Front sensor on a TRD Pro Grille
Discussion in '2.5 Gen Tundras (2014-2021)' started by Willskaf, Nov 17, 2019.
  1. Nov 17, 2019 at 9:17 PM
    Willskaf
    Willskaf [OP] New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Hi Fellas,
    I'm about to change my Chrome grille to a TRD Pro Grille. I kinda like the older TRD Pro Grille that comes on the 2018 year than the new one . However, I have the 2019 Limited with the sensor . Is there anyway to reinstall the sensor with some kind of kit or I just have to stick with the new TRD Pro Grille ? This is the Grille I like.
    Thank you for the help .
  2. Nov 17, 2019 at 9:44 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    https://www.ajtdesign-llc.com/online-store/TSS-Relocation-Bracket-10052A-p141587099
    :thumbsup:
  3. Nov 17, 2019 at 10:07 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thank you .do I need to recalibrate the sensor after?
  4. Nov 18, 2019 at 5:12 AM
    Squatting Pigeon
    Holden
    North Texas
    That I'm not sure of, but I wouldnt think so.
  5. Nov 18, 2019 at 6:40 AM
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    I'm in the exact same boat, would like to hear from someone that has used that bracket with the sensor and 18 pro grill as well. Thanks.
  6. Nov 18, 2019 at 7:10 AM
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    I used the jomax bracket last week. So far so good. I have put around 100 miles on it so far without issue. I did not recalibrate. They will send you a YouTube video when you order the bracket that is very very very very very detailed.
    One thing I will mention, they sent me a face plate for the bracket with a Jomax logo in it that is all in white. It is not subtle. I would contact them ahead of time and see if they can send you a more subtle face plate. I wish I did.
  7. Nov 18, 2019 at 7:24 AM
    daven
    daven New Member
    the AJT bracket is black, that is why I am curious about that bracket and recalibration. AJT has plenty of disclaimers regarding TSS issues not being their issue, not to call, etc.. Understood, but if most are using with no issue I'd like to go with that bracket.
  8. Nov 18, 2019 at 12:50 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I called my local Toyota dealership today as a second option to see if I can go with the 2019 TRD Pro grill just in case I was not able to go with the 2018 Pro grill. The service advisor was not as friendly and he said that if I use the 2019 TRD Pro grill, it will not work even with calibration. That's not what I have been hearing but he was very combative about it and he said definitely it will not work. My understanding is I can definitely go with the 2019 TRD Pro grill and it will not be a problem. Has anyone done that before without issues? He said the accident deterrent system will not work anymore.
  9. Nov 18, 2019 at 12:58 PM
    Blueknights75
    Ron
    Clayton, NC
    Many members have had great success installing a ‘19 PRO grill on a ‘18 or newer Tundra. There have also been several members who have installed the ‘17 PRO grill on a ‘18 or newer Tundra although there is a little more work to do because of the TSS sensor. There are some great you tube videos for both grill swap outs.
  10. Nov 18, 2019 at 12:58 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    I have the 2019 pro grill conversion on my 2019 limited. This calibration stuff is BS it either works or does not. The only thing I ran into was I bought the $60 ebay cover for the sensor and it would occasionally throw an error to "clean the sensor". I ordered the OEM and never got the warning again. If you want to verify it's "calibrated / working" all you do is use your cruise control do a few adjustments on the radar distance. You will know if it's "calibrated or not".
    Primalbryan likes this.
  11. Nov 18, 2019 at 1:00 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    The Jomax bracket (from every post I've seen of someone who used it) is not causing problems with the TSS.
    That said, I like the idea of going with a grill that doesn't require the relocation bracket, just to avoid possible warranty issues. I like the '17 Pro grill best, but I will probably just get a platinum or sport grill [I think they are exactly the same]: the upside of that would be that I could get the bulge and surround already painted in Quicksand.
  12. Nov 18, 2019 at 1:02 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    So you never have to calibrate anything? And it's working perfectly? I swear service departments AR not helpful anymore. They are not knowledgeable at all. he must have told me four times that it will not work at all. I took his name down that way when I do the conversion, I'm going to stop by and prove him wrong
  13. Nov 18, 2019 at 1:07 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    What is there to calibrate? If it's not reading the distance correctly that's an entirely different thing. Mounting it a few inches forward or back wards isn't going to effect it. If you were a foot or more off to the left or right that might, but I still doubt there is any "calibration to compensate" The are "calibrated when they are manufactured to the specs given by Toyota.
