SAIS bypass and cold weather?
Discussion in '2nd Gen Tundras (2007-2013)' started by MacCTD, Nov 14, 2019.
  1. Nov 14, 2019 at 12:23 PM
    MacCTD
    MacCTD [OP] New Member
    2010 CM 4x4
    5100s
    Had the dreaded P2440 code, installed the Hewett tech gen 1 SAIS bypass kit with block off plates. Install went fine, truck has no codes and runs perfect, but I notice at startup it seems to hesitate slightly to start, recently it has been in the 20s. It cranks fine, the battery is pretty new. Is there anything the bypass does that would cause this when it is colder out?
  2. Nov 14, 2019 at 7:50 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Hmm I just installed a Hewitt Bypass and had no such issues here in Missouri. Had temps in the teens earlier in the week.
    HewittTech01 likes this.
