2nd gen - Convert stock brake/turn signal bulbs to LED?
Discussion in 'Lighting' started by digdug, Nov 10, 2019.
  1. Nov 10, 2019 at 6:25 PM
    digdug
    digdug [OP] New Member
    Doug
    2008 Crewmax
    5" BDS Fox 2.5 BDS UCA TRD stabilizer Airlift wireless one 35x12.5 Venom Power Terra Hunter XT 20" Hard Rock Indestructible
    I am wanting to convert my stock brake/turn signal bulbs to LED. Can anyone recommend a kit that might work?
    Thanks!
  2. Nov 10, 2019 at 6:30 PM
    VLeds Triton series
    TheBeast likes this.
  3. Nov 10, 2019 at 6:36 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    For brakes and reverse, have had good luck with Sylvania and Pillips from Amazon. Much more affordable than the VLEDs. Get red LEDs for brakes.
    Using Auxbeam for signals, again much more affordable. Signals need the resistor to avoid hyper flash.
  4. Nov 10, 2019 at 6:59 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    I want to do my front headlight turn signals as switchbacks. Not trying to piggyback but anyone got recommendations for something like this?
  5. Nov 10, 2019 at 7:06 PM
    Yep, Vleds Triton series.....they have switchbacks.
    TRD-tv[QUOTED] likes this.
  6. Nov 11, 2019 at 9:31 AM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    Now do those need resistors?
  7. Nov 11, 2019 at 9:50 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    For inexpensive....I went with Antline. Wrap a piece of electrical tape around the socket before you insert though cause they don’t fit super tight without doing that. I haven’t done the signals yet. I think I may use red bulbs for those too, as most vehicles don’t have yellow turn signals in the rear anymore
    ANTLINE Extremely Bright 3157... https://www.amazon.com/dp/B07MYX6Z2N?ref=ppx_pop_mob_ap_share
    For cargo, the third brake light, and the reverse lights I used Sirius LED.
    SiriusLED 921 Back up Reverse... https://www.amazon.com/dp/B0716QBV1C?ref=ppx_pop_mob_ap_share
  8. Nov 11, 2019 at 10:41 AM
    It is built in on my Gen 2 Tritons. You will have to call and see if it is the same on the V6 Tritons.
  9. Nov 11, 2019 at 3:08 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    That's awesome!! But $125 for turn signal bulbs, I'll wire my own in lol
