Newbie here help needed
Discussion in '1st Gen Tundras (2000-2006)' started by Dannyguo316, Nov 11, 2019.
  1. Nov 11, 2019 at 3:19 PM
    Dannyguo316
    Dannyguo316 [OP] New Member
    Danny
    2nd gen tundra double cab.
    Hello everyone, I recently purchased a 2002 sequoia AWD, 180k mile . I plan on changing the front and back rotors and pads, front struts. Oil change, transmission fluid, can you guys tell me what else I should look out for? And replaced?
    Thanks
    Prostar 190 and Black Wolf like this.
  2. Nov 11, 2019 at 3:22 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    You should probably also do the coolant, since you are doing all the fluid.
  3. Nov 11, 2019 at 3:25 PM
    Dannyguo316
    Danny
    That's right!!! Also when should I replace the original radiator? Previous owner owned the car since 2013, she doesn't seem to know much about cars. And I want this car to be in good shape since i plan on taking it for a roadtrip soon
  4. Nov 11, 2019 at 3:35 PM
    Welcome from NY.
    Also check the belts and hoses.
    Pinay and Dannyguo316[OP] like this.
  5. Nov 11, 2019 at 3:36 PM
    Dannyguo316
    Danny
    I did some reading on the forum, apparently timing belt is very expensive to replace
  6. Nov 11, 2019 at 3:37 PM
    Cheaper to replace it before it breaks.
  7. Nov 11, 2019 at 3:49 PM
    Dannyguo316
    Danny
    Words of wisdom lol
  8. Nov 11, 2019 at 4:37 PM
    koditten
    Kirk
    Midland of the Mitten
    I like to change the rads out at the 200,000 mark. Radiators are pretty cheap.
    I have no fear if aftermarket rads, just the shipping companies getting them to me.
  9. Nov 11, 2019 at 4:43 PM
    Welcome from Colorado. Pics?
    Dannyguo316[OP] likes this.
  10. Nov 11, 2019 at 8:11 PM
    Dannyguo316
    Danny
    Here she is. Just got her back to the house. I have to leave for a work trip. No time to change anything yet
    bmf4069 and Darkness like this.
  11. Nov 11, 2019 at 11:19 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Napa sells Denso radiators for a good price. I would also change the differential fluids, the transfer case and brake fluid. And replace the thermostat while you're doing the coolant. And grease the driveshaft slip joint.
  12. Nov 12, 2019 at 2:49 AM
    Welcome from Ohio.
  13. Nov 12, 2019 at 3:29 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Welcome from Maryland :hattip:
    FWIW- I would replace all fluids and timing belt !!
  14. Nov 12, 2019 at 4:22 AM
    bmf4069 Captain wtf
    If you replace the front shocks do the rears too. Stay away from monroes.
