False alarm..
Discussion in '2.5 Gen Tundras (2014-2021)' started by HighonFirewood, Nov 11, 2019.
  1. Nov 11, 2019 at 4:16 PM
    HighonFirewood
    HighonFirewood [OP] Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Third time I’ve tested this and maybe I’m missing something. I can drive my 5.7 V8 2019 all the way down to E. I get it about 20 miles during empty, and on my digital showing how many miles left, I only 1 mile...
    I fill up (3 different stations), and I can only fill 32 gallons. It will fill 32 almost exactly. All my truck info shows I have a 38 gallon tank. So, WTF?
  2. Nov 11, 2019 at 4:17 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Do a search. Lots of threads on this. About an 8 gallon reserve I think.
  3. Nov 11, 2019 at 4:18 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Its a built in reserve. Best not to take it too low or the fuel pump may get damaged.
    TTund16, Kerch71, Ely010606 and 4 others like this.
  4. Nov 11, 2019 at 4:19 PM
    longbedlife
    longbedlife New Member
    New England
    2020 DCLB
  5. Nov 11, 2019 at 4:19 PM
    18" TRD Off Road Wheels
    This.
  6. Nov 11, 2019 at 4:22 PM
    HighonFirewood
    2019 Tundra
    Did a search and apparently didn’t use the correct wording. Nothing to see here people...
    Pinay and GODZILLA like this.
  7. Nov 11, 2019 at 4:23 PM
    AZTundra
    Paul
    Phoenix, AZ
    You must have a blockage somewhere in the tank. :stirthepot:
    On a more serious note....Yup, as others above noted there is an extremely conservative reserve of ~8 gals which also keeps the fuel pump cool.
  8. Nov 11, 2019 at 4:26 PM
    HighonFirewood
    2019 Tundra
    I had no idea of this...and each time I thought I was crazy..appreciate the replies (mostly)
    Black Wolf and AZTundra[QUOTED] like this.
  9. Nov 11, 2019 at 4:27 PM
    What keeps the fuel pump cool is gas running thru it, not the gas around it. Sheesh...Still not good to run it down to true empty.
  10. Nov 11, 2019 at 4:36 PM
    Reserve is approximately 6 gallons for the 26 and 38 tanks.
    Ely010606 and Magnetic15 like this.
  11. Nov 11, 2019 at 5:36 PM
    Blue Thunder
    Washington
    <sarcasm on>
    You guys must be wrong...the manual says:
    <sarcasm off>
    Funny Toyota went through the trouble to mention 3.8 gallons remaining in the large tank, yet reality is much higher.
    Black Wolf likes this.
