2018+ Factory LED Headlights Switchback DRL Development
Discussion in 'Lighting' started by prerunnerseth, Nov 7, 2019.
  1. Nov 7, 2019 at 1:55 PM
    prerunnerseth
    prerunnerseth [OP] New Member
    Apex, NC
    2015 MGM Limited 4x4
    So, I bought a broken led headlight to take apart. I plan to design a sequential switchback board to replace the DRL board. Unfortunately I cant do the bottom one as it has some complicated driver circuitry that would be expensive to replicate. The bottom is just PCBs with LEDs and I should easily be able to make a replacement. Plan is to dim the bottom DRL and shut off the top DRL to allow a sequential amber turn signal on the top. For now here are some pictures of the inside.
    20191107_163444.jpg 20191107_163448.jpg 20191107_163453.jpg 20191107_163457.jpg 20191107_163709.jpg 20191107_164110.jpg 20191107_164123.jpg 20191107_164738.jpg 20191107_164758.jpg
    voz likes this.
  2. Nov 7, 2019 at 2:26 PM
    voz
    voz New Member
    2016 Tundra
    You the man Seth.
  3. Nov 7, 2019 at 3:31 PM
    prerunnerseth
    Apex, NC
    If you look at the board with the blue on it. At the bottom right corner is the LED controller IC. That IC was designed by a guy in my building.
    Black Wolf likes this.
  4. Nov 8, 2019 at 4:40 AM
    prerunnerseth
    Apex, NC
    BRIGHT!!
    Low brightness mode.
    Verifying i can easily shut off the top LEDs to enable the turn signal to run.
  5. Nov 14, 2019 at 12:04 PM
    prerunnerseth
    Apex, NC
    Switchback designing today. One board done one more to design.
    voz likes this.
  6. Nov 14, 2019 at 12:07 PM
    voz
    voz New Member
    2016 Tundra
    Dibs
  7. Nov 14, 2019 at 12:09 PM
  8. Nov 15, 2019 at 9:03 AM
    lewishenry19
    lewishenry19 New Member
    Sweeeeeet.
  9. Nov 15, 2019 at 12:10 PM
    prerunnerseth
    Apex, NC
    Changed the name of the thread to better indicate what im doing here.
    voz likes this.
