2013 CM Bed bounce?!
Discussion in '2nd Gen Tundras (2007-2013)' started by Kevincmonaghan, Dec 18, 2016.
  1. Dec 18, 2016 at 8:56 AM
    Kevincmonaghan
    Kevincmonaghan [OP] New Member
    Kevin
    Greeley, CO
    2013 CM Limited
    So I noticed a few weeks ago I had really bad bed bounce from 60-80mph. It just sort of presented it self. I haven't changed anything on my truck. Tire pressure is good, wheels are balanced. So wtf?! I thought they resolved this in 2010?!! I had an 08 D.C. and bed bounce was terrible. My 2013 has it now? I only have 11,000mi.
  2. Dec 18, 2016 at 9:11 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    All of them have bed bounce my 2016 has it as well. It's really depending on the road you're on. Concrete paved roads are the worst. Updating the shocks with softer valving and changing the shackles helps quite a bit.
    I'm running kings and coach builder shackles with poly bushings and it's a night and day difference. I also installed a full bed rack that nearly took care of it all.
    TheBeast likes this.
  3. Dec 18, 2016 at 9:12 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Also it could be the cold weather if you're shocks are not getting to temp they will ride stiff.
  4. Dec 18, 2016 at 9:19 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    Well..... the other day was -11 and yesterday was -2, so that could be it I guess. Seems strange that it would just randomly happen all of the sudden.
  5. Dec 18, 2016 at 9:22 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    I'm betting the cold has something to do with it. I know my Kings are rough as hell when it's real cold.
  6. Dec 20, 2016 at 8:34 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    Does anyone know if the 2013 Tundra comes with the hydraulic body mounts? Or is this part of the TSB?
  7. Dec 20, 2016 at 10:14 AM
    Tundrazy
    Tundrazy Turd Bro
    '17 CM Cement PRO
    Is there anywhere on this site that lists all the TSB that apply to the Tundras? I know that Tacomaworld does. Just wondering what I might be missing. My '07 has terrible "bed bounce", but I have just gotten used to it over the years.
  8. Dec 21, 2016 at 8:53 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    There is a TSB for 07-10 tundras with bed bounce. If you call the dealer they can run your vin and will let you know. They replace the rear cab mounts with some different mounts that have oil inside and it's supposed to minimize the bed bounce.
