Overhead console
Discussion in 'General Tundra Discussion' started by Pariverpirate, Nov 10, 2019.
  1. Nov 10, 2019 at 10:43 AM
    Pariverpirate
    Pariverpirate [OP] New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    Well I screwed up. I was replacing the bulbs in my overhead console with LED's. Somehow I broke the switch to the light on the drivers side. Took the console down and played around with it and couldnt get it to work. The passenger side works but no the driver's side. Blew 4 fuses playing with it. Im at a loss. Pretty sure its just the switch as everything else is still working right. Question is now what do I do? A replacement console is $300. Havnt been able to find a used one in the right color for the right year. Any suggestions? Its a 2015 SR5 light grey interior.
    Thanks.
    DalTee likes this.
  2. Nov 10, 2019 at 6:50 PM
    Pariverpirate
    Rich
    Non yet
    Anyone know if a overhead console from a 2013 will fit a 2015 ? Holes look like they will line up.
  3. Nov 10, 2019 at 6:56 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    Mine is screwed up too. I just live with having no light on the drivers side. Replacement led bulbs light up the interior enough
  4. Nov 11, 2019 at 3:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not knowing what a 2015 innards look like, I'll still suggest putting a jumper wire from good switch to LED associated with bad switch. Good switch then turns on both lights.
    By chance do you have a Pick-a-Part like place close to you ?
    Also, Toyota Cool Springs has a Dome Lamp Assembly - Toyota (81240-0C050-B0) listed for $99.00 which shows it covers a number of years !
    https://parts.toyotaofcoolsprings.c...kcmEmeT0yMDE1JnQ9dHJkLXBybyZlPTUtN2wtdjgtZ2Fz
  5. Nov 11, 2019 at 4:36 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Been there done that
  6. Nov 11, 2019 at 6:22 PM
    Pariverpirate
    Rich
    Non yet
    THanks for the link but its the overheard console light aka map lights
  7. Nov 12, 2019 at 8:38 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    TRD-tv likes this.
