Low pressure on cold mornings
Discussion in 'Wheels & Tires' started by Bushwacked989, Nov 17, 2019.
  1. Nov 17, 2019 at 6:19 PM
    Bushwacked989
    Bushwacked989 [OP] New Member
    2020 Tundra SR5 - Cav Blue
    With the lower temps hitting ... Every morning the sensors come on for at least one of the back tires. I have the 20" Goodyear Wranglers and I'm just wanting to make sure it's not jacking with my wearing of the tires.. my drive to work is 20 miles and normally about mile 15ish they get up high enough the alert goes off. The backs will be around 29-30 pounds. The fronts move up to 35ish.
    Do I need to add any air? Is this normal? (Also this is the first vehicle that has ever had pressure sensors haha)
    OR18TRD likes this.
  2. Nov 17, 2019 at 6:23 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Air molecules get closer when cold. Add air and your good. As air warms up pressure will go up in the tires.
  3. Nov 17, 2019 at 6:26 PM
    Bushwacked989
    Ya I'm just worried if I add air they may have too much once the air warms up inside ... How do I make sure that doesn't happen or I'm not always adding or releasing air ..
  4. Nov 17, 2019 at 6:29 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Every year for as long a rubber tires have been on earth they lose air when the first week of winter cold settles on them. Air them up a few PSI to the proper level and live long and prosper. No need to worry.
    ColoradoTJ and Bushwacked989[OP] like this.
  5. Nov 17, 2019 at 6:39 PM
    empty_lord
    05 rollover special
    Don’t over think it. 38-40 psi in the winter. 35 in the summer.
    It’s the way things have been for a very long time
  6. Nov 17, 2019 at 6:44 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    At the very least, match them all up. Put the rears to match the fronts at 31/32 psi.
    OR18TRD likes this.
