
    Ok that’s what I figured. The bumpers appear to have been trimmed when I got the truck. Not sure about the CMC. How can I tell?
  4. Mar 15, 2018 at 5:22 PM
    Did you buy the truck new and have the work done after you purchased?
  5. Mar 16, 2018 at 5:18 AM
    AlexWV
    Alex
    WV
    No, I got it used with around 45k miles on it.
  6. Mar 16, 2018 at 5:19 AM
    AlexWV
    Alex
    WV
    Made my heart race
  7. Mar 16, 2018 at 7:52 AM
    Is it a grinding like a rub noise, or does your trac light come on and sounds a bit odd at certain angles?
    Dirty pic, but here is one of my cab mount chop. You can locate this next to the fender well towards the bumper. Take a photo of the area and we’ll let you know if it’s been done.
  8. Mar 16, 2018 at 8:13 AM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    Disable your traction control and test on same turn.
  9. Mar 16, 2018 at 8:24 AM
    AlexWV
    Alex
    WV
    My tire rubs the well sometimes backing out, but I know that sound. It could be that but happening at 40mph sounds different. It is a little more of a guiding sound than I would expect for that though. I'll go look for the CMC.
  10. Mar 16, 2018 at 8:24 AM
    AlexWV
    Alex
    WV
    I take that same turn every day I go anywhere, and it has only happened twice though.
  11. Mar 16, 2018 at 8:32 AM
    AlexWV
    Alex
    WV
    M
    Hard for me to tell where that part is, but here’s three shots to try. Sorry, I’ve just never messed with my vehicles any.
    2D8E0B77-3388-46E9-B329-99D10FE82A13.jpg 4DE97276-4026-4339-8E59-EE25C1148A13.jpg 5F441168-0893-48E8-9EF2-C73123E08B24.jpg
  12. Mar 16, 2018 at 11:30 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The pic Sean posted is the Cab Mount. It's where the back of the front wheel hits the cab area, where your mudflaps used to be. But if your dash lit up, it's most likely your traction control kicking in. Might start with a zero point calibration.
  13. Mar 16, 2018 at 11:33 AM
    AlexWV
    Alex
    WV
    Got ya. I was looking on the front side of the front wheel, since he has said towards the bumper. I'll look again later.
    I've had traction control kick in on take off before, and it wasn't quite like this. But may be different at 40+mph
    joonbug[QUOTED] likes this.
  14. Mar 16, 2018 at 11:36 AM
    AlexWV
    Alex
    WV
    Also, I still have mud flaps, so does that mean I definitely don't have the CMC?
  15. Mar 16, 2018 at 11:37 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You have 35's with a 3" lift and you still have your mud flaps on? How? o_O
  16. Mar 16, 2018 at 11:38 AM
    AlexWV
    Alex
    WV
    I don't know. It only rubs when I'm backing up and turn just right. I have spacers too if that makes much difference.
  17. Mar 16, 2018 at 11:40 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, the spacers actually make it worse in terms of the cab mount. Interesting
  18. Mar 16, 2018 at 11:43 AM
    AlexWV
    Alex
    WV
    The specs online say those tires are technically only 34.8". It also says they're for wheels 9.5-10.5" wide, but I'm on stock TRD wheels. Weird
  19. Mar 16, 2018 at 11:53 AM
    AlexWV
    Alex
    WV
    I really need one of you knowledgeable truck guys to come look at my truck and tell me what all exactly was done to it before I got it. :rofl: Will supply beer.:drunk:
  20. Nov 18, 2019 at 5:48 AM
    Tundra69
    Tundra69 2011 Tundra sr5 TRD 4x4
    Rob
    NW AR
    2011 Tundra SR5 TRD 4x4
    2019 stock Rims, Westin Steprail, TRD rear sway bar, 4 wheel power stop brakes and rotors, Tri-fecta Toneau cover, remote start, discover At3 tires, RC level kit, ventshade visors, BAMuffler 8”, Aries bull bar, more later
    Did you fix the grinding yet?
