aftermarket wheels on 2001 AC - negative 8mm offset too far out?
Discussion in '1st Gen Tundras (2000-2006)' started by vanilla.chinchilla, Nov 12, 2019.
  1. Nov 12, 2019 at 11:00 AM
    vanilla.chinchilla
    vanilla.chinchilla [OP] New Member
    2001 tundra sr5 with topper and Wheelers AAL
    Needs vs wants
    Hi,
    potentially driving to look at/buy a set of wheels for my tundra. They are Black Pacers with E rated terra grapplers. seems like a decent deal at $450, but wondering how much a negative 8 offset will push the tires out. I know because of math they'll push out just shy of an inch, just wondering if anybody has done this on theirs and what their experience is. Will I need to wash the truck every time I hit a puddle?
    The truck has a tiny bit of rubbing at full turn when I hit a bump, so moving the tire out a bit wouldn't hurt. 1.5" lift in front and about level in back with 265/70/17 +15 offset currently, new wheels would be 265/75/16 -8 offset. Opinions on wheel size as well?
    Thanks
    Luke
  2. Nov 12, 2019 at 2:59 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    You’ll be alright, what’s the width on the wheels? 8? 9?
  3. Nov 12, 2019 at 3:38 PM
    vanilla.chinchilla
    Needs vs wants
    oohhh I don't know that one. Probably right in that range. looking around though, it looks like pacer only makes a 16x8 in that size.