    Maybe I'm wrong and they can be calibrated, the question is does it need it....
  14. Nov 18, 2019 at 1:13 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I haven't done the conversion yet. I'm trying to figure this one out before I buy the Pro grill. As you know, my 2019 Tundra limited, the sensor is exactly centered on nthe grill. The 2019 TRD Pro, it's centered from right to left but it's not centered exactly in the center up and down the grill. It's approximately 5 to 6 inch lower than what I currently have. And when I hear from a dealership that it cannot be done, it makes me wonder. I'm planning on buying everything OEM including the sensor cover
  15. Nov 18, 2019 at 1:15 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I've been running this ^ exact conversion for over a month. No issues...
  16. Nov 18, 2019 at 1:22 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Okay. Great. And no calibration correct? You just simply changed the grill including the sensor and no problem?
  17. Nov 18, 2019 at 1:30 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    100% correct
  18. Nov 18, 2019 at 1:31 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I literally just got off the phone with Sparks Toyota service department. They said that if I change from my 2019 limited grill do the 2019 TRD Pro grill,, the collision detection will no longer work at all and I would have to turn it off. He also said that it still will not work even with calibration. This is weird.
  19. Nov 18, 2019 at 1:32 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    BTW I would order via @Roman he has a list on the thread of exactly what you need as there are "nuts" that are not really reusable.
    Roman likes this.
  20. Nov 18, 2019 at 1:34 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    If the radar for the cruise control works off the "collision detection" as I think it does, they don't know what they are talking about. Did you ask them if the cruise control would not work as well? I am 99.999 sure the radar and collision are the same sensor and cruise control with distance adjustment works great.
  21. Nov 18, 2019 at 1:34 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    That's great. I will do so. And regarding the conversion, I just don't understand why sparks service department said it will not work because how do you justify all the tundra Pro guys that are lifted?
  22. Nov 18, 2019 at 1:36 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Ask @Roman he works at a dealership he sold me mine and I don't think he would of sold it knowing it would not work...
    The guys at sparks, you may of got someone that didn't know what they were talking about.
    Roman likes this.
  23. Nov 18, 2019 at 1:37 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I did not ask him that question specifically. I just simply asked if there will be any issue by swapping a 2019 Tundra limited front grill with a 2019 TRD Pro grill. I asked if there's is any calibration needed? He said that yes there will need to be calibration however the collision detection will not work and I will have to disconnect it.
    I hope someone from Sparks Toyota is looking at this thread and to comment on it
  24. Nov 18, 2019 at 1:42 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
  25. Nov 18, 2019 at 2:52 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Sparks is actually one of the biggest Toyota dealerships that modify their trucks. @Roman does a lot as well. I think both of them know what you’re talking about, I wouldn’t say they don’t. The pro grill is technically set up for a 2 inch lift in the front that’s probably what you’re talking about. Yes it’ll probably work but it’s not aligned properly.
    Roman likes this.
  26. Nov 18, 2019 at 2:58 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I should of said that "individual" at sparks. 2" lower when you consider all cars are different heights etc. I still do not see how you would re-calibrate for that.
    Like I said I've done this conversion at it has worked flawlessly. YMMV I guess...
  27. Nov 18, 2019 at 3:07 PM
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    I will second this. Installed newest Jomax bracket about 1k miles ago. Simple install and ZERO issues with the sensor. No recalibration needed even after installing 6112s up front at 1.9”.
    My only issue is the branding on the cover plate. Wish it was black, but honestly you don’t notice it unless you’re looking for it. 4DB02E80-BEA3-4EAB-8651-54516250C31D.jpg
    Coachbuilder1 likes this.
  28. Nov 18, 2019 at 3:35 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    ok, so from what I'm understanding, I do not need to purchase a sensor? I can use my current sensor and only need the bracket?
  29. Nov 18, 2019 at 3:48 PM
    spyshot
    Ohio
    Correct. You remove the sensor from the grill and mount it with the new bracket
  30. Nov 18, 2019 at 3:54 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I was at my local dealership Saturday getting Sightline wipers. Buy one get one free sale. Two for $20. Stocked up for tundra and Venza. Anyways there was a service bulletin under the glass at the parts counter . My phone was out in my truck and I parked a long way out. Otherwise I would have gotten a photo. Parts guy was giving me a hard time because I wanted so many blades otherwise I would of asked him for a copy of it. Basically I (think)? It said that they would no longer sell TRD Pro grills to truck owners with the sensors in the grill because they will not work then? Something to that effect? Good luck. D
