Spacers/Adapters Law
Discussion in '2nd Gen Tundras (2007-2013)' started by Albinator, Nov 15, 2019.
  1. Nov 15, 2019 at 10:04 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    I live in Utah and wheel spacers are not allowed but adapters are fine. Does BORA or Spidertrax have adapters? I honestly don’t know the difference...
  2. Nov 15, 2019 at 10:10 PM
    Sunnier
    Sunny
    San Diego, CA
    What are ‘adapters’? :notsure: I’ve never heard of this either.
    Black Wolf likes this.
  3. Nov 15, 2019 at 10:11 PM
    Sunnier
    Sunny
    San Diego, CA
    Albinator[OP] likes this.
  4. Nov 15, 2019 at 10:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Adapters are just spacers that run a different lug pattern on the male/female sides.
    They are identical parts. I run gen 2 tundra 5 lug “adapters” then :p
    Someone periodically checking the torque on their spacers is a safer motorist than 90% of cars that are never checked...
    YotaMan, Albinator[OP] and Sunnier like this.
  5. Nov 16, 2019 at 12:03 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Well this says it pretty clearly..
    “Wheel spacers are prohibited.”
    http://www.liftlaws.com/utah_lift_laws.htm
    Aside from that most wheel spacer manufacturers claim “offroad use only.”
    What kind of inspections do you have for registration? Do you think a cop is going to check your truck for wheel spacers if you get pulled over? What’s the penalty if a cop did notice you had wheel spacers?
    Here in Texas we have to do a safety inspection yearly before we can pay the yearly illegal tax in order to drive on the public roadways.
    If wheel spacers were illegal here, it would be during that inspection that your vehicle would get checked for wheel spacers (among all the other crap). People would simply remove them before going the safety inspection and put them on afterward. And if a cop found them during a traffic stop it would be a fix it ticket and some arbitrary amount for court fees.
    Tundyfundy and 08crewmax like this.
  6. Nov 16, 2019 at 12:44 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    5x150 x 5x150 wheel adapters is what you need :thumbsup:
  7. Nov 16, 2019 at 6:15 AM
    Albinator
    Utah
    Safety inspections are actually not required anymore in Utah as of about 2 years ago. I don’t think I cop would, but I’d rather be law abiding than worry about it.
  8. Nov 16, 2019 at 6:16 AM
    Albinator
    Utah
    Do you have a link to some good ones so I know what you’re meaning by that?
  9. Nov 16, 2019 at 6:17 AM
    Albinator
    Utah
    Do you have a link to which ones you have?
  10. Nov 16, 2019 at 6:36 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Spidertrax
  11. Nov 16, 2019 at 6:38 AM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Spacers are dangerous. Just go long travel.
  12. Nov 16, 2019 at 6:44 AM
    Albinator
    Utah
    What is long travel and what do you recommend?
  13. Nov 16, 2019 at 6:57 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you have to ask you don’t need it $$$$$$
    Lol
    Toyotoholic and 08crewmax like this.
  14. Nov 16, 2019 at 6:58 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
  15. Nov 16, 2019 at 6:58 AM
    Albinator
    Utah
    There’s a lot of things people don’t really need like some who get trucks just because they want them.
  16. Nov 16, 2019 at 6:59 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sometimes laws are just stupid. This sounds like one of those instances. There's basically no difference between a an adapter and a spacer except an adapter changes the lug pattern. Bora and Spidertrax are the 2 most trusted spacers. But you can just get new wheels with a different offset and avoid using spacers.
  17. Nov 16, 2019 at 7:01 AM
    Albinator
    Utah
    By different offset, do you mean width of the wheel? Does that cause less mpg because there’s now more rubber/surface space on the road?
    831Tun[QUOTED] likes this.
  18. Nov 16, 2019 at 7:06 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Different wheels wont change mpg. I chose spacers because I really like the trd offroad wheels but I wanted them to sit flush with fenders instead of sunk in
  19. Nov 16, 2019 at 7:13 AM
    Sunnier
    Sunny
    San Diego, CA
    Ha! You’d think. Because I didn’t want to cut the bed and cage, I have both. -12mm wheels in the front to clear all the LT, 2” BORA spacers in back to (somewhat) even out the width of back behind the front.
  20. Nov 16, 2019 at 7:23 AM
    YotaMan
    Colorado Springs
    2021 Platinum
    That was a bit of a joke my man, and may be a possible way to 'say you have spacers'
    Adapters and spacers are the same, except the lugs on the wheel side are a different pattern. Tundras being 5x150
    Best of luck
    Albinator[QUOTED][OP] likes this.
  21. Nov 16, 2019 at 7:58 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No, not different width wheel. Where in the sectional width of the wheel the wheel actually mounts to the hub. Or, the distance from the hub is another way to think of it. From the middle of the wheel section, the distance, either in (toward the truck) or out, the wheel mates to the hub
  22. Nov 16, 2019 at 9:26 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Fixed it for you.
  23. Nov 16, 2019 at 9:48 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Theres some confusion here. All wheel adapters are spacers but not all spacers are wheel adapters.
    These are a wheel spacers.
    Wheel adapters can be used to mount different lug patterns, however they can also be used as spacers with the same lug pattern as you currently have.
    The spacer shown above is where the laws are typically concerned since you may not get enough thread engagement with the spacer mounted.
    Spacers IMO are a bad plan, adapters are fine as long as they're installed properly.
    focal, Sunnier and Hbjeff like this.
  24. Nov 16, 2019 at 12:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Omg those old slide on spacer are still made? Those are terrible
  25. Nov 16, 2019 at 7:02 PM
    Albinator
    Utah
    Do
    Do you know what the biggest tire (widest also) that will fit the Tundra without mods?
  26. Nov 16, 2019 at 7:43 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't know, too many variables. But, there is a thread on the subject as it's the most asked question on the forum.
