Blower motor Resistor swap out
Discussion in 'General Tundra Discussion' started by jt83, Nov 11, 2019.
  1. Nov 11, 2019 at 11:02 AM
    jt83
    jt83 [OP] New Member
    07 Doublecab
    My ac makes dull squeak every time i turn it on. About 1/6th of the time it wont blow til ive been driving about 10 minutes. Seems like I might have a ac blower/resistor problem from what I've read. (I'm not mechanical at all so please bear w me)
    I can easily find a blower. Anybody know where to get the resistor??? Maybe I don't know what I'm looking for... thanks
  2. Nov 11, 2019 at 11:03 AM
    War Machine
    War Machine SSEM # 5 3MW
    I haven’t looked for a Toyota one, but they were available at any auto parts house for my old Silverado.
  3. Nov 11, 2019 at 11:24 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Thought the resistor was in the fan speed selector switch but not certain.
    Recently replaced blower/motor assembly. Fan was not working at all. I was able to measure dc volts at the fan harness. Voltage was incremental from about 1.5 to 12 volts when changing blower speeds low to high.
    If voltage present, would say bad blower/motor. A squeak or noise may suggest worn bearings as well.
  4. Nov 11, 2019 at 11:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Typically if the resistor is bad it won't work on any speed but high. Yours sounds like a blower motor problem.
    Randy Morton likes this.
  5. Nov 11, 2019 at 11:59 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Agreed
